Qantas744er
PW4056 On The 744
Wed Oct 04, 2006 1:27 am
Got a question, the PW4056 has 56,750Lbs of thrust compared to the
GE CF6-80C2B1F ( 58,000Lbs) and the RR RB211-524G (58,000Lbs)
So for operators like CX, SQ, UA etc. does this mean that their 744´s will have
a "longer" takeoff roll than the other two engine types? And this will result in a slower climb rate right?
And for the pilots.. how does it compare, is there a real difference?
Cheers Leo
You live and you die, by the FMA
jetmech
RE: PW4056 On The 744
Wed Oct 04, 2006 1:43 am
Quoting Qantas744ER (Thread starter):
Erm... Do you mean MH Qantas744ER? I am pretty sure CX does not currently have P&W powered 744's, although they will have some P&W powered 747 (744?) freighters in the future.
[Edited 2006-10-03 19:04:45]
Avro85
Wed Oct 04, 2006 2:01 am
I would rather suspect that the planes with the PW engines will be certified with a smaller MTOW.... I'm not sure  Wink
Chris
Qantas744er
Wed Oct 04, 2006 2:31 am
Quoting JetMech (Reply 1):
Actually they do.. just check the database... they are all ex SQ planes.
Quoting Avro85 (Reply 2):
Nope because the SQ and CX (ex SQ) 744´s all have the max MTOW for the 744, 875,000Lbs
Cheers Leo
jetmech
Wed Oct 04, 2006 2:35 am
Quoting Qantas744ER (Reply 3):
Yep, you are quite right Qantas744ER   . I stand corrected.
Photo © Matthew C. Lyons
[Edited 2006-10-03 19:39:21]
EssentialPowr
Wed Oct 04, 2006 2:59 am
If all 3 engine types are operated at max rated thrust on respective a/c that weigh the same amount, the Pratt powered a/c will have slightly less performance in all flight regimes. In practice, it is a negligible difference.
Cheers-
Qantas744er
Wed Oct 04, 2006 3:46 am
Quoting JetMech (Reply 4):
No problem.. thats what aviation is all about, righ? Learning new things Big grin
Quoting Essentialpowr (Reply 5):
Thanks, that pretty much what i wanted to know  Smile
Cheers-
Tristarsteve
Wed Oct 04, 2006 5:20 am
On a max weight take off out of Hot Singapore, for a 12hr flight our B744 uses reduced power take off. So you would only notice that you have PW engines on really long flights. Up to then everything would be the same, same take off roll at the same thrust, just the PW engine would come up against a limitation a little earlier than a RR or GE engine. Say a 13 hr flight instead of a 13.5 hr flight. So if your route profile does not include ant flights over 13hrs, you would never notice it.
EssentialPowr
Wed Oct 04, 2006 5:46 am
Quoting TristarSteve (Reply 7):
This is a more than a bit confusing. If the a/c and take off weight weights are the same, and all 3 engines are operated at max rated thrust as provided above, the Pratt powered a/c has less performance. What diff does the 13 vs 13.5 hr flight distinction mean? If the engines have the same SFC, then the Pratt w/ less thrust has MORE range.
Avro85
Wed Oct 04, 2006 6:36 am
OK thanks for clarifying. Sorry for the mistake ...
Chris
Tristarsteve
Wed Oct 04, 2006 11:28 pm
Quoting EssentialPowr (Reply 8):
OK, sorry finding it difficult to explain.
At the same weight on the same runway at the same OAT all three engine types would have a similar take off thrust requirement. As one of these factors increases then the PW engined aircraft will reach its linits before the others.
For example for a max zero fuel weight departure on the same runway, the PW engine aircraft would be able to carry less fuel than the other two. This would make its planned mission shorter, or for the same mission it would have to offload payload in able to take the required fuel.
On the B744 out of SIN for LON with max zero fuel weight, this would not be noticed as we use derated thrust.
You would need a longer mission, or a shorter runway to notice the restriction.
PhilSquares
Thu Oct 05, 2006 12:29 am
Just to throw this in, the RR powered aircraft are substantially heavier, so they won't have the same fuel, the RR are also slightly heavier than the PW, so again, the fuel won't be the same.
In reality, there is no discernible difference. The difference in thrust is neglible.
Fly fast, live slow
EssentialPowr
Thu Oct 05, 2006 2:12 am
Quoting Tristarsteve (Reply 10):
I agree.
Negative. Same a/c remember, certified to the same weights, same day, but different engines? The MZFW won't be limiting. If there was a runway or climb limitation in which max rated thrust was required, then the Pratt powered a/c would be penalized with a runway or climb limit, which would lower MGTOW with a reduction in either payload or gas.
You stated (I copied it from my post):
Therefore, no runway or climb limit is assumed by that statement. I assumed a max rated thrust t/o, then, and assumed equal SFCs. Since the pratt powered a/c is producing less thrust at equal SFCs as the other types, it uses less fuel for takeoff and climb. For equal MGTOWs (again, exact same a/c), that reduced fuel burn in climb translates to more range for the Pratt powered a/c, b/c it burned less gas in the t/o and climb regimes, and we can assume that cruise thrust is equal for all 3 types.
Make sense?
[Edited 2006-10-04 19:15:24]
[Edited 2006-10-04 19:16:14]
[Edited 2006-10-04 19:18:42]
Users browsing this forum: Woodreau, zknzf and 2 guests
