greg3322
Flight Attendant FAA Certificate?
Fri Aug 11, 2006 7:31 am
Do flight attendants get issued some sort of certificate from the FAA?
I noticed the flight attendant on my recent UA flight had a certificate in her badge holder that looked nearly identical to my pilots certificate.
In this day and age, I tend to not ask question in flight about stuff like that.
Greg
corey07850
RE: Flight Attendant FAA Certificate?
Fri Aug 11, 2006 7:47 am
Yes they do... if you look up a flight attendant in the FAA airmen registry, you'll see their information listed something like:
CertIficate: FLIGHT ATTENDANT
Rating(s):
FLIGHT ATTENDANT
GROUPII
greg3322
Fri Aug 11, 2006 8:29 am
Quoting Corey07850 (Reply 1):
Thanks, Corey! I never realized that.
Greg
corey07850
Fri Aug 11, 2006 8:36 am
Quoting Greg3322 (Reply 2):
Neither did I until just recently...
My dad is a mechanic and he also his license is also the same way...
EMBQA
Fri Aug 11, 2006 8:50 am
Yes they do...
I doubt it.. so what FAR do they operate and train under...?
FAR 61.. Pilots
FAR 63.. Flight Crew Members-Other then Pilots (not there)
FAR 65.. Airman- Mechanics, Riggers, Dispatchers (not there)
[Edited 2006-08-11 01:58:25]
corey07850
Fri Aug 11, 2006 9:03 am
Quoting EMBQA (Reply 4):
Ummm Part 121/135...
Before you doubt more, take a read:
http://www.faa.gov/library/manuals/e...rs/8400/media/volume3/3_014_01.pdf
lowrider
Fri Aug 11, 2006 9:09 am
121, 135, or 91 Sub K, depending on the operation. Completion of a carrier's training program will qualify them for issuance of a Flight Attendant's certificate. As far as I know, no medical is required. The FAA started issuing these a little over a year ago, just before the SIC types.
Proud OOTSK member
corey07850
Fri Aug 11, 2006 9:12 am
Quoting Lowrider (Reply 6):
Correct, but there are requirements for them to be able to lift certain amounts of weight (simulating exit doors, etc)... I'm not sure if this is actually in the FAR's but it's certainly in the particular airlines job description/operating manuals
EMBQA
Fri Aug 11, 2006 9:15 am
Quoting Corey07850 (Reply 5):
Training is goverened, yes.. it always has been. So provide a link that says their LICENSED. I provided a link to the licensed groups, and F/A's are not listed. They would fall under FAR Part 63 if they did.
You may want to re-check for facts...
Part 91, Sub-K... Frac. Ownership
Part 121, Sub-K... Instruments and Equipment
Part 135, Sub-K... Hazdrious Materials
[Edited 2006-08-11 02:25:41]
corey07850
Fri Aug 11, 2006 9:26 am
Quoting EMBQA (Reply 8):
Training is goverened, yes.. it always has been. So provide a link that says their LICENSED. I provided a link to the licensed group, and F/A's are not listed. They would fall under FAR Part 63 if they did.
"CertIficate: FLIGHT ATTENDANT
Rating(s):
FLIGHT ATTENDANT
GROUPII"
As I said before, this was taken directly off the FAA Airmen Registry for a Flight Attendant I know... FA's go through FAA 121/135 training and are awarded a certificate the same as any pilot, dispatcher, mechanic, etc would...
EMBQA
Fri Aug 11, 2006 9:38 am
Quoting Corey07850 (Reply 9):
So go to FAA.gov and read the regulations for Part 121 and show us where F/A's are listed..... or even mentioned...!!! They're not. (only under number required - passengers carried)
Quoting Corey07850 (Reply 3):
No, your Dad, like myself is NOT the same. We went to an FAA Approved and regulated school... or met the long requirements through hands on work...again regulated and over seen by the FAA. We then took the FAA approved tests and after passing were issued a license. The same holds true for Pilots and Dispatchers.
[Edited 2006-08-11 02:44:49]
lowrider
Fri Aug 11, 2006 9:49 am
Pay particular Attention to Section 4 paragraph E where is says that no person may serve as a flight attendant about an air carrier after Dec 11, 2004 without a flight attendant certificate
The Sub K was for 91 only. Fracs use flight attendants too.
