airfoilsguy
747 A380 Slide Of Death Photo
Sat Oct 07, 2006 3:30 am
The below photo of the emergency slide on the 747 looks kind of scary. Can a passenger go down that and not break bones? Will the A380s be of the same design? I am sure if it was between death by fire, and taking the slide, I would take the slide, but there has to be a better design.
Photo © Ivan Coninx - Brussels Aviation Photography
It's not a near miss it's a near hit!!
DH106
RE: 747 A380 Slide Of Death Photo
Sat Oct 07, 2006 3:41 am
Quoting Airfoilsguy (Thread starter):
You mean - perhaps one that doesn't go down as far !  Big grin
...I watched c-beams glitter in the dark by the Tanhauser Gate....
Newark777
Sat Oct 07, 2006 3:48 am
The point isn't to have a fun ride down a slide. It's to get to the ground as fast as possible, while limiting injuries. I may sprain my ankle, but it is far better than burning alive trying to get out through the bottom level.
Harry
2H4
Sat Oct 07, 2006 3:52 am
IIRC, when the Gimli Glider (Air Canada flight 143) ran out of fuel, glided to an abandoned airstrip, and screeched to a stop with a collapsed nose gear, the only injuries occured on the evacuation slides.
I suspect this was a result of the nose gear being collapsed. The rearward section of the airplane was higher than normal, so the slides hung at an angle that was steeper than normal.
I've stood at an open door on a 747 upper deck, and I can tell you...the main exit would have to be blocked by a wall of flames for me to jump.
2H4
Intentionally Left Blank
Lemurs
Sat Oct 07, 2006 3:56 am
Quoting 2H4 (Reply 3):
I wonder how many of the 34 injuries that occured during the max-pax evac test on the A388 came from the upper deck slides versus lower. I don't think I've ever seen it spelled out...perhaps intentionally?
There are 10 kinds of people in the world; those who understand binary, and those that don't.
2H4
Sat Oct 07, 2006 4:06 am
Quoting Lemurs (Reply 4):
Good question. I'd love to see the data.
Slightly off-topic...does anyone know whether the A380's upper deck slides will the have covered 90-degree corners at the top? There was talk of including them to prevent evacuees from seeing the view down until they've already jumped onto the slide.
2H4
KELPkid
Sat Oct 07, 2006 4:07 am
Question...(relating, to the photo). In a freighter, who arms the evac slides? I realize that in a 747, the upper doors are *always* armed, but in every other airliner model, this has to be an issue...
airfoilsguy
Sat Oct 07, 2006 4:12 am
I would think a better design would be some kind of tube with an huge inflated pillow at the bottom. Like the kind you see kids bouncing on at carnivals
Quoting Newark777 (Reply 2):
The slide shown above is almost at a 90 degree angle to the ground with a very little lip or landing zone at the bottom. I don't see how anyone can go down that with out injury.
Bobster2
Sat Oct 07, 2006 4:17 am
People are supposed to go down the A380 slides two abreast. Imagine pairs of people running out the door and jumping side-by-side.
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
Newark777
Sat Oct 07, 2006 6:08 am
Quoting Airfoilsguy (Reply 7):
I really doubt it's close to 90 degrees. It's probably steep, but not that bad.
Harry
Sat Oct 07, 2006 6:47 am
Correct for the Gimli Glider.
It is an accepted "fact" not widely advertized by the airlines that an evacuation will probably involve a couple of sprains and maybe a broken bone or two. These are seen as preferable to the alternatives. You know, the charred flesh and stuff...
Flyer732
Quoting KELPkid (Reply 6):
The pilots or the loadmaster.
FredT
Sat Oct 07, 2006 7:02 am
You are being tricked by the optics of the camera.
When using a telephoto lens, the objects depicted appear compressed along the direction in which the photo is taken, i e flatter than they actually are. This makes the angle of the slide appear a lot steeper than it actually is.
That, however, does not change the fact that a few injuries are expected during any emergency evac. That's why they are a bit reluctant to blow the horn at times. They know that there'll be a broken bone or two, a few broken wrists, hips, sprained ankles etc.
