highflyer9790
NoseGear Question
Fri Oct 06, 2006 8:42 am
Hello all-
After looking at this rather interesting photo, i am wondering what the two torpedo-like tubes are sticking out above the nose gear. i have seen this on a few other aircraft as well. Also, to how many pounds is that jack rated for?
Photo © Joe Pries - ATR Team
Highflyer
btw, i would think landing/taxi lights would be HIDs by now...lol...they are on some CRJs...
[Edited 2006-10-06 01:43:33]
121
EMBQA
RE: NoseGear Question
Fri Oct 06, 2006 8:47 am
Nose steering actuators...
highflyer9790
Fri Oct 06, 2006 9:29 am
Quoting EMBQA (Reply 1):
not sure i follow you on that one...
121
474218
Fri Oct 06, 2006 10:05 am
They are the nose gear steering actuators. There is a piston in each one and as hydraulic fluid is ported to them the piston either extends or retracts, that is how they move the nose gear left or right.
fr8mech
Fri Oct 06, 2006 10:51 am
Quoting Highflyer9790 (Thread starter):
Normally rated for 60 tons. Remember, you're only lifting the nose, which carries just a fraction of the total weight of the aircraft.
SFOMB67
Fri Oct 06, 2006 2:14 pm
Quoting 474218 (Reply 3):
To get a little more technical, the main portion of the nose landing gear does not rotate. As you can see, the steering cylinders are mounted where the lower strut piston extends from, or out of, the upper section of the nose gear. The steering cylinders merely turn the lower piston, with the wheels attached. As 474218 stated, fluid is ported to the two steering cylinders (one extends and the other retracts), and as a result, the lower piston rotates and steering is accomplished.
Spruit
Fri Oct 06, 2006 7:10 pm
Quoting Fr8Mech (Reply 4):
Does this actually lift the nose? I would have though it compressed the shock more than lift the nose?
Spru!
E=Mc2
jetmech
Fri Oct 06, 2006 7:42 pm
Quoting Spruit (Reply 6):
If everything is in equilibrium, and there is no loading or unloading going on, in theory, every millimetre you raise the jack will also lift the entire nose landing gear a millimetre as well. This will then also raise the nose of the aircraft.
The landing gear struts contain pressurised nitrogen which supports the weight of the aircraft. When the nitrogen pressure inside the strut (in psi) multiplied by the area of the inner cylinder (in square inches) equals the weight upon the strut in pounds, the strut will neither extend nor shorten.
Spruit
Fri Oct 06, 2006 7:44 pm
Quoting JetMech (Reply 7):
Good point, well made, my question seems quite obvious now you've posted this?!
Spru!
E=Mc2
Fri Oct 06, 2006 9:04 pm
The Nose Gear is def lifted after the Strut is compressed a certain extend.
regds
MEL
Users browsing this forum: EIASO, Woodreau and 1 guest
