ual757
767/DC-10 Doors
Thu Sep 28, 2006 1:31 pm
This is my first post so here I go:
Do 767/Dc10 doors open into the ceiling of the plane?? It has been a few years since my last 767 flight. I have seen pictures of the planes at the gates, the doors are open, but I see no door! If they do open into the ceiling, how do you open them from the outside. If anybody knows of any pictures showing the door(s) open from the cabin, please post them!  Smile
I am unfamiliar with the search, so if this has been discussed before, please suggest deletion!
FlyDeltaJets87
RE: 767/DC-10 Doors
Thu Sep 28, 2006 1:58 pm
I know the second boarding door on the 767-400 does. Not sure if all the doors on the 764 do this. I was in the second row behind the boarding door coming back from Hawaii on a DL 764, and thought the door going up into fuselage was pretty cool.
Someone could correct me if I'm wrong, but I think the L1011 had doors like this to.
"Let's Roll"- Todd Beamer, United Airlines Flight 93, Sept. 11, 2001
zippyjet
RE: 767/DC-10 Doors
Thu Sep 28, 2006 2:02 pm
Welcome to A Net! This may have been touched on but, I an notgoing to suggest deletion! I don't think 767s had the retacting doors. The power door that dissappeared into the fusilodge was all the rage with the DC-10, MD 11 and L-1011. Coincidentially, when these birds were designed GM incorporated the "clamshell" tailgate design in their behemouth station wagons (1971-1976 models). Interestingly, the sliding doors have faded away with disco in both the airliner and automotive industrys.
I'm Zippyjet & I approve of this message!
ual757
RE: 767/DC-10 Doors
Thu Sep 28, 2006 2:10 pm
Thanks for replying so fast!  wave
jetmech
RE: 767/DC-10 Doors
Thu Sep 28, 2006 2:15 pm
Welcome to A.net UAL 757! The doors on the 762 and 763 opened by firstly moving laterally into the fuselage, and then sliding up into the roof. A large handle to the side of the door (both on the inside and outside) was used to initiate the opening and complete the closing of the door. IIRC, to open the door, you pulled either the external or internal handle up which performed the initial lateral movement of the door into the fuselage, the door was then manually or electrically powered up into the roof. The reverse procedure was used to close the door. A large counter-balancing mechanism was used to balance the weight of the door and make it easier to move up and down into the roof. You had to be real careful not to open the door if you were doing a slide-raft change for two reasons. Firstly, if you opened the door without the weight of the slide-raft assembly, the counter-balancing mechanism would slam the door up into the roof. Secondly, it took lots of force and strength to bring the door back down so you could refit the slide-raft assembly.
[Edited 2006-09-28 07:19:31]
In the interior, the slide-raft assembly was disarmed with a separate, smaller lever to the opening / closing handle.
Photo © Mark H
On the exterior, the slide-raft was disarmed in a slightly different manner. You pushed you fingers into the small red panel which moved in and disarmed the slide. The inward movement of this small red panel simultaneously allowed you to grab the bottom of the opening / closing handle to open the door.
[Edited 2006-09-28 07:27:33]
[Edited 2006-09-28 07:28:02]
FlyDeltaJets87
RE: 767/DC-10 Doors
Thu Sep 28, 2006 2:18 pm
Quoting Zippyjet (Reply 2):
Is my memory failing me? I could have sworn the 767-400 had the retracting door.  Confused
RyanAFAMSP
RE: 767/DC-10 Doors
Thu Sep 28, 2006 2:47 pm
While I flew as a flight attendant for United, I was always uncomfortable with the 767 and DC-10 doors - especially the DC-10. DC-10 doors required two people for opening in the event of a power assist failure. On the 767, you could do it with one person, but you would have to be extremely strong. Of course in both cases, if the door was armed and you pullled the main opening handle in an emergency, the power assist bottles would propel the door into the ceiling and deploy the slide. But my fear was always that in more excessive emergencies, the power assist mechanisms would fail, and the fuselage would bend - making it impossible for the doors to smoothly retract into the ceiling.
This is why the ultra-simple, old-school 747 plug doors made so much sense to me. Though they also had power assist bottles to blow the doors open in an emergency, you weren't fighting gravity in the event that the accident.