Rgds,
/Fred
legoguy
Sat Oct 07, 2006 7:03 am
I would imagine elderly people would have abit of a problem even thinking about going down that slide. I can picture an elderly granny standing at the top, repeating over and over that she can't go down. She would end up holding people back up behind her and the flight attendant can not really just push her down.
Which makes me wonder, is there any rules about flying on the upper deck of a 747?
In case there is an emergency, all people on the top deck should be able to, if required, go down the steep emergency slide without much thought.
Can you say 'Beer Can' without sounding like a Jamaican saying 'Bacon'?
Lemurs
Sat Oct 07, 2006 7:06 am
Quoting Starlionblue (Reply 10):
Yup, there have to be standards for that stuff when evaluating the evacuation methods for the planes, etc...I am pretty sure the acceptable maximum in a drill is 5%. That means the 34 injured pax on the A380 are well below the threshold for how many were in the plane (almost 900?)...a pretty impressive showing considering you had hundreds of people falling from many feet up in the air from that second deck. Good job on Airbus.
ThrottleHold
Sat Oct 07, 2006 7:20 am
That's a bit of a dramatic title!! Do you write headlines for the FOX Channel by any chance?
Newark777
Sat Oct 07, 2006 7:23 am
Quoting Legoguy (Reply 13):
If I see flames, grandma is getting a nice firm kick in the ass, and isn't going to have a choice.
Harry
curlyheadboy
Sat Oct 07, 2006 7:34 am
Quoting Newark777 (Reply 16):
Harry
BTW, have a look at this other pic of the "established on the ILS" 742, it gives an idea of how much the slide slopes. looks as quite a ride...
Photo © Vincent JR
[Edited 2006-10-07 00:43:42]
[Edited 2006-10-07 00:45:01]
If God had wanted men to fly he would have given them more money...
legoguy
Sat Oct 07, 2006 7:42 am
LOL poor granny. Do any airlines consider this sort of thing when allowing people on the top deck of the 747?
Tod
Sat Oct 07, 2006 7:45 am
Big version: Width: 851 Height: 638 File size: 50kb
Depends on where you park.
 duck Tod
legoguy
Sat Oct 07, 2006 7:48 am
Quoting Tod (Reply 19):
Now that looks fun! When did this happen?!?! I presume it was a runway over run?
TEBGuy
Sat Oct 07, 2006 7:52 am
wow  laughing   rotfl
and i thought on campus parking was bad.
Remember, taking off is optional, landing is mandatory.
AirWillie6475
Sat Oct 07, 2006 8:04 am
Things such as the slide up there are tested over and over again, they don't just put an inflatable slide and hope for the best.
Tod
Quoting Legoguy (Reply 20):
Overrun at BKK a few years ago.
Tod
2H4
Sat Oct 07, 2006 8:08 am
Quoting ThrottleHold (Reply 15):
The title of this thread is, in my opinion, one of the single greatest thread titles I've ever seen on A.net.  biggrin
2H4
airfoilsguy
Sat Oct 07, 2006 8:11 am
Quoting CURLYHEADBOY (Reply 17):
That one dosen't look so bad.
That is histerical. Sort of a new meaning to adding insult to injury
Tod
Sat Oct 07, 2006 8:24 am
Quoting Legoguy (Reply 18):
poor granny
 checkmark
Didn't some granny break her neck in a Douglas evac test about 20 years ago?
Tod
N600RR
Sat Oct 07, 2006 8:28 am
Quoting 2H4 (Reply 24):
...Sounds more like something from Mythbusters
Hmmm, well the slide part looks tame enough, but going off the end... splat  ouch  knockout
"And the fluffy white lines that the airplane leaves behind are drifting right in front of the waning of the moon" -Cake
Sat Oct 07, 2006 8:43 am
As Newark777 points out, granny would get a kick in the bum. To quote well known pointy eared science officer: "Sometimes the needs of the many outweight the needs of the few, or the one."
Quoting AirWillie6475 (Reply 22):
So true. And it is also understood that any evacuation is a suboptimal outcome, with no way to plan for every eventuality. For example if the captain parks her next to a tree.
As I understand it, the slide isn't exactly slippery as an oilslick either. I'm pretty sure it has some friction so as to limit terminal velocity. I think that's one of the reasons you should hold your hands on your chest. It lessens the risk of friction burns.
