taguilo
757 Typical MAC % Numbers
Mon Aug 07, 2006 12:30 am
Hi All,
Does anyone recall what is a typical MAC percent for a full loaded 757 aircraft, pax version and/or cargo version; and how many units of trim are needed for TO ?
Thank you
Tom
SNA350
RE: 757 Typical MAC % Numbers
Wed Aug 09, 2006 5:45 pm
MAC can vary from 13 to 30% when fully loaded
the trim units are 6.75 and 3.75 respectively
these are affcourse the limits for take off, I don't think a plane will fly like that
Aircraft flown: B733, B734, B736, B737, B738, B744, B752, B763, B772, A319, A320, A321, A343, A346, Do328, CRJ7, E190
taguilo
Wed Aug 09, 2006 8:15 pm
Quoting SNA350 (Reply 1):
Thank you for the info!
Tom
lehtora1
Fri Aug 11, 2006 9:24 pm
Hi,
I checked few charter flights from HEL to mediterranean destinations.
They had pax onboard between 190-220, and TOW was between 93-96 tons. ZF MAC was between 20-24%, TO MAC between 23-26% and trim units between 3.7-4.1 degrees.
Hope this helps you.
taguilo
Sun Aug 13, 2006 8:32 am
Quoting Lehtora1 (Reply 3):
Hi,
Yes, it helps me a lot. Many thanks  Smile
Tom
LAXintl
Sun Aug 13, 2006 1:23 pm
As far as loading the B757 plan bags in aft compartment 3 first. Depending on the type of flight and passenger load very often near all the baggage will fit into 3.
After that plan compartment 4 and 2, but this is somewhat dependant if you have a 2-class aircraft aircraft or an all economy aircraft. If all economy than having all baggage in 3&4 and forward compartments empty will work.
OldAeroGuy
Tue Aug 15, 2006 12:51 am
MAC is the Mean Aerodynamic Chord. It will not vary no matter how the airplane is loaded.
What you all are describing is the CG position in terms of % MAC.
taguilo
Wed Aug 16, 2006 12:41 am
Quoting OldAeroGuy (Reply 6):
Yes, that's it. I guess we all in this thread know that, so use the adopted common expression "% MAC" instead of the proper one. Anyway, thank you for pointing out the difference  Smile
Tom
SNA350
Wed Aug 16, 2006 1:41 am
thanks didn't know that
Users browsing this forum: DL777200LR and 5 guests
