B752 - Aft Break Ring.
Fri Aug 18, 2006 8:28 pm
Is there any unit on the Structure aft of the Rear pressure Bulkhead of a B752 called the Aft Break Ring.If So any idea what its purpose is.Around STA 1862 approx.
Noticed this on a magazine some time ago.Could not find this in the AMM.
regds
MEL
KevinL1011
RE: B752 - Aft Break Ring.
Tue Aug 22, 2006 4:07 pm
Sounds like some kind of cabin over/under pressure safety device. Perhaps a "pop off" valve.
 scratchchin
Hopefully someone will post the answer.
474218, Carl, You will be missed.
777wt
Wed Aug 23, 2006 7:59 pm
Quoting KevinL1011 (Reply 1):
There's postive and negative relief valves for that.
Wed Aug 23, 2006 8:34 pm
Quoting 777WT (Reply 2):
These are not relief valves.The b752 has Two Negative relief valves on the RH side of the MEC area & Two Positive Pressure Valves on the LH Aft side near the Rear pressure bulkhead.
This is some structural part by the tone of the name I guess.
regds
MEL
Users browsing this forum: stratosphere, tom02, trevisan26 and 28 guests
