albydal
How Good Are Door Seals?
Fri Sep 01, 2006 3:29 am
I've always wondered how well an aircraft door actually seals off the cabin. I know that with most doors opening inwards, the pressurization of the plane actually makes the seal stronger. I was in an exit row of an AA MD-80 yesterday and noticed that when I pulled back on the rubber trim around the exit door a little bit I could hear a noticeable hissing sound. The trim then snapped back in place very quickly when I let go of it, as if there was very strong suction behind it. Stuff like this makes me wonder!
airfoilsguy
RE: How Good Are Door Seals?
Fri Sep 01, 2006 3:54 am
Quoting ALbyDAL (Thread starter):
People who screw with aircraft doors while in flight make me wounder. Lucky nobody saw you.
It's not a near miss it's a near hit!!
Fri Sep 01, 2006 4:25 am
The seal you pulled was not the main door seal.That is more Outboard.The seal you touched is a flappertype used to reduce noise.
regds
MEL
albydal
Fri Sep 01, 2006 5:50 am
Quoting Airfoilsguy (Reply 1):
As mentioned... it was part of the trim on the interior panel, NOT the actual door seal. Roughly akin to me fidgeting with a window shade.
Fri Sep 01, 2006 6:37 am
There is very little you can do to a typical airliner door at cruise altitude which would be dangerous to the aircraft. Otherwise they'd secure it somehow.
As for door seals, they are not perfect. You will get leakage of heat and air. Still, they are a good compromise of weight/complexity vs tightness. Think of it this way: even if a whole window popped out, the pressurization system could easily compensate. So a slightly leaking door seal is no biggie.
onetogo
Fri Sep 01, 2006 6:57 am
Quoting Starlionblue (Reply 4):
Is that right?
N231YE
Fri Sep 01, 2006 7:14 am
Not exactly. A door seal leaking, yes, but a missing window is too big of "leak:" the aircraft would rapidly depressurize. Besides condensation elimination, why do you think there is a plastic shield in front of the window?
David L
Fri Sep 01, 2006 7:36 am
While the aircraft made an emergency descent to 10,000 ft or so.  Smile
n8076u
Fri Sep 01, 2006 8:22 am
The noise or whistling that may occur from any leak in a cabin door is normally more of an issue than the small amount of air that leaks past, as the aircraft's pressurization system can more than compensate for that.
Keep in mind that the outflow valve(s) are always open to some degree, creating a controlled leak, so as to exhaust stale air and make room for fresh air. Air even goes down the sink drains, as they are open to to outside, through the drain masts.  Wink
Chris
Don't blame me, I don't work here...
Fri Sep 01, 2006 8:31 am
Quoting N231YE (Reply 6):
As David L is saying, the pressurization system can compensate fast enough for the plane to reach a safe altitude.
As N8076U is saying, the outflow valve(s) are making a controlled leak the whole time. Close those and there's room for quite a big unexpected leak.
Bjones
Fri Sep 01, 2006 8:57 am
A hole the size of a window would most definately result in a rapid decompression, at least on the aircraft size I am most familiar with (narrowbody jets). Perhaps in something the size of a 747 it would result in a slower decompression but I tend to think not much slower. The incidents I have heard of where a rapid D occurred have in most cases been the result of fairly small (significantly less than 1 sq ft) holes.
Fri Sep 01, 2006 9:01 am
I guess I stand corrected. But isn't the point of the pressurization system to keep the plane pressurized enough to reach a safe altitude in a reasonable time in case it springs a leak?
474218
Fri Sep 01, 2006 10:04 am
On the L-1011 a 5 square inch leak in the passenger or cargo door seals (cumulative over all the doors) would lead to an additional 68 pound fuel burn per hour, or $11,750 per year, in 1977 dollars. Door seals are very important.
Bjones
Fri Sep 01, 2006 10:23 am
No a pressurization system is to provide a safe and comfortable environment for humans at an altitude that is efficient for the aircraft and above most weather that would affect the flight. The oxygen masks are what are there to keep the passengers and crew safe and alive long enough to descend to a safe altitude for breathing without supplemental oxygen.
Fri Sep 01, 2006 4:22 pm
Not if you consider Both the Outer & Middle pane popping out.
regds
MEL
N231YE
Sat Sep 02, 2006 12:40 am
Quoting Starlionblue (Reply 11):
The pressurization system is a means of comfort to sustain life on board the aircraft, without any masks or suits. But should the system fail, that is why oxygen masks are provided above each seat, and usually, the pilots have about 12 minutes (depending on the aircraft) to bring it down to a safer altitude.
David L
Sat Sep 02, 2006 3:55 am
Quoting Bjones (Reply 10):
Of course, but...
Quoting Bjones (Reply 13):
I was under the impression that airliners had to be certified to "manage" a pressure loss caused by a window blowing out (possibly two) long enough for the crew and passengers to don their masks. Not at normal pressure levels, obviously, but also not at zero pressure differential. Otherwise, why would Concorde's windows have been so much smaller?
RichardPrice
Sat Sep 02, 2006 6:00 am
Quoting David L (Reply 16):
Concordes windows were indeed smaller so as to allow the pressurisation system to handle multiple blowouts and maintain a 'breathable' (not necesarily a comfortable) level while the aircraft descended from operational altitude, without requiring deployment of masks.
Users browsing this forum: BobPatterson, Exabot [Bot], sjones1975, Wraine and 1 guest
