EI787
What Is The 'Self Protection System'?
Wed Sep 06, 2006 12:50 am
Hi!
I was looking at this photo today:
Photo © Weimeng
In the caption, it says 'Notice the Self Protection System on his body'.
Can anyone tell me what exactly is the self protection system and where it is on this picture?
Thanks in advance,
EI787
futureualpilot
RE: What Is The 'Self Protection System'?
Wed Sep 06, 2006 1:21 am
I would imagine that it is there as an anti-missile defense system, i.e. drops flares or chaff or something like that, should anybody fire on the airplane.
Life is better when you surf.
Wed Sep 06, 2006 1:24 am
Photo © Ismael Jorda
Photo © Weimeng
Notice the Bulged fairings at the Left Aft.
Is this the Flares anti terror system.
regds
MEL
SlamClick
Wed Sep 06, 2006 1:40 am
Quoting HAWK21M (Reply 2):
No I don't.
Can you narrow it down using the actual names of airplane parts or landmarks in the picture?
EI787
Wed Sep 06, 2006 1:45 am
Is this what you're on about:
http://i3.tinypic.com/2mdl9jr.jpg
aeroweanie
Wed Sep 06, 2006 1:57 am
What you are looking at is the Elta Flight Guard system. It drops flares if a missile launch is detected.
2enginesonly
Wed Sep 06, 2006 3:14 am
There seems to be a strange bulge right below the apu exhaust as well.....part of the same system??
Arjan
onetogo
Wed Sep 06, 2006 3:15 am
Quoting AeroWeanie (Reply 5):
Impressive!
Wed Sep 06, 2006 6:24 am
I imagine some sort of evasive maneuvers are also in order once the threat indicator beeps.
Qantas744er
Wed Sep 06, 2006 6:31 am
Quoting 2enginesonly (Reply 6):
Correct, this is the Infra red that detects the missile, the bulged fairings on the aft are the part wich will release the flare etc. but the bump under the APU is only to detect the missiles.
Cheers Leo
You live and you die, by the FMA
kaddyuk
Wed Sep 06, 2006 6:49 am
Quoting Qantas744ER (Reply 9):
Looks like the strobe light to me...
aeroweanie
Wed Sep 06, 2006 7:41 am
Here are the competing American systems for airliner self-protection. Both work by detecting the missile launch and then firing a laser into the homing head to confuse the missile and force it to break lock.
This is the Northrop Grumman Guardian system, which is pod mounted:
This is the BAE Systems JetEye system, which has its boxes internally mounted:
Quoting Starlionblue (Reply 8):
With these systems, the pilot is not supposed to maneuver. Keeping the aircraft on a predictable flight path helps the system deal with the missile.
Wed Sep 06, 2006 12:48 pm
Impressive.Any Close views on the B767 fitted with this.
regds
MEL
Wed Sep 06, 2006 8:28 pm
Quoting AeroWeanie (Reply 11):
Good info. This is hardly typical of missile evasion but I imagine the expected threat is a rather low tech infrared AA missile so it makes sense.
Wed Sep 06, 2006 10:46 pm
Analog
Fri Sep 08, 2006 4:20 am
Quoting HAWK21M (Reply 14):
http://www.ifri.org/files/CFE/Flight...'Elta%20Flight%20Guard%20system'
Interesting link
regds
Note the 1/1000 false alarm rate claimed by the manufacturer. This is somewhat scary for a civilian flare-based system. 0.1% of flights is a lot more common than missile launches at airliners. Imagine if every airliner had this... lots of fireballs from the sky.
How does this system prevent setting buildings, brush, etc. on fire (flares @ low altitude = really bad, right?) and killing people in the process? Other systems use lasers, which would only blind people  Wink.
Fri Sep 08, 2006 4:52 am
Quoting Analog (Reply 15):
Presumably the possibility of a flare hitting a building or person is weighed against the advantage of not being hit by a missile. But you have a point.
lredlefsen
Fri Sep 08, 2006 12:13 pm
Holy shnikeys -- that would take a *lot* of faith in the system. "Inbound missile detected -- please fly straight and level."
It would make spotting so much more interesting, wouldn't it? In fact, if you could figure out how to trigger a false positive (given the 1/1000 rate, that doesn't seem too hard to pull off), it could make for some really cool photos...  Wink
aeroweanie
Fri Sep 08, 2006 1:12 pm
They are using a special flare that burns outside the visible spectrum and is gone well before it hits the ground. In fact, its not really even a flare, just wafers of a special material.
Analog
Sat Sep 09, 2006 1:07 am
Quoting AeroWeanie (Reply 18):
And if a MANPAD is launched when the AC is rotating? Are the wafers intelligent (timed)?
Clearly the wafers must emit IR (for IR homing missiles)... Why not visible, other than the fact that a visible flare would look bad if it were a false alarm? The probabilities say that virtually all flare launches would be false alarms for a civilian airliner, even for an airline like LY.
Users browsing this forum: adools, Baidu [Spider], sharles and 1 guest
