AC320tech
Engine Naming
Thu Aug 03, 2006 7:03 am
I heard someware that the P&W JT series of engines stands for Jet Turbine. If that is the case, than what does the number and the D (or C in the JT3C) mean? Does CF stand for anything in CF6?
I know the numbers in the engine model has to stand for something other then sounding good when you say it, like RB211-535E4B? Howcome Rolls Royce used RB (and what does it stand for) and now Trent?
I know it is a lot of questions, bu Thanks!
DH106
RE: Engine Naming
Thu Aug 03, 2006 7:13 am
Can't help you with anything but the Trent part - most RR turboprop/jet engines are named after British rivers - Trent, Spey, Avon, Dart, Tyne.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
kaddyuk
RE: Engine Naming
Thu Aug 03, 2006 7:38 am
Perhaps they should have changed the Trent 556 name to the Thames... its full of sh!t... haha!
n8076u
RE: Engine Naming
Thu Aug 03, 2006 8:09 am
The "D" in JT3D, JT8D, JT9D stands for "ducted", as they are all turbofans rather than a turbojet like the JT3C. I have no idea what the "C" in JT3C stands for, though.  Wink
Chris
Don't blame me, I don't work here...
AC320tech
RE: Engine Naming
Thu Aug 03, 2006 8:16 am
Thanks Chris.
All the 707-120 and -320's have JT3C's and when you see pictures of it, is one whole engine with no LP bypass (thats open, because the JT3C is a turbojet) like on the JT3D, so the C should probibly stand for Closed.
Hahahaha at Kevin, it should be, considering RR them selves are not pleased with the fuel consmption of those engines.
kaddyuk
RE: Engine Naming
Thu Aug 03, 2006 9:50 am
Quoting AC320tech (Reply 4):
The core of the engine is pretty good, its just a shame that everything else bolted onto it isnt...
longhauler
RE: Engine Naming
Thu Aug 03, 2006 9:57 am
Quoting Kaddyuk (Reply 5):
Don't tell me it has Lucas Electrics????
kaddyuk
RE: Engine Naming
Thu Aug 03, 2006 10:10 am
Quoting LongHauler (Reply 6):
Even better, it has AIRBUS parts stuck to the side of it...  Wink
AC320tech
RE: Engine Naming
Thu Aug 03, 2006 10:19 am
I does have the fan of the Trent 700, which isnt the greatest. Kevin, do you have any trouble with the tripple spool?
kaddyuk
RE: Engine Naming
Thu Aug 03, 2006 10:46 am
Quoting AC320tech (Reply 8):
The shaft protection can be a pain (the system that detects if any of the shafts have sheared). Causes some troubles at time however normally a reset and functional test of the EEC fixes the problem. Operationally the engine causes little trouble, but it can make for awkward delays... Most engine issues i see are with items attatched to the powerplant (Hyds, Elecs, Bleed etc...)
[Edited 2006-08-03 03:47:36]
jetlife2
RE: Engine Naming
Thu Aug 03, 2006 12:08 pm
RB = Rolls Barnoldswick
CF = Commercial Fan
CJ = Commercial Jet
CFM = Commercial Fan Moteur
Sub-naming conventions for GE:
major models are, for example, Commercial Fan 6 (CF6).
This becomes a family name - and now has acquired a "Brand" value. So quite a range of engines are designated under the "CF6" family name, even though this spans CF6-6 up through CF6-80, where you could have easily designated them CF6, CF7, etc.
Simlarly CFM56 was named using part GE, part SNECMA methods. SN designates in sequence "Moteur 56", "Moteur 88" etc. So we have
CFM56 = Commercial Fan Moteur 56
The CFM56 is now a brand so it acquired sub types CFM56-2, -3, -5, etc. The missing numbers (-1, -4) did exist as studies. Extra credit if you know which applications they could have been. The -6 was not used to avoid possible confusion with CF6.
Further models within a family have names that designate the basic engine, such as
CF6-80C2
CF6-80E1
These are just the start....
suffix B - Boeing, A - Airbus, D - Douglas
sometimes suffix F means FADEC (vs PMC) but this is so common now, so no longer used for new programs.
first example CF6-80C2D1F is a "CF6-80C2" engine built for the first Douglas installation (D1) with a FADEC
2nd example CF6-80C2B6F is a "CF6-80C2" engine for the 6th Boeing application (B6) with FADEC. Why 6? Different thrust ratings for Boeing would be counted B1, B2, etc.