SR100
RE: 767/DC-10 Doors
Thu Sep 28, 2006 5:47 pm
Quoting FlyDeltaJets87 (Reply 1):
Yes, you are right. The other jets that had these kind of doors were the Caravelle with the main passenger door only and the Trident 2 and 3. These door were opened manually only, there was no electrical support.
And Boeing is a good example for introducing different door opening mechanisms.
First the well known mechanism used on the B-707, B-720, B-727, B-737, B-747 and B-757, which is simple, but according the size of the door and its location sometimes very heavy to open.
Second, after the introduction of the up sliding doors on the DC-10 and L-1011, they went for the same mechanism on the B-767.
Third, after the success of Airbus with the out-ward sliding door mechanism on all their airbuses, they went for the same with the B-777 and I assume also with the B-787.
My favourite planes flown: Lockheed 188 Electra, Vickers Viscount, Trident, VC-10, B-707, L-1011, A330/340, E90 + Concorde
jetmech
RE: 767/DC-10 Doors
Thu Sep 28, 2006 6:11 pm
Quoting RyanAFAMSP (Reply 6):
Erm.... I was never a Flight Attendant, so I can't speak about day to day operations with respect to aircraft doors, but IIRC, the weight of the 767 door and slide-raft assembly was pretty much completely balanced by the counter-balance mechanism. The electric and emergency assist was certainly nice to have, but manual operations were certainly within the strength capabilities of most people. The prevention of door operations due to a bent fuselage could also prevent a 747 type door opening. If we were fuelling a 744 for a trans-pacific flight, which took about 170 tonnes of fuel, we always made sure that doors 3 left and 3 right (overwing exits) were shut, as the loads and strains on the fuselage due to the weight of fuel in the wings was often enough to prevent these doors from closing if left open. I think the relative complexities of the door mechanisms were similar.
57AZ
RE: 767/DC-10 Doors
Thu Sep 28, 2006 7:33 pm
Don't forget that the Lockheed Constellations had sliding doors too. Unlike the "up and over" design of the DC-10/11, Tristar and Boeings they pulled in and slid to the side!
"When a man runs on railroads over half of his lifetime he is fit for nothing else-and at times he don't know that."
SR100
RE: 767/DC-10 Doors
Thu Sep 28, 2006 7:52 pm
Quoting 57AZ (Reply 9):
And door L1 on the Super Constellation was the outward sliding door, like the Viscount 800, the Vanguard, the VC-10 and BAC-1-11. Not to forget the Tu-154.
And the Lockheed Electra 188 had the up sliding, electrical powered passenger doors. I think that it was the first passenger aircraft to have this feature.
But the trouble with this feature on narrowbody aircrafts was, that the opened door took some space from the ceiling. Those of you who flew the Caravelle will remember, that the flight attendants always had to put a kind of cushion onto the open door frame to protect the passenger's head... On this French jet, the door could only have a given size, because on the opposite side of L1, there was the galley door, therefore it had this limited height. This was not the case with the Electra, because there were no doors on the opposite side of the two passenger doors.
Dougloid
RE: 767/DC-10 Doors
Thu Sep 28, 2006 11:01 pm
Here's something I can actually say something worthwhile about because I was certified to rig and inspect passenger and cargo doors at McDonnell Douglas. It kept me off the ramp on colder autumn nights LOL. The MD11 door rides on tracks. It translates inward when unlocked and is lifted into the overhead by an electric motor that operates a windlass arrangement. The emergency function is provided by a pair of nitrogen bottles operating an air motor. When doing a timed test we'd blow the door and it*was*going*open* in no uncertain terms. Occasionally someone would open the door without disabling the slide and there'd be a small problem that rapidly got to be a big problem.
The advantage is that the door is free to float in the opening. Manually locked doors with pins could be problematic in the event of major structural deformation. The disadvantage is, as your colleague points out, they are heavy mothers to lift because there's no counterbalance.
The biggest problem we had was when the people putting the interior fixtures in left screws halfway out and they'd scrag the surface of the door when it went into the overhead. A lot of plasma welding went into fixing those defects, and the color of the applied metal was darker than the parent metal.
