A380CGN
Some Sort Of Smoke In Cabin While Acr On Ground
Sat Jul 29, 2006 4:25 am
Hello everyone,
yesterday I was flying with 4U from CGN to VIE on an A319 and I noticed something I have never seen before and I don't know what it is: While the aircraft was on ground some sort of thick white smoke (which looked like evaporating dry ice) was constantly streaming out of the air conditioning outlets over the windows and over the overhead bins (but not out of the overhead air conditioning nozzles; only over the windows and over the bins). I held my hand in the smoke and noticed that it was pretty frosty. When the engines were started the smoke began streaming out more fast and when the engines spooled up for taxi there was even more smoke coming out. Only when we took off the smoke stopped.
As the F/As were quite busy I couldn't ask them about it but maybe you can help me...?
Thanx in advance for your answers  Smile
fr8mech
RE: Some Sort Of Smoke In Cabin While Acr On Ground
Sat Jul 29, 2006 5:05 am
Was it humid out?
The 'smoke' was propbably condensation. Normal when the the conditions are hot and humid and the pacs are working their hardest to cool the cabin.
xjramper
Sat Jul 29, 2006 5:14 am
Even when its a little bit hot out, that is the way the air conditioning works until it is in the air. Once airborne it uses the air at altitude to a/c the aircraft. I don't know how the A/C works, but perhaps MEL or someone could explain it better while the aircraft is on the ground.
XJR
Look ma' no hands!
bri2k1
Sat Jul 29, 2006 5:34 am
You can read my detailed post about air conditioners on jet powered aircraft here, in reply #2:
Dangerous Goods And Refrigerators On Aircraft (by Spinaltap Jul 24 2006 in Tech Ops)
The only difference on the ground is the APU provides the input air to the air cycle machines instead of the engine bleeds.
This "smoke" is definitely water vapor. It's pretty common on the A319/320/321 family while it's on the ground. I don't know why, but If I had to make a bet, it would be because the APU can't cool the air as much as the engines can, so water vapor that has frozen up during the flight melts when it lands and you see it entering the air stream.
[Edited 2006-07-28 22:38:26]
Position and hold
avioniker
Sat Jul 29, 2006 5:52 am
Before the new air cycle machines and water separators came into being I used to be able to make it snow in the cabin on a nice June Orlando afternoon.
AAAhhhhhhhhh the good old days...
 Smile
Jamie757
Sat Jul 29, 2006 5:56 am
Quoting Bri2k1 (Reply 3):
I'd second that.
I'd second that too, I've seen this happen a few times on the A321. Nothing to worry about.
Rgds.
"I feel like a turkey who's just caught Bernard Matthews grinning at him!"
nonfirm
Sat Jul 29, 2006 7:10 am
Also very common on the MD-80 as well you can almost make it rain. airplane
n8076u
Sat Jul 29, 2006 8:00 am
I remember when we were almost done with a C-check on an A320, they'd do a pressurization and pack operational/leak check, and you'd get that "white smoke" condensation from the vents then as well, even in a not so warm or humid environment at SFO.
Chris
Don't blame me, I don't work here...
musapapaya
Sat Jul 29, 2006 8:09 am
Quoting A380CGN (Thread starter):
Hello everyone,
Hey there!
How was your flight then? Was it nice one? I am a supporter of 4U!
William
Lufthansa Group of Airlines
N600RR
Sat Jul 29, 2006 11:42 am
...it happened in my Toyota truck yesterday morning.  cold  smile
Quoting Avioniker (Reply 4):
Would have liked to see that! Was it hard to do, or did you
just turn the a/c on when it was very humid?
"And the fluffy white lines that the airplane leaves behind are drifting right in front of the waning of the moon" -Cake
bohica
Sat Jul 29, 2006 11:45 am
Quoting Fr8Mech (Reply 1):
The best part is watching the passengers get nervous.  Big grin
Sat Jul 29, 2006 4:47 pm
Thats caused by Water Vapour in the Conditioned Air.
The Packs have Water Seperators/Water Extractors in the System.Sometimes due to Coalaser bag blockage or Defective components,if the Water is not properly seperated from the Conditioned Air,this type of Smoky effect arises.
The Warmer outside Temperature contributes to the effect too.
regds
MEL
MD11Engineer
Sat Jul 29, 2006 6:32 pm
Was it humid out?
Hot and humid? Most of Europe was at 32-39 degrees centigrade (90-100 degrees Fahrenheit) with 60 to 80 % relative moisture during the last few days!
