AC320tech
747 JT9D Cascades
Sun Aug 13, 2006 11:25 am
In this picture you can see (what looks to be) reverser cascades at the top of the engine, just forward of the the reverser cowling.
Photo © Julio Ribeiro
Why are they up there?
n8076u
RE: 747 JT9D Cascades
Sun Aug 13, 2006 11:33 am
The reverse thrust fan exhaust does exit from where that upper vane section is located, so it is normal for the cascade vanes do go up that high.
Neat photo, brings back memories...
Chris
Don't blame me, I don't work here...
MarkC
Sun Aug 13, 2006 11:41 am
That is what they are. That is where they are. I see these on a daily basis. The other ones are removed in your picture. They go around the circumference of the Fan Exit Rear Case just like the one shown.
twal1011727
Mon Aug 14, 2006 12:57 am
That looks like a/an oil cooler or some type of heat exchanger.
KD
fr8mech
Mon Aug 14, 2006 12:19 pm
Quoting TWAL1011727 (Reply 3):
Nope, it's a cascade segment.
Mon Aug 14, 2006 4:32 pm
Are the Remaining Cascades Removed.
& Why so much Forward.Any reason.
Any pic of a Running JT9D in Reverse.
regds
MEL
AC320tech
Tue Aug 15, 2006 12:08 am
Quoting MarkC (Reply 2):
But if that is true, wouldent we be able to see the guide stop outlines on the cowling?
fr8mech
Tue Aug 15, 2006 1:45 am
Quoting AC320tech (Reply 6):
Guide stops? Not sure what you're asking here.
Here's a brief anatomy of what we're seeing:
-At the very top, fwd of the pylon is the thrust reverser air motor (just visible).
-Below that, as discussed is a cascade segment.
-The green ring the segment is attached to (fwd) is the translating ring. This ring moves fore and aft and is continuous from the top of the engine to the other side. If I had to guess, about 320 degrees.
-The cascade segment is attached, at its aft mount, to the translating sleeve. Housed in the sleeve, inner, out of our view, are the blocker doors and the operating links.
-Forward of the ring, are 2 of the TR gearboxes and their jackscrews. These are linked together, in series, with 2 more on the other side, by shafts (heavy cables) to the TR air motor.
I don't see any other TR component from this view. Incidently, the fixtue on the engine fan case about half way up, is the attach point for the engine change equipment.
n8076u
Tue Aug 15, 2006 11:37 am
fr8mech
Tue Aug 15, 2006 11:55 am
Quoting N8076U (Reply 8):
Oh my, the memories (and the pain) come flooding back!
Tue Aug 15, 2006 5:08 pm
Photo © Simon Ng
Fantastic view.
Quoting Fr8Mech (Reply 9):
What was the pain for.Was it a tough Engine Mx point of view to Maintan.
regds
MEL
fr8mech
Tue Aug 15, 2006 7:56 pm
Quoting HAWK21M (Reply 10):
Yes, the engine was (is) maintenance intensive. Chapter 75 is a bear on the -7A/AH's and only marginally better on the -7Q. The reverser is always locking up. The early engines leaked oil and the fuel leaks on the -7Q would clean off the oil. The core cowl could kill you if you're not careful.
Wed Aug 16, 2006 5:12 pm
Quoting Fr8Mech (Reply 11):
Was these ever cured by some SBs,or it always stayed that way.
regds
MEL
fr8mech
Wed Aug 16, 2006 7:27 pm
Minor improvments, but no real change. The engine doesn't really leak much oil, but the breather/cowl interface isn't the best and you always get a film of oil under the cowl. The engine uses a horrendous amount of oil compared to today's standards. I believe our limit is 1.25 qts/hour.
Wed Aug 16, 2006 8:53 pm
Photo © Vatche Mitilian
Photo © Nikolas Stassinopoulos
Photo © Lindsay Hockey
Have seen them on the old B742 of AI a lot.Is the Type used on the B742 different from the rest or just the Fairings differ.
regds
MEL
fr8mech
Thu Aug 17, 2006 11:49 am
The B747-2XX normally has -7Q engines (if PW equipped) though I know of at least one tail that had a set of -7J engines installed.
As for the fairings; I think there are a couple of -1XX that have the high speed fairings installed, I don't believe it's a -2XX installation only. I'll keep on eye on our birds as they cycle through to confirm.
Thu Aug 17, 2006 3:01 pm
Quoting Fr8Mech (Reply 15):
Whats the Difference -Q & -J
regds
MEL
fr8mech
Fri Aug 18, 2006 4:48 am
Other than max EGT being different, I don't recall anything else.
MarkC
Fri Aug 18, 2006 8:32 am
Quoting HAWK21M (Reply 16):
regds
MEL
The Q is very different.
The Q had the 5 stg LPC instead of 4, and also added an extra roller bearing on the LP shaft. The Q's are really a lot like the R4's.
Fri Aug 18, 2006 1:35 pm
Quoting MarkC (Reply 18):
Interesting.Thanks.
What were the Different variants on the 9Ds.
regds
MEL
MarkC
Sun Aug 20, 2006 3:09 am
Quoting HAWK21M (Reply 19):
The answer would take a while, and I would not be the one to give it completely, but here's what I do know.
The original was the 4 main brg, 4 stg. LPC -7A, H, AH, F, J and -20's. (-20 was DC-10) That's one family.
The -7Q's and -59A/-70's were the next development. These had 5 main brgs and a 5 stg. LPC. 59/70 had a fan mounted gearbox, and were for DC-10, A300, and a few 747.
The -7R4 was further updated. All the -7R4's differ upon the application, but the core is essentially the same, but not always.
The 4000's are so much more the common engine.
Sun Aug 20, 2006 11:03 am
Was checking out the P&W website & found this.
http://www.pratt-whitney.com/prod_comm_jt9d.asp
regds
MEL
Users browsing this forum: DL777200LR, HighBypass and 1 guest
