A520
Tech/Ops
Mon Aug 07, 2006 5:45 pm
Hi there,
Is there a fundamental design reason with engines are always below the wings and not on top of them on modern aircrafts? Putting the engines on top would solve ground clearance issues and allow to use higher dilution fans.
[Edited 2006-08-07 10:46:35]
RE: Tech/Ops
Mon Aug 07, 2006 6:10 pm
A520
RE: Tech/Ops
Mon Aug 07, 2006 6:21 pm
Quoting HAWK21M (Reply 1):
Maybe the Title needs a Change
Yes, sorry, I mixed up between forum name and post name! Thanks for the link
RE: Tech/Ops
Mon Aug 07, 2006 7:20 pm
Quoting A520 (Thread starter):
Putting the engines under and in front of the wings has several benefits (? where I am guessing):
- Counteract wing twisting.
- Easier to change engines.
- Less noise in the cabin.
- Marginally more protection from blade shedding for the cabin?
- Pylon can be more elasic and transfer less vibrations to the wing?
- Airflow is cleaner by putting the engine out in front and below.
Besides, engines on the wing are just plain ugly. Just look at the dreaded VFW-614:
Photo © Gerhard Plomitzer
kaddyuk
RE: Tech/Ops
Tue Aug 08, 2006 12:07 am
Quoting Starlionblue (Reply 3):
This being the main reason, the airflow over the top of the wing is FAR more critical than the air Underneath the wing, which is why engines and Pylon pods are slung forwards...
LMP737
RE: Tech/Ops
Tue Aug 08, 2006 5:09 am
Along with some of the reasons already stated servicing engines on traditional aircraft is easier. Also if you drop something you don't have to worry about damaging the wing.
2H4
RE: Tech/Ops
Tue Aug 08, 2006 5:57 am
Well, Honda made it work:
Photo © Sergey Riabsev
Photo © Mike Paschal
 Wink
2H4
Intentionally Left Blank
Bobster2
RE: Tech/Ops
Tue Aug 08, 2006 6:24 am
Which is better for a wheels-up landing or a water ditching? I think I'd rather see an engine hit the ground/water instead of a whole wing hitting (the Honda looks especially scary), but I don't know.
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
RE: Tech/Ops
Tue Aug 08, 2006 11:45 am
Quoting Bobster2 (Reply 7):
If it's a crash, the engines will shear off anyway.
If it's slower than a crash, I'm sure the pilots on the board can enlighten you. My guess is that if you do it right you can belly land either with as much success.
RE: Tech/Ops
Tue Aug 08, 2006 5:56 pm
Quoting 2H4 (Reply 6):
I wonder why they did not use the common Fuselage Mounting.
regds
MEL
RE: Tech/Ops
Tue Aug 08, 2006 8:56 pm
Quoting HAWK21M (Reply 9):
IIRC the party line is that this was more efficient aerodynamically.
It may well be different just for marketing differentiation reasons. Make the aircraft look memorable.
N600RR
RE: Tech/Ops
Thu Aug 17, 2006 1:00 pm
Perhaps there is less vibration/noise in the cabin as a result? Requires less structural loading reinforcements, as the engine weight can be supported by the MLG? Simplified fuel delivery? Simplified maintenance? All of the above?
"And the fluffy white lines that the airplane leaves behind are drifting right in front of the waning of the moon" -Cake
RE: Tech/Ops
Thu Aug 17, 2006 3:00 pm
Quoting N600RR (Reply 11):
Any Link to this Aircraft with more Tech Details.
regds
MEL
Users browsing this forum: Flow2706, longhauler, Woodreau and 1 guest