ORDERS: 8400.10
APPENDIX: 4
BULLETIN TYPE: Flight Standards Information Bulletin for Air Transportation (FSAT)
BULLETIN NUMBER: FSAT 04-07
BULLETIN TITLE: Flight Attendant Certification
EFFECTIVE DATE: 12/10/04
TRACKING NUMBER: N/A
M/M ATA Code 14 CFR PTRS
N/A N/A 121 N/A
APPLICABILITY:
1. PURPOSE. This bulletin cancels N8400.64, Flight Attendant Certification. It provides revised guidance for principal operations inspectors (POI), aviation safety inspectors (ASI)-cabin safety, and directors of operations (DO) of certain air carriers concerning the flight attendant certification requirements established by Congress. It is reformatted for better readability.
2. BACKGROUND. In the fall of 2003, Congress established a flight attendant certification requirement under the Vision 100-Century of Aviation Reauthorization Act (the Act). Although flight attendants perform safety- and security-related functions, they previously had never been certificated like pilots, mechanics, aircraft dispatchers, parachute riggers, and others whom Congress calls airmen, collectively. Congress acknowledged that flight attendants perform vital crewmember functions onboard air carrier aircraft, including emergency functions for aircraft evacuations, firefighting, first aid, and response to security threats. Flight attendants are considered safety-sensitive employees subject to FAA drug and alcohol testing requirements and flight time limitations.
3. AVAILABILITY OF THE VISION 100-CENTURY OF AVIATION REAUTHORIZATION ACT. The entire Act may be downloaded at: http://www.gpoaccess.gov.
A. Click on Public and Private Laws.
B. In the query box enter “public law 108-176” (with quotes).
C. Click on Submit.
D. Click on the .PDF version of public law 108-176.
E. Flight Attendant Certification is in Title VIII-Miscellaneous, section 814, Flight Attendant Certification (page 102).
4. KEY PROVISIONS OF THE ACT. Among other provisions, the Act provides the following:
A. Definition of the term flight attendant. A flight attendant works in the cabin of an aircraft that has 20 or more seats and is used by an air carrier to provide air transportation.
B. Scope. The Act applies to flight attendants of air carriers providing air transportation using airplanes with 20 or more passenger seats under Title 14 Code of Federal Regulations Parts 121 and 135.
C. Distinction. The Act distinguishes between this certificate and an airman’s certificate. This certificate is not an airman’s certificate as specified in Title 49 of the United States Code (49 U.S.C.), section 44703; it is a separate kind of certificate as specified in 49 U.S.C., section 44728.
D. Appearance of the certificate. Each certificate of demonstrated proficiency shall:
(1) be numbered;
(2) contain the name, address, and description of the individual to whom the certificate is issued;
(3) be similar in size and appearance to certificates issued to airmen; and
(4) contain the airplane group for which the certificate is issued (Group 1 = Propeller-driven; Group 2 = Turbojet-powered). See Title 14 of the Code of Federal Regulations (14 CFR) part 121, section 121.400).
NOTE: An airline name appearing in the Limitations section of the certificate is not required by the Act and is not a restriction; it simply identifies the origin airline. The first several thousand certificates were issued with an airline’s name appearing in the Limitations section. The more recent certificates do not show an airline name in the Limitations section, nor will they in the future.
E. Compliance deadline. After December 11, 2004, no person may serve as a flight attendant aboard an aircraft of an air carrier unless that person holds a certificate of demonstrated proficiency issued by the FAA.
5. IMPLEMENTING THE ACT, GENERAL.
A. The DO enters a record; the FAA awards a certificate. If a flight attendant has not been previously certificated, the Director of Operations (DO) submits notification to the FAA by entering certain pertinent information through a web-based interface into the Flight Attendant Certification System database signifying that the individual has successfully completed all requirements of the FAA-approved training program. A certificate of demonstrated proficiency is effective immediately upon receipt by the FAA of notification by the Director of Operations by the above method. The FAA will mail a wallet-sized hardcopy of the certificate to the flight attendant within 10 to 14 days.
B. If the DO verifies that a flight attendant already holds a certificate, no further action by the DO is required. If a flight attendant has previously received a certificate of demonstrated proficiency in connection with training provided by another air carrier, the DO of the current air carrier verifies that a certificate of demonstrated proficiency has been issued. This verification is accomplished by either of two methods:
(1) a flight attendant presents the hardcopy certificate to the DO, or to the DO’s representative, or
(2) the DO or DO’s representative queries the FAA’s database (http://registry.faa.gov/amquery.asp) and finds a pre-existing certificate
C. If the DO cannot verify that flight attendant already holds a certificate, the DO must enter a complete record in the name of the flight attendant in the Flight Attendant Certification System database.
