747400sp
Do KC-135 Land Flater And Lower Than 707's?
Thu Sep 14, 2006 5:44 am
I was just watching a KC-135E land on www.flightlevel350.com, and I notices that it had a very nose down landing for a jet. When I look at a 707 landing it nose seem to stand a little higher. I know that a KC-135 (717) and 707 are different aircraft, so is one of different is that a KC-135 lands almost nose down?
411A
RE: Do KC-135 Land Flater And Lower Than 707's?
Thu Sep 14, 2006 3:19 pm
KC135 types generally do not have full span leading edge devices as do the later B707 types, so yes, the pitch angle on approach may indeed appear a bit more 'nose down' than with the B707.
Spruit
Fri Sep 15, 2006 12:31 am
KC-135 is not a 717 derivative but a derivative of the Boeing 367-80 which is the proof of concept for the 707!
The 707 Derivative KC-135 are designated A Variants if i'm not mistaken?
Spru!
E=Mc2
avioniker
Fri Sep 15, 2006 2:45 am
More properly the aircraft built after 1959 were based on the 720
747400sp
Fri Sep 15, 2006 9:43 am
Quoting Spruit (Reply 2):
The KC-135 civilian name is 717. Yes, I know there's the DC-9 base 717, but Boeing just gave it the name since there was no civilian airliner in there line up with that name. Since the KC-135 was for military uses only, Boeing did have a civilian 717. To put a long story short the KC-135 was the original 717.
LeanOfPeak
Fri Sep 15, 2006 10:56 am
The 707 derivative KC-135's are designated KC-137.
Fri Sep 15, 2006 8:43 pm
As 747400sp points out, the KC-135 is Boeing Model number 717. Both the 707 and the 717 are derived from the 367-80. The 707 has a wider fuselage due to customer demand and competitive pressure (from the DC-8) to put in 3-3 seating instead of 2-3.
Spruit
Fri Sep 15, 2006 10:42 pm
Quoting 747400sp (Reply 4):
Thanks, I never knew that!  Smile
Spru!
E=Mc2
Sat Sep 16, 2006 3:08 am
Quoting Spruit (Reply 7):
If you're interested in Boeing history, "Boeing - Planemaker to the World" by Redding and Yenne is a good introduction. It's about 10 years so a bit dated, but it covers civil and military from the founding of the company.
http://www.amazon.com/Boeing-Planema...04-0861965-8185516?ie=UTF8&s=books
Users browsing this forum: Bing [Bot], CV990A and 1 guest
