symphonik
A320 Questions Of The Day
Mon Oct 02, 2006 5:29 am
Hi all,
I just flew US (well, HP) for the first time (SJC->PHX) and on one of their A320's. I have a couple of questions about the bird itself.
1.) On both flights in and out, as the plane pulled away from the gate and throughout the taxi, then for a number of seconds after takeoff, I heard noises from the belly of the beast. It wasn't a continuous sound, rather like someone was down there with a power ratchet, going from bolt to bolt and tightening them. It was fairly constant, maybe one squeak every half-second, then gradually slowed down and faded in volume. It's really hard to type out what it sounded like. What sort of mechanical activity is going on during these portions of the taxi and takeoff?
2.) Some of the windows on the plane had little black triangles over them. They didn't seem to correspond to the location of oxygen canisters/lights/etc in the overhead bins or to exit rows (I was in the row 10 exit and I saw one maybe one or two rows ahead of me). What do these symbols mark?
Thanks for satisfying my curiousity.  Smile No complaints about the flight or the crew, everyone was very professional and there were no major hitches (though my PHX->SJC leg was delayed a bit -- the APU was offline and they had to pump air in to get the engine started up). Still, based off that experience I wouldn't have any problem flying US/HP again. The plastic cups for drinks onboard were bigger than what UA gives you.  Silly
Leskova
RE: A320 Questions Of The Day
Mon Oct 02, 2006 5:36 am
I think you'll find answers to your questions in this thread:
RE: A320 Sound (by DBOBA Aug 1 2001 in Tech Ops)
Smile - it confuses people!
symphonik
Mon Oct 02, 2006 6:17 am
Bah! I even did a search, but for "noise".  Sad
Thanks, Leskova!
Anyone about the triangles over the windows?
nzblue
Mon Oct 02, 2006 6:31 am
Quoting Symphonik (Reply 2):
The two black triangles correspond to the location inside the cabin where the wings meet the fuselage. The area between these two points marks the overwing portion of the cabin space. One triange is placed where the front of the wing meets the fuselage, and the other is placed where the back of the wing meets the fuselage.
[Edited 2006-10-01 23:37:22]
It's an entirely different kind of flying; all together.
symphonik
Very cool.
Well, that was an easy thread.
Thanks, Leskova and NZblue.
jc2354
Mon Oct 02, 2006 6:49 am
Hey Symphonic!
Yes, the sounds you heard was (basically) the hydraulic systems going through a self-test phase. If you hear it, it's a "good thing". The sound is much more noticeable on the earlier models.
You might also be onboard when they have to do a "system reset" while parked at the gate. Imagine rebooting your computer. Takes about 10-15 minutes to go through every system on the airplane , and you'll hear every noise, ding, warning, every light will go off and on, even the toilets will flush. The flight attendants can also do a cabin only system reset.
As for the black triangles, I believe they are above the windows at row 9 or 10. These window locations indicate the most optimum viewing of the wing and engine areas. Especially during or after de-icing, you might notice one of the pilots looking out of these windows.
If not now, then when?
Users browsing this forum: DL777200LR, Google Adsense [Bot] and 1 guest
