JAGflyer
Fuel Quantity By AC
Tue Oct 17, 2006 8:43 am
Where would I find a fact sheet about how much fuel different planes' tanks usually hold. I am curious to know fuel quantities for aircraft.
For example how much avgas does a C152 take and how much jetfuel does a A340-600 take?
Support the beer and soda can industry, your recycle old airplanes!
N231YE
RE: Fuel Quantity By AC
Tue Oct 17, 2006 8:52 am
Cessna 172R: 56 Gallons of Avgas 100LL total, 53 Usable.
411A
Tue Oct 17, 2006 10:50 am
The first civil transport with a fuel capacity (in pounds) greater than its empty weight is....the B707-300.
Max fuel, 23,855 US gallons 162,314 pounds (depending on fuel temperature).
Typical empty weight, 144,300 pounds
Endurance, 10.5 hours.
Cruising speed, M.82
Runway required at MTOW (316,000 pounds), standard day, sea level,
11,650 feet (balanced field length).
An oldie...but a goody:D
vikkyvik
Tue Oct 17, 2006 10:52 am
I'll be nice, and not just say "go to the manufacturer's websites"
From www.boeing.com:
Maximum Fuel Capacity:
737-700: 6,875 U.S. gal (26,020 L)
767-300ER: 23,980 U.S. gal (90,770 L)
777-200ER: 45,220 U.S. gal (171,160 L)
747-400: 57,285 U.S. gal (216,840 L)
Aaaaaand....from www.airbus.com:
A320: 6,300 (7,885) US gal.
A330-200: 36,750 US gal.
A340-300: 37,150 (39,060) US gal.
A340-600: 51,746 (54,023.2) US gal.
EDIT: Edited to put the 737 before the 767....cause those kind of things annoy me  Smile
[Edited 2006-10-17 03:54:56]
JAGflyer
Tue Oct 17, 2006 11:49 am
Wow, at YKZ most of the fuelings are nozzle fuelings with like 100-300 litres per side. The odd singlepoint bizjet with a few hundred more. I am bigger airports have faster singlepoint nozzles/hoses but I can't picture having to do a large jet with our equip. The tank would be low if not empty by the time we finished 1 737. How long does it usually take to fuel a 747 (i assume they have both wings fueling at the same time)
futurecaptain
Tue Oct 17, 2006 12:15 pm
Quoting JAGflyer (Thread starter):
26 gallons. 24.5 usable.
EMBQA
Tue Oct 17, 2006 12:20 pm
Your best source is a search of the TCDS.
http://www.airweb.faa.gov/Regulatory...keModel.nsf/MainFrame?OpenFrameSet
[Edited 2006-10-17 05:21:13]
jetmech
Tue Oct 17, 2006 12:43 pm
Quoting JAGflyer (Reply 4):
G'day JAGflyer  Smile. I used to work at the international terminal at SYD. The heaviest fuel loads were for the 744(non ER) aircraft doing Trans-Pacific flights to LAX. In these situations, the final fuel figure was often as high as 176 tonnes depending on the specific gravity for the day. The aircraft usually had about 15 tonnes of fuel aboard, so the uplift was about 160 tonnes. IIRC, this would take about 40-45 minutes with 2 trucks.
The best part of these tasks was if you could manage to get the final fuel load not more than 100 -200 kg above what the pilots wanted. Too much more was no good as they were often at MTOW, but an extra 100 -200kg would be burnt during taxi putting them right on MTOW upon line up to the runway. It was even better if the discrepancy was less than 100 kg as well Big grin  bigthumbsup !
It was just amazing how low the wing bent down with that much fuel. The inlets of the outboard engines were no higher than the inboards. Add a full load of passengers and baggage and the landing gear struts would have only an inch or so of chrome showing. This meant that the engine inlets were only about 3 -4 feet off the ground! You could almost touch the wingtips if you jumped hard enough.
Photo © Gabriel Savit
Photo © Tim Edmunds
JAGflyer
Tue Oct 17, 2006 9:09 pm
The first time I watched an MU2 being fueled I was told to watch the wings to see what happens. Since they are very highwinged you can see the weight of the fuel bending them down.
[Edited 2006-10-17 14:10:57]
Wed Oct 18, 2006 11:38 pm
Quoting JAGflyer (Reply 8):
Even on common commercial Aircraft ie B737/757s.Its cautioned not to place the Cocks touching the wheels & not place Trestles/Equipment below wings as the added fuel weight can cause the Aircraft to drop lower on the Struts.
regds
MEL
Spruit
Wed Oct 18, 2006 11:51 pm
Quoting Vikkyvik (Reply 3):
Almost OCD there VikkiVic  Wink
E=Mc2
Users browsing this forum: No registered users and 20 guests