D. Carrying the certificate is optional. Flight attendants are not required to carry the certificate. If requested, flight attendants shall present their certificate to the FAA, the National Transportation Safety Board, or another Federal agency within a reasonable period of time after the date of request (FAA policy: 15 days). FAA ASIs are not required to verify if the flight attendant has in his or her possession the Flight Attendant Certificate of Demonstrated Proficiency. An ASI may use the ISIS mainframe database or the SPAS airmen search utility (MSAT-A) to verify that a certificate has been issued.
6. IMPLEMENTING THE ACT, SPECIFIC.
A. Director of Operations.
(1) The DO requests, in writing and on company letterhead, access to the FAA’s Flight Attendant Certification System. The request shall include the DO’s E-MAIL ADDRESS and be mailed to:
Federal Aviation Administration
Airmen Certification Branch, AFS-760
P.O. Box 25082
Oklahoma City, OK 73125-0082
(2) The DO determines that a person has successfully completed the training requirements approved by the FAA for that person to serve as a flight attendant.
(3) The DO enters a record in the FAA’s database in a timely manner, in the following instances:
· The first time a flight attendant not already holding a certificate completes initial, recurrent, or re-qualification training, or
· An airplane Group rating is added to an existing certificate.
(4) The DO enters the following data for each record:
· Name
· Date of birth
· Place of birth
· Address
· Physical description (height, weight, hair and eye color, and gender)
· Citizenship
· Qualification in Group I, Group II, or both
NOTE: Entering a record and generating a certificate is normally a one-time occurrence for each flight attendant, regardless of the number of air carrier training programs a flight attendant might complete. When a flight attendant completes training with a second (or subsequent) airline a subsequent record normally is not entered into the system, and no new certificate is generated.
One exception: When a flight attendant completes training with a second (or subsequent) airline and a new airplane group is added to the certificate. Only in this case must the DO enter updated information in the System; a new certificate is generated. (Two airline names would appear in the FAA database, the name of the origin airline and the name of the applicable subsequent airline.)
B. An individual flight attendant.
(1) Updating personal information is voluntary. If personal information shown on the Certificate of Demonstrated Proficiency should change, such as a name, date of birth, citizenship, or gender, a flight attendant may request that the information be changed in the FAA’s database. He or she should send by United States Postal Service, a signed request stating the reason for the request. The request should include social security number, date and place of birth, and certificate number together with a copy of formal documentation showing evidence of the change(s) such as a marriage certificate, a divorce decree, or a court order. Mailing address is:
FAA
PO Box 25082
(2) Replacement certificates are available. To obtain a replacement certificate reflecting any such change(s) a flight attendant must provide a permanent mailing address, and include a check or money order for $2, payable to the Federal Aviation Administration. If the permanent mailing address includes a post office box number, a rural route, or a commercial address, then the current residence address must be identified. If the residence address is listed as General Delivery, Rural Route, or Star Route, the flight attendant must provide written directions or a diagram locating the residence, attested by his/her signature. Flight attendants should mail requests to the address listed above. Incomplete information in a request could delay the issuance of a replacement certificate. A form that may be used in requesting a replacement certificate may be downloaded from the FAA’s public website at: http://registry.faa.gov/airmen.asp
(3) Address change: Notification to FAA not required. A flight attendant is not required to notify the FAA of an address change, but may do so voluntarily. Procedures apply as shown in (1) and (2), just above.
C. The FAA.
(1) FAA provides a user ID and password to the DO. When the FAA receives a valid request from a DO for access to the Flight Attendant Certification System, the FAA sends a confirmation message to the DO by e-mail containing a user ID and password for access.
(2) FAA awards a certificate of demonstrated proficiency. Concurrent with each record entered by the DO in the System (FAA notification) the FAA awards a certificate of demonstrated proficiency. Each certificate is effective immediately.
NOTE: Before December 1, 2004, the FAA Flight Attendant Certification System database accepted batch files as a courtesy to the airlines, and particularly to the DOs, to help them meet the start-up task of entering records for all their company’s flight attendants -- thousands in some cases. Most records (almost 100,000) have been entered as this bulletin goes to press. Since December 1 the FAA no longer accepts batch files. The DO must use the web-based system for entering flight attendant records.