Tod
RE: 767/DC-10 Doors
Fri Sep 29, 2006 2:10 am
Looking aft at a 763 door 1R fully retracted into ceiling area:
Big version: Width: 480 Height: 573 File size: 134kb
Looking up / aft at a 763 door 1L counterbalance unit:
Big version: Width: 640 Height: 480 File size: 140kb
Tod
Tristarsteve
RE: 767/DC-10 Doors
Fri Sep 29, 2006 3:32 am
I must admit that as an engineer I have never been a fan of up and over doors. Its that big spring that worries me. If you have ever seen a Tristar door go up on the spring without the escape slide then you know why. The spring looks so inoccuous sitting there, like a gallon can, but the power inside it is tremendous. When you are working on the doors you have to check very carefully and make sure you don't disconnect the wrong bolts!.
Had you noticed that on the Tristar the L1 and R1 doors are not opposite each other? This is to allow room for the doors to open, as they overlap because of the fuselage curve.
The B757 doors are nearly as bad, they are so heavy to open and close, and the L1 door on the B737 is a disgrace. How can Boeing still produce this unpowered heavy door on a new aircraft. ( I know its called grandfather rights).
But now we have the Airbus doors and the B777. Lets hope we stay with this design. Light and easy to open and close in all modes, without the need for power assist.
Dougloid
RE: 767/DC-10 Doors
Fri Sep 29, 2006 5:12 am
I remember reading somewhere that Airbus was ordering big assed capacitors to store a charge that'll be enough to open the A380 doors in an emergency...that's going to be one big honkin' set of capacitors.
SFOMB67
RE: 767/DC-10 Doors
Fri Sep 29, 2006 12:00 pm
Concerning the 767 doors. I was involved with them for about 8 years in C-Cks, and we never had any problems with the doors on the 762 or 763. But if someone did have trouble, like say a broken cable to the counterweight, you had a problem because they were so trouble free, that nobody had experience working them. Now, the 737 doors on the other hand, had lots of experienced mechanics available, because they were always worked on at C-Cks.
FlyingColours
RE: 767/DC-10 Doors
Sun Oct 01, 2006 8:01 am
Quoting TristarSteve (Reply 13):
I didn't think the 737 L1 door was that bad, to be honest I used to think it was the easiest of the lot to operate on the grounds of it was the one door that would always be used. 1R & 2R were the real headaches. IMO the 737 doors in general were not too bad (esp since I'm stuck with the 757 now).
The 757 door is awful, the amount of times people have hurt themselves with them. I came very close to throwing my back out by operating one once (by the regs - which are now under review since then). At least they have power assist for emergencies but should they fail then 1 person alone can't open the exit. At least doors 3L/R are good in an emergency, just lift the handle up and push the door out and she falls like a drawbridge.
The Airbus Doors are nice, the only worry with them is that we've left them in the wrong mode or there's a pressure issue. Are they the same design on the A300/310 as they are on the A32X/330/340?
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
474218
RE: 767/DC-10 Doors
Sun Oct 01, 2006 8:59 am
Quoting Dougloid (Reply 11):
That is not one spring, inside the counterbalance there are seven (7) titanium springs, five (5) on the small type 1 door counterbalances. When removed from the housing these springs are six feet long when they are removed from the unit. The entire package is a small package of energy. I referred to them as "mechanical bombs".
In an emergency the counterbalance would fully open an L-1011 passenger door and deploy the slide, in less than 4.5 seconds.
Dougloid
RE: 767/DC-10 Doors
Mon Oct 02, 2006 5:50 am
Quoting 474218 (Reply 17):
Don't know how I got in there, that seemed to be Tristar Steve but what you're describing sounds like the old sprung hubs on Triumph motorcycles.
I take it from your description that the door closes down against spring pressure and it's normal place would be in the up position. The MD11's quite different. One bird that sounds like what you describe is the HS125/DH125 series, at least the older ones I'm familiar with they had the cabin door counterbalanced with some kind of spring arrangement so that it was pretty easy to slide open *up and in* once you popped the latch.
Tristarsteve
RE: 767/DC-10 Doors
Mon Oct 02, 2006 6:29 am
Quoting Dougloid (Reply 18):
Yes that sounds like the Dh Trident or the B767.