[Edited 2006-10-07 01:45:19]
Tod
Sat Oct 07, 2006 8:55 am
Quoting Starlionblue (Reply 28):
But that's no fun.
Big version: Width: 659 Height: 575 File size: 177kb
Tod  Smile
2H4
Sat Oct 07, 2006 9:00 am
Come to think of it, that was the other main cause of injuries on the Gimli Glider evac. Apparently, there's enough friction to cause very severe burns that essentially tear off exposed flesh.
I shudder whenever I see people flying with flip-flops, high-heels, skirts, etc. Imagine having to A) Evacuate, and B) trudge through and wait in ice, slush, and snow after the evacuation while wearing such things.
 cold
2H4
Markhkg
Sat Oct 07, 2006 10:30 am
For the record, the UD slide in the picture was NOT opened by the cabin crew. It was opened by maintence personnel after the evacuation had taken place.
There are deceleration pads at the end of the slide.
Quoting Tod (Reply 26):
During an MD-11 evacuation trial, a women tripped on the slide, went down head first, and ended up paralyzed from the neck down.
The slides are of different design. In fact, the A380 upper deck door is LESS high than the B-747 upper deck door. I remember reading one accident report where a B-747 PIC or First Officer broke his collarbone because at the end of the UD slide he fell off the slide.
The A-380 UD deck doors are designed so that passengers do not hesitate before they start the descent...the slide is designed so pax cannot look directly down to judge the height and thus are sliding by the time they realize how high they are.
An interesting feature of the new A-380 slide is that they can deploy several more feet of slide in case the door detects an unusual aircraft attitude when it is open (i.e. the UD doors in the front of the plane during a nose up landing will deploy several more feet of slide to ensure the slide touches the ground.)
http://www.faa.gov/ats/asc/nlaweb/Do...0ARFF%20for%20NLAFG%2005-13-03.ppt
Big version: Width: 240 Height: 180 File size: 69kb
Big version: Width: 240 Height: 180 File size: 57kb
Skookum
Sat Oct 07, 2006 10:37 am
At least lube it up with some lav blue-goo first.
Good flying
kaddyuk
Sat Oct 07, 2006 10:27 pm
Quoting MarkHKG (Reply 31):
I've been down a B744 UD Slide Before, its fast, but not dangerous... Not in the slightest... If you keep your whits about you and put your feet down infront of you and continue running as you hit the ground, you'll be FINE!
If you like my friend on the other hand, DONT stick your feet out ready to be walking on when you hit the bottom, you'll end up on your back and that IS painful because the 2 or so ft from the floor to the slide surface is a fair drop even when you're NOT doing speed!
MD11Engineer
Sun Oct 08, 2006 12:36 am
Anybody know the inertia reels attached to the cockpit emergency hatch of the 747 (UPS used them also for their 757s)?
You were supposed to don a harness looking like a diaper, hook that inertia reel to the harness using a snap hook and then jump out of the emergency hatch. As one F/E on a safety briefing before a jump seat flight told me once "you go down like a barrel of bricks"!  Wow!
On the Channel Express A300B4s they didn't even had the harness, you were supposed to grab a reel by the handle and make sure you went out of the cockpit window feet first.
Jan
2H4
Sun Oct 08, 2006 12:41 am
Quoting MD11Engineer (Reply 34):
I think that's the same equipment used by Batman.
2H4
airfoilsguy
Sun Oct 08, 2006 1:08 am
Great photos, I have been waiting to see what the A380 slides look like. They don't look any worse then those big slides you see at the fair.
Sun Oct 08, 2006 1:32 am
It all depends on the correct method used for Jumping on the slide.
regds
MEL
Markhkg
Sun Oct 08, 2006 3:16 am
Quoting Airfoilsguy (Reply 36):
Check out the A380 evacuation trial video too...
http://www.a380.singaporeair.com/gallery_home.html#
pygmalion
Sat Nov 04, 2006 3:50 am
The 747 also had only a hand reel, no diaper/harness. You grab on and slide down the side of the fuselage. I think they are all the same. Its still better than the rope you slide down on most airplanes. The inertia reel at least wont give you a rope burn.
Users browsing this forum: Flow2706, StereoTechque and 1 guest