Each airline’s DO registering with the Civil Aviation Registry receives a designator (user  ID), a password, a help file, and a link to the web site for entering flight attendant records. The help file provides contact information in case any problems arise while using the System. If questions arise concerning flight attendant information or system difficulties, the Registry may be reached toll free at 1-866-878-2498.
(3) FAA mails a certificate to the flight attendant. Within approximately 10 to 14 days of awarding a certificate, the FAA sends a wallet-sized hardcopy of that certificate by U.S. Postal Service to the respective flight attendant.
7. PRIVACY ACT. Under the Privacy Act, personal information is generally not available to the public. Certain personal information held by the FAA in each flight attendant’s certification record is not releasable to the public, such as address, physical description, date of birth, and place of birth. Only basic certification information of an identified individual is releasable to the public, such as certificate number, ratings (Group I, Group II), and date of issue.
NOTE: For holders of an airman’s certificate (pilots, air traffic controllers, and others – but not flight attendants) the Aviation Investment and Reform Act for the 21st Century (AIR-21) partially overrules the Privacy Act and requires the FAA to release certain information including address information, unless the airman specifically requests that address information be withheld. Consequently, a certificated flight attendant who also holds an airman’s certificate (as a pilot, for example) is subject to AIR-21, and possible releasability of address information. In such a case a flight attendant would have the opportunity to request that address information pertaining to the airman’s certificate be withheld from the public.
(http://registry.faa.gov/airmen.asp; click on Change Releasability Status of your Mailing Address )
8. ACTION. POIs or ASIs-cabin safety, if applicable, shall make the information in this bulletin known to the DO of each operator affected by the Act requiring flight attendants to hold a certificate. Inspectors should provide the DOs with a copy of this bulletin or refer them the FAA’s public website (http://www.faa.gov/avr/afs/fsat/fsatl.htm).
9. DISPOSITION. This bulletin will expire when Order 8400.10, Air Transportation Operations Inspector’s Handbook, has been updated to reflect this guidance. Questions concerning this bulletin should be directed to the Air Carrier Training Branch, AFS-210, at (202) 267-7480, or to the Civil Aviation Registry, AFS-700, at 866-878-2498 or 405-954-3822.
/s/ Thomas K. Toula, for
Matthew Schack
Manager, Air Transportation Division
Proud OOTSK member
corey07850
Fri Aug 11, 2006 10:06 am
Quoting EMBQA (Reply 10):
I'm not arguing that FA's endure the same amount of training that pilots and mechanics receive... The original poster asked if FA's are issued FAA certificates (the physical plastic card) similar to those that pilots receive, which they are...
135.349 outlines FA training, and Lowrider even provided the information that states FA's must have FAA issued certificates after 12/11/04
EMBQA
Fri Aug 11, 2006 10:27 am
Fair enough and I stand corrected...
If your read Section 2, it reads like government pork barrel politics and this was done to make F/A's feel more important.
lowrider
Fri Aug 11, 2006 10:33 am
Quoting EMBQA (Reply 13):
That I won't argue. As I see it, it makes it easier for the FAA to take away the jobs of Flight Attendants as well.
Proud OOTSK member
Fri Aug 11, 2006 4:36 pm
GROUPII
What are the Categories for.
regds
MEL
EMBQA
Fri Aug 11, 2006 7:23 pm
Quoting HAWK21M (Reply 15):
Section I is your name and address. Section II is the ratings.
greg3322
Fri Aug 11, 2006 9:09 pm
I did some poking around and I see that Group I is for Prop planes and Group II is for Turbojet.
GROUPII
regds
MEL
EMBQA
Sat Aug 12, 2006 5:11 am
Anyway.... Yea, kind of suprised our Gov't wasted time and money on this. Unlike Pilots, Mechanics and Dispatchers....Flight Attendents ARE NOT required to operate a Part 121 airline. They are not regulated under an FAR like pilots, mechanics and dispatchers are.
Sat Aug 12, 2006 9:18 pm
Quoting Greg3322 (Reply 17):
Interesting.So an FA has to be qualified on Type of Aircraft prior to working on it.I thought onlr Pilots & AMEs had to do that.
regds
MEL
corey07850
Sat Aug 12, 2006 11:09 pm
Quoting HAWK21M (Reply 19):
I believe the FAA group I and II refers to simply props or jets as another poster stated... However, the airlines require aircraft type specific training and must pass proficiency exams on that type of aircraft. The CO FA I know is currently a reserve FA so she has to be "current" in every aircraft in the CO fleet, even if she never flies on it.
