ASTROJET707
Explanation Of ETOP(s) Changes To A B752
Thu Jul 13, 2006 8:49 am
Would someone explain what physically is done to the airframe and engines when changing a B752 from "standard" to ETOPS?
Thanks very much!
AJ707
EMBQA
RE: Explanation Of ETOP(s) Changes To A B752
Thu Jul 13, 2006 9:26 am
Quoting ASTROJET707 (Thread starter):
Nothing... It mostly has to do with changes to the AFM and Operations Manual. There are also some extra cabin safety items added, but that's about it. ETOPS really has more to do with the way the aircraft is operated by the airline then it does physical changed to the plane. But, you must first start with an aircraft that 'can' be ETOPS certified...!! Not all can.
[Edited 2006-07-13 02:33:25]
kaddyuk
Thu Jul 13, 2006 10:12 am
Some components must be of an ETOPS standard.
Components of lower Mod Status although authorised for use by the Manufacturer on Non-ETOPS flights, are not able to be used on ETOPS aircraft.
This also means that if you install a component of a lower mod status, the aircraft can not fly ETOPS routes untill back to original Mod Status.
There are many different rules and regulations on this topic, i suggest reading JAR-OPS for more info.
SFOMB67
Thu Jul 13, 2006 2:42 pm
I believe some 757 & 767's may have all the required ETOPS equipment installed ( or wired for the installation ) during manufacture, but the airline doesn't choose to fly it as an ETOPS aircraft. They pay a non-ETOPS price, but have to pay later to have it ETOPS certified, if they decide to use it for that purpose.
Thu Jul 13, 2006 7:39 pm
An Hydraulic Mechanical Generator [HMG] is needed for B752 ETOPS Flight.
regds
MEL
Dalmd88
Thu Jul 13, 2006 11:32 pm
Correct on the HMG. Another change may be Cargo Fire Suppression system. As I recall on a non ETOPS a/c the system only has to suppress the fire for 60min, while on an ETOPS a/c it has to do it for the length of the ETOPS cert.
Thu Jul 13, 2006 11:39 pm
What About ETOPS Requirements with regards to Bulk Cargo hold Fire Extinguishing System on Freighters.Non ETOPS B752SFs have no Fire Extinguisher for Bulk cargo,just smoke Detectors.
regds
MEL
dl757md
Fri Jul 14, 2006 10:05 am
Not all 752s have HF radios which are required.
calpilot
Fri Jul 14, 2006 12:30 pm
Quoting EMBQA (Reply 1):
You know what, I've got to call B.S. on this one! If you don't know the correct answer then don't answer; And you don't know this answer.
It is NOT just a AFM change.
Not the least of these items is the HDG, Dual fuel crossfeeds, 180 min.Fire suppersion, Heavy weight evacuation slides, HF's, and yes about a hundred pages of more restrictive MEL requirements.
To lead people around the world to think that a standard B757-200 flying around domestic can turn into ETOPS with paper is wrong.
[Edited 2006-07-14 05:33:03]
Fri Jul 14, 2006 4:22 pm
The Number of pages or Size of the MEL is Smaller for ETOPS Aircraft  biggrin
regds
MEL
n8076u
Fri Jul 14, 2006 5:29 pm
Quoting HAWK21M (Reply 9):
Less things you can MEL means less pages, yup!
Chris
Don't blame me, I don't work here...
FlyingColours
Fri Jul 14, 2006 8:03 pm
I can only give you a few aspects of the cabin changes as thats my area. I've not actually flown an ETOPS route yet but some of our 752s are equipped (its most of our older aircraft that are ETOPS from the days of the good ole trans-atlantic charters  Smile ).
The emergency exit slides will be replaced with Sliderafts which come complete with an erectable canopy and basic survival pack (puncture repair kit, water purification tablets etc...).
Liferafts will be carried as well, although all the aircraft have the appropriate stowage that doesn't mean they will be fitted.
I don't know if its a requirment but Survival packs are also added, these are just placed in overhead lockers near to the liferafts. These should contain;
Knife, whistle, canopy, sponges, a cup, torches, sea sickness tablets, boiled sweets, 1st Aid Kit, Hand pump, water packs, water purifing tablets, signalling mirror, sea dye tablets, canteens and a signalling mirror. Oh and of course booklets entitled "Immediate actions and features of sea survival" - I kid you not  Wink
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
SP90
Sat Jul 15, 2006 3:47 am
Quoting FlyingColours (Reply 11):
Knife
If there is a knife in the survival packs, whats the point of all that hassal TSA put you through about no sharp objects allowed in carry-ons?  Confused
Sat Jul 15, 2006 4:51 am
Quoting SP90 (Reply 12):
Don't question the logic  Wink Seriously, AFAIK (and I may be wrong) this is a rope cutting knife for the rafts. So the blade is pretty recessed.
FlyingColours
Sat Jul 15, 2006 7:47 am
Quoting Starlionblue (Reply 13):
Well thats partly right, there is a knife actually attatched to the slides themselves (well a little pouch on there) to allow you to cut the rope. The one in the survival pack is small and besides you'd have to unpack the thing first and since they are the size of a suitcase and are bright yellow someone's gonna see you  Wink
Yes the blade is recessed on the ones on the slides, you are supposed to put the rope through a little gap then fold the rope over it to sever the conection. I've never seen the survial pack issue ones though - hope never to either.
Phil
FlyingColours
Sat Jul 15, 2006 9:47 am
Quoting FlyingColours (Reply 14):
Probably a small blade. Enough to hurt someone but as you say it's a bit of work to get to it.
Perhaps there are also scalpels, tweezers and scissors in the first aid kits?
FlyingColours
Sat Jul 15, 2006 9:34 pm
Quoting Starlionblue (Reply 15):
There are some scissors in the AED (Automated External Defib) box which can only be used to cut open clothing to allow quick acess to the chest area - its impossible to stab anyone with them as the pointy ends actually curve outward and are rounded.
I'm not aware of there being any scalpels though.
Phil
FlyingColours
EMBQA
Sun Jul 16, 2006 11:33 am
Quoting Calpilot (Reply 8):
I never said JUST the AFM. I said 'mostly'... which for the most part is true. 99.999% of the traveling public could not tell the differenace if they walked onto either plane. I also said there were added safety equipment... and lastly, you first need to start with an aircraft that can be certified.. not all can. All of that is true...
dl757md
Sun Jul 16, 2006 12:03 pm
Quoting EMBQA (Reply 17):
In defense of Calpilot's blasting of you, your answer to the following question was "nothing".
What 757s are not capable of being converted to ETOPS?
DL757Md
Sun Jul 16, 2006 6:17 pm
Quoting Dl757md (Reply 18):
The Ones with no HMG installed.Unless you fit it
regds
MEL
[Edited 2006-07-16 11:18:08]
dl757md
Sun Jul 16, 2006 8:42 pm
Quoting HAWK21M (Reply 19):
Which is no that big of deal to do. It probably takes less time to install it and the associated plumbing and wiring than it does to install winglets yet everybody seems to think 'why not put winglets on xyz airplane?'. But these same people think that if a plane doesn't have an HMG it's irrevocably bound to flying no further than 60 mins single engine flight time from the nearest suitable runway.
DL757Md
MarkC
Sun Jul 16, 2006 10:20 pm
For the PW engines, certain parts are "ETOPS approved", or "not approved for ETOPS". They are all the latest change parts. It probably has more to do with those parts being BOM when it was approved. I don't think they are appreciably more reliable than earlier parts, but if you want to "convert" a 2000 to ETOPS, you have to go through the list to make sure all the ETOPS parts are installed, or swap for them.