But on the L1011 it was a much stronger spring. With no electrical power, if you pulled the open handle down (in manual) the door still slid up into the ceiling quite fast, even with the slide attached. When you closed the door you usually used an electric motor(except on 4L/R which didn't have one) and this compressed the spring as it closed. Without power there was a manual drive socket. But it was very hard work to close the door manually!!
WNCrew
RE: 767/DC-10 Doors
Mon Oct 02, 2006 10:55 am
I've operated doors on the 757, 737, and MD-80. I find the 737 the hardest to open, especially the 1R door due to the curvature of the fuselage....ever HARDER to close! When you open the door with the weight of an armed evac slide it's even worse.
Both back doors of the 737 are easy though.....they're seated well and not at an odd curvature point on the fuselage. I wonder if Boeing didn't just leave the doors as they are b/c they have a simplistic design. The slides are easily accessed, no recessed arming/disarming mechanism, no power assist....easy to fix if broken.
Dougloid
RE: 767/DC-10 Doors
Mon Oct 02, 2006 12:16 pm
Quoting WNCrew (Reply 20):
The MD11 used a 'girt bar' in the doorway. When the slide was armed the door would go up but the girt bar stayed in place and out came the slide. It was possible to pop the slide inside the cabin and there were a couple incidents of it happening while the mechs were working on the doors.
WNCrew
RE: 767/DC-10 Doors
Mon Oct 02, 2006 12:50 pm
Quoting Dougloid (Reply 21):
Did you actually touch the girt bar when arming/disarming the door? That's interesting as I didn't realize any aircraft of that size operated that way. I know the 707-717-727-737-MD80-(etc) operated that way.
jetmech
RE: 767/DC-10 Doors
Mon Oct 02, 2006 2:21 pm
Quoting WNCrew (Reply 22):
I don't remember with the 767, but with the 747, you don't actually touch the girt bar when arming/disarming. With the 747 door closed, moving the arm lever to "arm" mechanically "flicks" a pair of fittings that slide on the girt bar. This simultaneously disconnects the girt bar from the lower hinged flapper door and connects it to fittings on the door opening sill. This is done via a set of mechanical linkages.
When you move the lever to "disarm", you again mechanically "flick" the pair of fittings that slide on the girt bar. This "flick" simultaneously releases the girt bar from the door opening sill fittings, and then connects the girt bar mechanically to the bottom hinged door flapper. Moving the door opening handle retracts the upper and lower door flappers which lifts the girt bar out of the way.
This design was actually reasonably safe when opening from the 747 door from the outside. What you did was crack the external handle just enough so that the upper and lower flappers retracted. You then looked under the lower flapper to see if the girt bar was connected to the door sill fittings. If it was, you re-shut the door and got someone inside the aircraft to disarm the slide. If the girt bar was not visible, you were safe to continue with opening the door. IIRC, there is no external slide disarm mechanism on the 747.
[Edited 2006-10-02 07:24:52]
[Edited 2006-10-02 07:26:01]
[Edited 2006-10-02 07:26:51]
Markhkg
RE: 767/DC-10 Doors
Mon Oct 02, 2006 4:37 pm
Does anyone know what ARFF will do if they see the girt bar still attached when they are opening the door from the outside (i.e. on a B-737 or MD80 aircraft)? Will they take out a knife and cut the slide attachment to prevent it from seperating from the door bustle?
WNCrew
RE: 767/DC-10 Doors
Mon Oct 02, 2006 10:24 pm
IIRC from training they said they were trained to open the door from the FWD side so the slide could still inflate.
Also: My point above was that perhaps given the complexities of arming/disarming assemblies on larger planes (hidden arming/disarming lifts, catches etc) Boeing kept it simple by simply having the FA place and remove the Girt Bar by hand. This is very simplistic and provides less chance of things to break since really you'r eonly dealing with the Girt Bar itself.
It's sort of like the Power Windows VS Manual Windows in your car. One is much more convenient....however it's also much easier to fix if broken given there are less complexities.
[Edited 2006-10-02 15:31:19]
Tristarsteve
RE: 767/DC-10 Doors
Mon Oct 02, 2006 11:55 pm
Quoting JetMech (Reply 23):
If you open a B747 door from the outside, the door is automatically disarmed. In fact a lot of airlines use this as a standard practice to stop inadvertant slide blowing. It is the same on B757 B767 B777 A320 L1011 to name a few. I expect it is standard on all doors where you move a lever to disarm the girt bar. It is there for the emergency case. If the aircraft has crashed, you dont want the slide blowing into the faces of the firemen as they open the door from the outside.
