KDTWflyer
How Much Fuel Does The AN-225 Hold?
Sun Jul 23, 2006 3:31 am
How much fuel does the AN-225 hold?
NW B744 B742 B753 B752 A333 A332 A320 A319 DC10 DC9 ARJ CRJ S340
A342
RE: How Much Fuel Does The AN-225 Hold?
Sun Jul 23, 2006 3:38 am
My BET is on about the same capacity as the A380 (310000 liters).
Exceptions confirm the rule.
RichardPrice
Sun Jul 23, 2006 4:01 am
661,375 lb (300,000 kg) with a load range of 2,430 nm (4,500 km) and an unload range of 8,310 nm (15,400 km).
pavlin
Sun Jul 23, 2006 9:31 pm
The loaded Antonov sure burns a lot of fuel 300000kg for only 45000km. Maybe a new engines would extend this range for at least 2000km?
A342
Mon Jul 24, 2006 3:01 am
Quoting Pavlin (Reply 3):
Hell, no ! There's not anywhere near 300,000 kg of fuel in it when it's fully loaded (with 250 tons of payload) ! In that case, the TOW would approach 800 tons !
There's only 300,000 kg of fuel in it when it has no payload, and in this case, the range is 15400 km, as RichardPrice noted.
rendezvous
Mon Jul 24, 2006 9:31 am
With nearly all planes, you can't have a full payload plus full tanks, otherwise you're over the taxi and takeoff weights.
N353SK
Tue Jul 25, 2006 2:36 am
How much does a gallon of Jet-A weigh?
RichardPrice
Tue Jul 25, 2006 2:44 am
Quoting N353SK (Reply 6):
1 US gallon of Jet A at a specific gravity of .88 (it varies between .63 and .88) weighs in at 3.32KG.
So the AN-225 can carry 90,361 US gallons.
This is far from scientific as it depends on the time of day the aircraft is fuelled, how long the fuel has been sat around for at a certain temperature etc.
Users browsing this forum: dlednicer and 1 guest