Jan
Matt72033
Sat Jul 29, 2006 7:09 pm
happens on our 340's often!
i remember being sat on the ground at the gate at JFK last october, there was a huge storm going on outside and it happened to us then, my friend who i was travelling with turned to me and said "isn't it great how they do that? i remember when the hosties used to walk up and down the aisle spraying the pesticides, now they just do it through the vent system"
i've never laughed so much in my life!
jeb94
Sat Jul 29, 2006 8:56 pm
I first saw this on my first C-130 ride out of Okinawa. Not that uncommon and certainly not unsafe.
A380CGN
Sat Jul 29, 2006 11:01 pm
Hey everyone,
thanks a lot for your answers!  Smile I already thought, that it was nothing to worry about but I just hadn't seen this before. Thanks again.
Quoting Musapapaya (Reply 8):
Hey there!
William
Yeah, it was quite nice. I did that as a day-trip. In the morning I flew on the D-AKNR with the former US-Airways interior and on the way back it was the brand new D-AGWA. The seat pitch is quite narrow but for me it's okay.  Smile
Sat Jul 29, 2006 11:15 pm
Packs fed by the APU or high pressure external bleed are on high flow on the ground regardless of the setting on the overhead panel, with the engines supplying the bleed the pack flow reverts back to the setting on the overhead panel, usually "norm".
The condensation is also a function of the air that is in the cabin at the time, usual only to see this at the start of a flight, at the end of a flight when the environment inside the cabin stabilised during the flight you will not see the marked change in relative humidity between the air in the cabin and that being supplied by the packs.
Tristarsteve
Sun Jul 30, 2006 5:07 am
The good old Vickers VC10 had godfrey blowers instead of packs. These worked well but were not very good at extracting the water.
On a descent into BAH at night where it is 30degC and 100% humidity ( yes I mean 100%, you needed windscreen wipers on to drive your car!), when the aircraft pitches nose up on finals the last four seat rows of pax get a shower!. You only sit there once!
N231YE
Sun Jul 30, 2006 9:32 am
I've noticed it on Avro RJ85's, coming out of the vents above the windows. Interestingly enough, while many A.Netters are talking about APU's and engine bleed air, the Avro that I experienced this on was hooked up to a ground mounted air-conditioning unit.
RichPhitzwell
Sun Jul 30, 2006 1:10 pm
Quoting N600RR (Reply 9):
You beat me to it, I used to have a Toy and it did this every now and then. freaked me out the first time as I was driving down the freeway. Never had any other truck do this.
I can imagine how worried PAX would be. Im suprised nobody screamed fire.
[Edited 2006-07-30 06:13:51]
Nonav.com kinda like Whiners except the lights are on and the pimps been paid
Sun Jul 30, 2006 3:29 pm
On the B737 Freighters,its common to notice this Smoke effect on Ground.
With The Main Deck lined with Smoke picups leading to Photoelectric type Smoke Detectors.Often the Thought is when would a Smoke Warning Illuminate,Luckily the Fogged Air does not continue to the Detectors as smoke would  Smile but the thought is always there.
regds
MEL
bri2k1
Wed Aug 02, 2006 6:38 pm
I rode on a UA 744 today and it there was so much mist, one passenger called it the "halloween flight." I took a short video. I'll see if it can get posted on another aviation forum which allows videos instead of just photos and provide a link here.
Position and hold
Wed Aug 02, 2006 7:19 pm
Quoting Bri2k1 (Reply 21):
Was this Mist In flight or on Ground.Looking fwd to the Video. Smile
regds
MEL
bri2k1
Wed Aug 02, 2006 11:17 pm
It was only on the ground.
They tried to start number 4 engine first, but the start valve would not open. The entire time the packs were running from the APU, it was just pouring out of the vents. We had to wait a while for a mech to manually open the start valve. As soon as a couple engines were running and the packs were running from bleed air, it instantly stopped misting. I'm talking now. This is consistent with all of my previous observations and is the reason I'm skeptical about the explanation given for why it happens on the ground but not in flight.
Strangely, there was no air coming out of the directional nozzles in the overheads until about half way through the 2-1/2 hour flight (ORD-DEN). Somewhere over Nebraska, they all of a sudden came on full bore. When we got to DEN there was a ground hold due to lightning and we had to wait about 25 minutes before we could be marshalled into the gate. Because of the delay, I had to rush off the plane and didn't get a chance to ask about it. When we got to DEN, which was clearly more humid than ORD on account of the thunderstorm, the mist did not start back up. I didn't see if the plane was hooked up to a ground-based air source. I know the same plane was going to continue to SFO a couple hours later, but they could have run the APU the whole time I suppose.