Sun Aug 13, 2006 6:18 pm
Quoting Corey07850 (Reply 20):
Does this Involve Practicals & Theory or both with Tests.
regds
MEL
corey07850
Mon Aug 14, 2006 1:21 am
Quoting HAWK21M (Reply 21):
I'm not exactly sure on how much "theory" is involved... However it's basically a written, an oral, and a practical... The FA I know has her recurrent training coming up so I was looking through her materials for it. Basically she had a booklet of a few hundred possible questions they can ask ranging from medical stuff to FAR's. The practical makes sure they can do things such as operate emergency exit doors, and the oral is just simply being asked a bunch of random questions on each of the planes they fly.
Mon Aug 14, 2006 4:37 pm
Quoting Corey07850 (Reply 22):
Interesting.I always thought only Pilots & AMEs had to study  Smile
regds
MEL
EMBQA
Mon Aug 14, 2006 9:35 pm
Is the test conducted by an FAA Inspector like it is for pilots and mechanics..?
silentbob
Tue Aug 15, 2006 2:02 pm
Each airline is responsible for their own training but FAA inspectors will audit classes from time to time. We had an FAA observer in our class for a week.
Tue Aug 15, 2006 5:11 pm
Quoting Silentbob (Reply 25):
Welcome to Tech ops.  Smile
How frequent is this Audit Anually.
regds
MEL
silentbob
Wed Aug 16, 2006 5:25 am
Not sure on the frequency, but I believe it to be more frequent and not on any specified schedule.
Wed Aug 16, 2006 5:23 pm
Quoting Silentbob (Reply 27):
Would Twice Annually be close.
regds
MEL
ADXMatt
Mon Aug 21, 2006 6:54 pm
From what I understand is that the F/A certificate is for one airline only. If they separate from the airline it has to get turned in.
Not like a piot/dispatcher etc who can take their cert from one airline to another.
Tue Aug 22, 2006 3:49 pm
Quoting ADXMatt (Reply 29):
Looks like an Approval system.
regds
MEL
iairallie
Wed Aug 23, 2006 5:22 am
My cert. doesn't say anything about which airline I work for. I took it with me when I switched airlines. The certificate doesn't exempt you from airline specific training programs. You go throught initial training the same as anyone else.
As an FA I went through an FAA approved and regulated training program. We had hands on requirements, took FAA approved tests and after passing we were issued an FAA certificate. Sure it doesn't involve as much as the pilot training but there is no reason to be so nasty about it. I hope you work cargo so you aren't forced to co-mingle with us peons. Aren't ATP mechanics certified after going through FAA approved training programs etc.? I didn't realize I could walk in off the street and immediately just go to town on an aircraft engine with out any go ahead from the FAA.
The FAA requires so many hours of IOE experience on the aircraft type (prop/jet) before they issue the certificate. You also have to qualify on all the different types of aircraft the airline expects you to work on at your base. If you aren't qualified on the plane you can't work on it.
All of the above. Contrary to popular belief FA training contains very little service training. In one 7.5 week 6 day a week training program we spent all of 2 days on service training. Most of it was safety, security and aircraft specific training.
Quoting HAWK21M (Reply 23):
HA! Lots of little bits of memorization we have to do in order to pass the FAA tests at initial training and our annual recurrent training.
Enough about flying lets talk about me!
WNCrew
Wed Aug 23, 2006 11:54 am
Amen IAirAllie!!!!!
Many people are ignorant to the fact that we do anything else besides what they see us doing. While it may appear as if we're only serving drinks, meals, etc there's a lot more to our job that's unseen and it's frequently only when something terrible happens that we are truly recognized for how WELL trained we are and how good we are at what we do.
I'm used to not having any respect...I don't have to prove my intelligence to anyone. I just figure those who think I'm stupid are really the STUPID ones. I love what I do, I'm extremely good at it and if the need arises for my REAL training to kick in, I know I'll be able to react accordingly.
Wed Aug 23, 2006 1:38 pm
Quoting IAirAllie (Reply 31):
Quoting WNCrew (Reply 32):
Thats true.Most people thin that FAs are for Serving,not realising the Primary purpose is to cater to an Emergency Evacuation.
Nice to see a couple of FAs out here Folks.
regds
MEL
Users browsing this forum: DL777200LR, GalaxyFlyer, Starlionblue, StereoTechque and 1 guest