Dougloid
RE: 767/DC-10 Doors
Tue Oct 03, 2006 12:49 am
As I recall there was a claw that came out and retained the girt bar in the floor when you armed the slide with the "Jesus handle" as some folks called it.
Markhkg
RE: 767/DC-10 Doors
Tue Oct 03, 2006 5:44 am
Quoting WNCrew (Reply 25):
Interestingly, there have been numerous cases aboard B-737 aircraft where the cabin crew was unable to open the door fully, since the doors are not equipped with a power assist. The addition of attaching the girt bar to the floor can increase the weight needed to push open the door quite a bit, and cabin crew can be mentally unprepared for this difference since most simulators/trainers don't incorperate the weight difference.
WNCrew
RE: 767/DC-10 Doors
Tue Oct 03, 2006 5:51 am
Quoting MarkHKG (Reply 28):
At WN they do account for it in initial training.
Markhkg
RE: 767/DC-10 Doors
Tue Oct 03, 2006 6:11 am
Cool...so do they tell you that there will be a difference, or does the door actually change weight?
I know that FR has opted to actually buy a new cabin simulator because of previous training issues.
WNCrew
RE: 767/DC-10 Doors
Tue Oct 03, 2006 7:02 am
They have this weighted thing that attaches underneath the slide bustle so that when the door is opened you feel the extra resistence. Now I've never opened an "actual" armed 737 door so I don't know how realistic our trianing really is, but I could definately feel a difference when opening the cabin trainer door in armed vs disarmed mode and I ALWAYS remind myself on takeoff (especially if I'm sitting 1L position) that it's gonna take a lot of grunt to open the door.
jetmech
RE: 767/DC-10 Doors
Wed Oct 04, 2006 2:48 pm
Quoting TristarSteve (Reply 26):
G'day TristarSteve  Smile. I just remember always checking under the lower flapper door when we opened a B747 door from the outside. I guess this must have been an extra precaution to ensure the slide had disarmed. Is the slide disarmed from the outside when you pull the extrnal butterfly handles outwards?
Markhkg
RE: 767/DC-10 Doors
Wed Oct 04, 2006 5:40 pm
Quoting JetMech (Reply 32):
The B-747 door is automatically disarmed when the Handle Release Button is pushed inwards...I think...
http://www.boeing.com/commercial/airports/arff/arff747.pdf
jetmech
RE: 767/DC-10 Doors
Wed Oct 04, 2006 6:01 pm
Quoting MarkHKG (Reply 33):
No worries MarkHKG. It appears that some sort of mechanism disarms the slide if the door is opened from the outside. It seems obvious to me now that there should be some sort of external slide disarm mechanism on the 747. I just remember that it was drilled into us to always check for the girt bar, so I assumed that there was no external disarm mechanism.
Markhkg
RE: 767/DC-10 Doors
Wed Oct 04, 2006 6:37 pm
Okay, yup, I was wrong and JetMech, you're right. I found my old school 1972 main entry door brochure, and this is what it says to open the door from the outside
1) Push inward on latch to release the door handles.
2) Pull the handles outwards to hully extended poisiton. This deactivates the door's emergency system.
3) Rotate the handles 90 degrees as shown in the top photo and check the lower edge of the door to assure that the evacuation slide girt bar has disengaged from the floor fitting.
Otherwise, you get a face full of slide!!! (OR WORSE!)
YYCSpotter
RE: 767/DC-10 Doors
Sun Apr 21, 2013 5:32 pm
I
pvjin
RE: 767/DC-10 Doors
Sun Apr 21, 2013 6:50 pm
Quoting YYCSpotter (Reply 36):
I think in 7 years original poster has probably figured things out pretty well, thanks linking this informative video though.
[Edited 2013-04-21 11:50:53]
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that." - Martin Luther King Jr
Viscount724
RE: 767/DC-10 Doors
Mon Apr 22, 2013 1:10 am
How do people even find 7-year-old threads?
Users browsing this forum: hyd09l27r and 2 guests