Position and hold
bri2k1
Thu Aug 03, 2006 12:12 am
Position and hold
AC320tech
Thu Aug 03, 2006 1:32 am
it happens quite frequently on the Airbus A320 family, about 1/4 of the 320 family fights I have been on have this issue, and its more common in the summer at night.
Thu Aug 03, 2006 5:16 pm
Quoting Bri2k1 (Reply 24):
Nice Video.What Recorder did you use.
regds
MEL
bri2k1
Thu Aug 03, 2006 5:29 pm
I have a Sony DSC-T5 digital still camera that also takes short video clips. I have a 1GB Memory Stick Duo Pro for it, so I think I can record 350 high quality images or about 35 minutes of video. Glad you liked it.
Position and hold
Thu Aug 03, 2006 5:32 pm
Quoting Bri2k1 (Reply 27):
Glad you liked it.
Im sure all do.After all you are sharing it & thats Appreciated.Any other Good ones.
regds
MEL
113312
Sat Aug 05, 2006 1:02 pm
Thank goodness it's not evaporating "dry Ice" which is carbon dioxide and not conducive to life! As most everyone has pointed out, the vapor is harmless water vapor, H2O resulting from the very cold conditioned air reacting with warm moist air of high relative humidity.
The highest amount of this water vapor frequently occurs when the cabin is being cooled from a very good ground conditioned air source. These units can produce very cold air and often do not have any sort of water separator device.
You can also experience water vapor clouds coming from the aircraft ducts when the aircraft is being cooled from the on board air conditioning packs. However, much of the water vapor from that source is removed prior to that air coming into contact with the ambient air in the cabin which is usually humid while the cabin doors are open. With the maximum cold setting, on many aircraft systems, air sent to the cabin ducts can be as cold as 35F/02C.
usair320
Sat Aug 05, 2006 3:29 pm
Im gonna say condensation from the air conditioning unit.
ThirtyEcho
Sat Aug 05, 2006 3:42 pm
Sheesh, folks, it is WATER VAPOR from the air condtioning system.
It was particularly noticeable on the Convair 240s in south Loisiana in the summer. I saw the same thing in my car in New Orleans.
usair320
Sat Aug 05, 2006 3:48 pm
Technically condensation and Water vapor are similar although not exactly the same.
Sat Aug 05, 2006 5:36 pm
Quoting 113312 (Reply 29):
Don't Ground AC Units have Water Seperatrs/Extractors.
regds
MEL
Sat Aug 05, 2006 5:47 pm
Quoting ThirtyEcho (Reply 31):
Incorrect.
It is the "new cool air" entering the cabin cooling the air in the cabin to the dew point temperature forming fog, this is then heated by mixing with the rest of the cabin air and the "new cool air" temperature increases above the cabin air dew point temperature and the "new cool air" appears clear again.
You can do the same by opening a refrigerator or freezer.
bri2k1
Sat Aug 05, 2006 9:43 pm
Quoting Zeke (Reply 34):
Perfect example. Boil some water on the stove so the humidity goes up in the kitchen, then open the kitchen. In the days before I had a seperate brewery, I'd boil wort on the stove for 2 hours. During the winter, opening the window produced the same effect.
Position and hold
Sun Aug 06, 2006 4:52 pm
Quoting Usair320 (Reply 32):
Condensation:- The physical process by which a vapor becomes a liquid or solid; the opposite to evaporation. In meteorological usage, this term is applied only to transformation from vapor to liquid; any process in which a solid forms directly from its vapor is termed sublimation, as is the reverse process.
Water vapor:- Water substance in vapor (gaseous) form; one of the most important of all constituents of the atmosphere
Ref
http://nsidc.org/arcticmet/glossary/
regds
MEL
N600RR
Tue Aug 08, 2006 10:56 am
Quoting HAWK21M (Reply 36):
Ref
Interesting...
What about this definition (from same site):
Hydrometeor Any product of condensation or sublimation of atmosphere vapor, whether formed in free atmosphere or at the Earth's surface; also any water particles blown by the wind from the Earth's surface.
So maybe next time it happens we could say this is just a simple case of "hydrometeorization"? This will surely impress your friends and comfort any nervous passengers. biggrin
Users browsing this forum: Baidu [Spider] and 2 guests
