AdamWright
Single Engine Procedures For Commuter Aircraft
Mon Sep 18, 2006 5:05 am
Hey Guys,
One of my projects for school is to dig up the single engine procedures for a small commuter aircraft such as the B1900 or CRJ-200, or Saab 340.
1. The scenerio is you're on the approach and you loose and engine and you MUST land. I'm needing the EXACT procedures (which google is giving me no love with) as to what the pilots would do step by step to get the bird on the ground safely.
2. In conjunction with that, what would the EXACT inflight RESTART procedures for that same aircraft?
I know alot of you guys are pilots with the regionals so hopefully you can help me out with those TWO questions.
Looking forward to hearing your responses!  Smile
-Adam
citationjet
RE: Single Engine Procedures For Commuter Aircraft
Mon Sep 18, 2006 11:20 am
Here is the Engine Failure During Approach procedure from the AFM of the new Citation Mustang, certified just last week:
Emergency Procedure:
1. Throttle (operating engine) Increase as required
2. Airspeed - Vapp
3. Flap Handle - Takeoff/Approach
4. Rudder Trim - Trim toward operating engine as required
5. Throttle (affected engine) Cutoff
6. Landing Gear - Down and locked
7. Landing Distance - Multiply by 1.28 if landing at Flaps Takeoff / Approach
8. Flap Handle - Takeoff/Approach
9. Autopilot and Yaw Damper - Off
10. Airspeed - Vapp (Vref if using Flaps Land)
Procedure completed.
A single engine restart is an Abnormal procedure, rather than an emergency procedure.
Inflight restart - one engine:
1. Throttle (affected side) - Cutoff
2. Fuel transfer Knob - Off
3. Engine Anti-Ice (affected side) OFF
4. Engine Fire Switch - Check Open
5. Air Cond Switch - Off
6. Air Source Select Switch - Opposite Running Engine
Assuming Starter Assist:
7. Gen Switch (affected side) Green
8. Fuel Boost Switch (affected side) Norm
9. Engine Start Buitton (affected side) - Press momentarily
10. Throttle (affected side) IDLE
11. Engine Instruments - Monitor
12. Engine Start Switch - Light extinguished
13. Engine Instruments - Check Normal
Assuming engine starts:
14. Engine Anti-Ice and Air Cond - As required
15. Air Source Select Switch - Both
There is another single engine restart procedure for windmilling airstart that starts at step 7 above.
A dual engine restart procedure is a separate, emergency procedure.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
411A
Mon Sep 18, 2006 11:54 am
Normally, with an engine failure during the approach, the engine is secured, and the approach and landing is accomplished with the engine shut down.
During an instrument approach, with the types mentioned, the priority is to complete the approach and land safely, not try an engine restart close to the airport.
2H4
Mon Sep 18, 2006 11:59 am
Quoting AdamWright (Thread starter):
For the Jetstream 4100:
Photo © Mike Primamore
Engine Failure or In-Flight Shut Down
FOR AFFECTED ENGINE:
-POWER LEVER - FLIGHT IDLE
-CONDITION LEVER - FEATHER/SHUT OFF
-CONFIRM LP VALVE CAPTION INDICATE SHUT
IF LP VALVE CAPTIONS DO NOT INDICATE SHUT:
-FUEL AND HYDRAULIC LP VALVE SWITCHES - SHUT
NOTE: PROPELLER MAY STILL ROTATE SLOWLY.
-FLOW SELECTOR - OFF
-PROPELLER ICE PROTECTION SWITCH - OFF
-ENG ELEV ICE PROTECTION SWITCH - OFF
-GEN SWITCH - OFF
GENERAL
-PROP SYNCHRO SWITCH - OFF
-STBY PUMP AND X FEED SWITCHES - AS REQUIRED
Assuming a visual single-engine approach:
- Select flaps 9* abeam the upwind end of the runway and maintain 160 kt by setting approx 55% torque
- Before descending on the base leg, select the landing gear down, check 3 greens and select flaps 15*
- Call for the landing checklist
- Select flaps 25* halfway round the final turn, reducing speed to a minimum of Vref + 10 kt at 200 ft above runway elevation
NOTE
- During training, the training captain may simulate engine failure by setting 10% torque which simulates zero thrust condition.
- Speed must be maintained at a minimum of V2
Manual In-Flight Start
THE BEST CONDITIONS FOR A RELIGHT ARE BETWEEN 110 TO 200 KT IAS AND LOWER THAN 20,000 FT. RELIGHTS MAY BE ATTEMPTED OUTSIDE THIS ENVELOPE.