3rd example CF6-80E1A1 is a "CF6-80E1" engine for the first Airbus application (A1).
There's more...but that will have to do for now.
My views are not necessarily the views of the GE Company
AC320tech
RE: Engine Naming
Thu Aug 03, 2006 1:02 pm
Quoting Kaddyuk (Reply 9):
The Embraer E-Jets have lots of "sensor" issues and bleed issues on the CF34. These sensor issues are common, and can be fixed by simply "resetting" the aircraft (IE powering it all down, or resetting the FADEC) which can take upwards of 15 minutes.
Jetlife2, you earn my respect.
kaddyuk
RE: Engine Naming
Thu Aug 03, 2006 11:46 pm
Certainly earned my RR...
Thanks Jetlife2!
darkblue
RE: Engine Naming
Fri Aug 04, 2006 2:33 am
Quoting Jetlife2 (Reply 10):
Boeing has 2 aircraft that both carry CF6-80C2 (747 and 767) and for the most part, the engine is only differentiated by thrust rating. However, I've noticed something that helps me remember which rating goes on which aircraft. I'm sure this was entirely unintentional, but odd ratings (B1F, B3F, B5F) are on the 747, while even ratings (B2F, B4F, B6F, B8F) are on the 767. The one except to my dumb little rule is the B7F which is on the 767.
and i'll carry on in the CF6 family with:
  • L - Lockheed, K - Kawasaki (for the CF6-80C2L1F and K1F models)
CF34-10 family
  • E - Embraer, A - ACAC (CF34-10E & CF34-10A)
GEnx family, GE has used the same nomenclature for airframer:
  • A - Airbus, B - Boeing (GEnx-1A, GEnx-1B)
Multiple aircraft within the same airframer is noted by the first number:
  • GEnx-1B (787), GEnx-2B (747-8)
Finally takeoff thrust rating is noted by a number after the letter to give you a rough idea of takeoff thrust:
  • GEnx-1B70, GEnx-2B67, GEnx-1A72
Jetlagged
RE: Engine Naming
Fri Aug 04, 2006 10:49 pm
On the CF6-50 series, the -50C2 was the Airbus A300 version and the -50E2 was the Boeing 747 version of the same engine, so the suffixes (at least at that time) were issued in sequence, rather than A for Airbus, B for Boeing.
There was also a CF6-45A (for the 747SP I think), again it was the same basic engine as the CF6-50, probably with a reduced thrust rating. As the "50" probably represented the TO thrust rating (which is in the 50,000 lbs range) the -45 was probably derated to around 45,000 lbs.
Not sure why GE chose the CF6-80 designation, maybe they thought it would grow to 80,000 thrust? Possibly it was because 8 is a lucky number in the Far East?
Around the time the CF6-80 came out engine designations were getting out of hand, being more like a part number trying to represent everything in one. PW "rationalised" this by adopting its new numbering system, replacing JT9D-7R4xx with the new PW4000 series, where the last two digits represented thrust rating. It wasn't long before the suffixes started to appear again though!
I suspect RR adopted the name Trent (the engine is still officially an RB211) as the numbers were getting out of hand, also as a marketing brand re-launch.
As for the JT3C, JT3D issue the JT3C came first, so I suspect the fan version was named JT3D simply because D comes after C alphabetically, so it was the next designation in sequence. If the letter was to mean something, F would have made more sense. Of course the D suffix then stuck as meaning turbofan on the JT8D, JT9D, etc., even though there was no turbojet equivalent. So "D for ducted" probably came later. The C in JT3C certainly doesn't stand for "closed" as was suggested earlier.
manzoori
RE: Engine Naming
Sat Aug 05, 2006 5:37 am
I(t) does have the fan of the Trent 700, which isnt the greatest.
Oh really? Since when?
Rez
 Big grin
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
Users browsing this forum: 67ponajrad, Yahoo [Bot] and 2 guests
