bucks918
Ever Notice That Some Planes Seem To Fly Smoother
Sat Jul 29, 2006 3:04 am
Is it me, or do some planes just fly smoother than others? I flew on a 767 the other day and we were jerking all over the place, and this happens a lot with me and Boeings...yet when I fly A320's or A319's they seem much smoother, except for something I like to call the drop and drive on the Airbus. Did you ever notice that when it comes time to decent on an A320, the power seems to cut out all the way, and you start a steep decent? What is that??
Outlier
RE: Ever Notice That Some Planes Seem To Fly Smoother
Sat Jul 29, 2006 4:19 am
Quoting Bucks918 (Thread starter):
Well Bucks918, its likely that what you were experiencing is an atmospheric phenomenon many aviators call "shakey shakey."
Visit your local Be A Pilot center and they'll explain it to you.
http://www.beapilot.com/indexfl.html
avi8tir
Sat Jul 29, 2006 4:21 am
Quoting Outlier (Reply 1):
hahaha. ya, that should do it!
*Long live the Widget*
flydreamliner
Sat Jul 29, 2006 4:34 am
Yep, it must be those european designed suspensions.
"Let the world change you, and you can change the world"
Asturias
Sat Jul 29, 2006 4:43 am
I think the B737-800 is a very smooth plane. I fly it a lot over the northern Atlantic, the Pyrreneas and the Alps. The MD80s are also very smooth. The B757-200 feels more rough while the B747-100 and B747-200 are both very smooth.
Good planes all of them, though the B757-200 is my favorite of the above.  Smile
cheers
Asturias
Tonight we fly
Sat Jul 29, 2006 5:28 am
Obviously a heavier aircraft will tend to be smoother because of Newton's second law of motion. Inertia makes it harder to move the plane.
As for differences between a 320 and a 737, you will probably find greater differences within the same aircraft depending on where you are sitting. For example, I refer to the back end of long aircraft as the whiplash zone because the fuse flexes more there.
SlamClick
Sat Jul 29, 2006 7:04 am
Maybe the European airplane is designed for those quaint cobblestone airways?
nonfirm
Sat Jul 29, 2006 7:13 am
I have been in bad weather on the 737 and the MD-80 and the MD-80 is far more stable than the 737 in bad weather. airplane
Sat Jul 29, 2006 7:19 am
Quoting SlamClick (Reply 6):
Yeah. But in the Middle Ages when they built them traffic was much less than nowadays.
AirWillie6475
Sat Jul 29, 2006 7:27 am
How often do you fly?
SlamClick
Sat Jul 29, 2006 8:39 am
Well I've flown a few different types of aircraft and with two exceptions I never flew one that I thought behaved in any unexpected or surprising way in turbulence.
The two exceptions were the Huey with its 48-foot rotor disk, with a light load, and I no longer even remember what it was about it that was noteworthy, and the DC-3 with its 95 foot wingspan and weight in the high teens or low twenties. It seemed to me (very subjective) to get 'pushed around' by turbulence. It rode it okay but the movements seemed large.
Problem is to compare them you'd have to fly them through IDENTICAL turbulence. Now turbulence is, by definition, turbulent. That means it is unpredictable, changes from minute to minute, and so on. I've had some of the smoothest rides of my life in standing lenticulars - in defiance of conventional wisdom about them.
Beyond a few constants like wing loading and stiffness (Electra comes to mind) there really isn't much you can generalize about.
Sat Jul 29, 2006 9:02 am
Quoting Nonfirm (Reply 7):
MD80 has a higher wing loading.
fspilot747
Sun Jul 30, 2006 12:25 am
Main Entry: tur·bu·lence
Pronunciation: 't&r-by&-l&n(t)s
Function: noun
: the quality or state of being turbulent : as a : great commotion or agitation b : irregular atmospheric motion especially when characterized by up-and-down currents c : departure in a fluid from a smooth flow
All in jest, of course. Like aforementioned, some airplanes might be more stable in turbulence from the passengers' perspective. But really, the "drop and dive" and 767's being bouncy...that's just turbulence and you'd feel it on any other airplane.
[Edited 2006-07-29 17:33:10]
ThirtyEcho
Sun Jul 30, 2006 5:16 pm
I think that you are very correct in saying that the "ride" in turbulence differs among passenger aircraft.
Wing loading and wing flex have a lot to do with what you feel in the passenger cabin. For my money, the B707 was a champion in this respect; you'd see the wingtips flexing and the engines nodding in the chop without a single bump reaching the cabin. There was almost the same shock absorber action going on with the B727.
My first flight in a B737, back in the early 1970s, felt more like a Model-T on a dirt road, in comparison.
The all-time stiff-winged bone-rattler had to be the Lockheed Electra; seemingly high wing loading but zip wing flex and shock transmission like hitting a steel girder with a baseball bat.
AC320tech
Mon Jul 31, 2006 8:02 am
It really all depends on turbulence.
All Airbus aircraft (exception to A300 and A310) have a turbulence dampening system that engages when the aircraft is clean (no flaps, slats, or gear) and over 200kts. Turbulence only is felt for a few seconds.
mikkel777
Mon Jul 31, 2006 9:31 am
Quoting Zeke (Reply 11):
The 737, especially the 736, has a too weak yawdamper for it short lenght, and tends to fly sideways in turbulence. Large wing and short airplane is a bad combination.
Anyway, MD80/90 and 753 are probably my favorites in rough weather.
flyf15
Tue Aug 01, 2006 8:35 am
Its almost entirely based on the airplane's wing loading... with runners up being the airplane's built in stability and the effectiveness of its systems (autopilot, yaw damper, ..)
Users browsing this forum: Bostrom, fsabo and 2 guests