-EGT - LESS THAN 200*C
-CONDITION LEVER - FLIGHT
-FUEL AND HYD LP VALVE SWITCHES - OPEN
CONFIRM CORRECT INDICATIONS
-STBY PUMP SWITCH - ON
-IGNITION SWITCH - NORMAL
-GEN SWITCH - OFF
-IEC COMPUTER SWITCH - OFF
-MANUAL START SWITCH - ENERGIZE
-START SWITCH - PRESS
IF PROPELLER DOES NOT START TO ROTATE:
-UNFEATHER SWITCH - OPERATE
UNTIL PROPELLER ROTATION STARTS
AT 10% RPM:
-MANUAL START SWITCH - IGNITE
-FUEL ENRICH SWITCH - AS REQUIRED
IF PROPELLER WAS ALREADY ROTATING UNDER NTS:
-FUEL ENRICH SWITCH - PRESS ON
AT 55% RPM:
-MANUAL START SWITCH - 60%
[START] INDICATOR LIGHT OFF
IF ENGINE ACCELERATES NORMALLY TO FLIGHT RANGE RPM:
-MANUAL START SWITCH - NORMAL
-IEC COMPUTER SWITCH - AS REQUIRED
-TTL COMPUTER SWITCH - AS REQUIRED
-GEN VOLTS - CHECK 27.5 TO 29.0 V
-GEN SWITCH - ON
-FLOW SELECTOR - AS REQUIRED
-ENG/ELEV ICE PROTECTION SWITCH - AS REQUIRED
-PROPELLER ICE PROTECTION SWITCH - AS REQUIRED
-STBY PUMP SWITCH - OFF
WHEN OIL TEMPERATURE EXCEEDS 55*C:
-POWER LEVER - AS REQUIRED
-CONDITION LEVER - AS REQUIRED
-PROP SYNCRO SWITCH - AS REQUIRED
IF ENGINE DOES NOT ACCELERATE NORMALLY TO FLIGHT RANGE RPM:
-CONDITION LEVER - FEATHER SHUT OFF
NOTE: WAIT 1 MINUTE BEFORE ATTEMPTING ANOTHER START.
Hope that helps....
2H4
Intentionally Left Blank
EssentialPowr
Mon Sep 18, 2006 12:02 pm
loose
"lose", not loose (even today after we have watered SATs down terribly, grammar still counts)
There are no "exact procedures"...there are checklists and QRH procedures, but an engine loss is an emergency, and each one is different, as each scenario is different...The amount of parameters involved is limitless; that , imo, should be the focus of your paper.
If the engine loss occurs at FL240, a restart will probably be attempted. An engine loss at V1, probably not.
[Edited 2006-09-18 05:03:29]
[Edited 2006-09-18 05:05:21]
Woodreau
Tue Sep 19, 2006 4:19 am
Even with an engine shutdown, you are still trying to keep everything as "normal" as you can and land as you would land with two engines.
There's more than just the engine shutdown checklist, it's really a series of checklists that are run in the same order - (1) fly the plane, (2) deal with the situation and run the appropriate emergency/abormal checklist, (3) in range/descent checklist, (4) approach checklist, (5) single engine approach and landing checklist, (6) single engine go around checklist. At least that's the way they try to keep it when you're training in the simulator.
Then there's things that aren't in the checklist - communication with ATC and the rest of your flight crew (flight attendant) and obvious things like rudder trim to counter act the loss of the engine and when you reduce the power on your operating engine to land, all that trim is going to start yawing your aircraft in the other direction so you have to be ready to counteract that, but that's not in any checklist anywere.
If you're just collecting checklists:
BE1900
Engine Fire or Failure Inflight:
Condition Lever (Affected Engine) - Fuel Cutoff
Propeller Lever (Affected Engine) - Feather
Firewall Fuel Valve (Affected Engine) - Pull Closed
Fire Extinguisher (Affected Engine) if required - Actuate
Dash 8
Engine Failure / Shutdown (Inflight):
Power Lever (Affected Engine) - Flight Idle
Condition Lever (Affected Engine) - Fuel Off
Alternate Feather (if required) - Feather
Pull Fuel Off Handle (Affected Engine) - Pull
Tank AUX Pump (Affected Engine) - Off
CRJ 200
Inflight Engine Failure / Shutdown
Accomplish only when flight conditions permit:
Affected Thrust Lever - Confirm and Idle
Affected Thrust Lever - Confirm and Shutoff
14st Stage ISOL Valve - Select OPEN
ERJ 145
Engine Out (EICAS Caution: ENG 1(2) OUT)
If inflight:
Precautionary Engine Shutdown / Engine Failure Procedure - Accomplish
Precautionary Engine Shutdown/Engine Failure Procedure:
APU - Start
APU Generator - On
Associated Start/Stop Selector - Confirm and Stop
If engine shutdown does not occur, Fire Extinguisher Handle - Confirm and Pull (Do not rotate)
Remaining Engine Thrust Rating - CON
B737-300
Engine Failure and Shutdown
Autothrottle - Disengage
Affected Thrust Lever - Confirm and Close
Affected Start Lever - Confirm and Cutoff
APU (if available) - On
Affected PACK - Off
A319/320
ECAM Message: ENG 1(2) FAIL
ENG MODE SEL - IGN
Affected Thrust Lever - Idle
If engine does not relight, Affected ENG MASTER - OFF
ThrottleHold
Wed Sep 20, 2006 8:04 am
Quoting Woodreau (Reply 5):
A319/320
ENG MODE SEL - IGN
The glory of Airbus....no messing about with loads of levers and switches!
corey07850
Wed Sep 20, 2006 8:41 am
Adam looks like you've got some good responses here.... What class is this for? 411?
and when are you coming up to photograph TEB????
Users browsing this forum: 71Zulu, sharles, snowmann and 2 guests
