speedracer1407
Arming Autobrakes
Tue Oct 17, 2006 11:18 am
I wasn't sure how to title this thread.
It's my understanding that autobrakes are armed before touchdown, likely in some checklist WELL before touchdown. Is it simply a matter of ensuring that the autobrake selector is set at the desired setting? Or is there something more to it, like a separate button that arms the system independently of the selector.
Also, how does autobrake selection work in situations when the pilot needs more or less braking than expected.
I seem to recall a pilot in another post suggesting that, if the ABS was set to "2" he could simply flick it to 3 during the landing rollout to expedite deceleration for a quickly approaching turnoff. Am I remembering this correctly?
Moreover, can the ABS system be used after touchdown if it hasn't been preset? I'm imagining a scenario in which a pilot is practicing touch and goes, and therefore has the ABS set to off. He touches down, and at that moment, an engine lets go, or some other serious failure occures. Can he simply flick the ABS over to "max," or does he need to apply manual braking?
This scenario is, of course, predicated on the idea that it would be wise/legal to jump on the brakes during a touch and go. I have no idea whether it is a good idea to do so, or even legal. Regardless, I'm curious about whether or not ABS can be activated once the plane has touched down with the system turned off.
thanks for any replies.
O
EssentialPowr
RE: Arming Autobrakes
Tue Oct 17, 2006 1:22 pm
Quoting Speedracer1407 (Thread starter):
On a Boeing it will Disarm b/t switch positions, and who wants to test whether it will rearm as one is rolling along at 145 kts?
Don't flick switches; bad technique. Use the automation in the manner intended; ie well before landing. If more brake energy is required, go to manual brakes with more pressure. Less? Just tap the brakes, and the autobrakes will disengage.
The function of auto brakes is to start and maintain deceleration at a point faster than humanly (typically) possible. If it's gusty, and you are busy flying the a/c all the way down to taxi speed, that is what ABs are for...
IAHFLYR
Tue Oct 17, 2006 8:30 pm
Quoting EssentialPowr (Reply 1):
Can't you run the speed brake closed and then full deflected to release them as well? That tap on the brakes at times is a jolt......bam then gone, very annoying for those who enjoy a nice calm ilde reverse and solid braking!!!  Smile It's like NO you can't make the turn at SF go to the end and round the corner on 2 wheels.......  Embarrassment
IAHFLYR
Tue Oct 17, 2006 9:05 pm
Quoting Iahflyr (Reply 2):
Silly dude, he meant spoilers......close the spoilers and then fully deploy them to release the autobrakes!!!  coffee
PhilSquares
Tue Oct 17, 2006 11:07 pm
On the 744, switching the autobrake selector from 2-3 will disarm the autobrakes. With the autobrakes operating, once the selector is taken out of the current position, the autobrakes are disarmed.
No. However, the rest of your question is somewhat different. On the 744, during touch and go's, as long as the thrust levers aren't vertical or greater, you just abort the maneuver. Stopping isn't a problem at all. If the engines have spooled up, you just continue the takeoff and deal with the problem in the air.
Fly fast, live slow
EssentialPowr
Wed Oct 18, 2006 12:29 pm
Steve McQween type, baby!!
EssentialPowr
Wed Oct 18, 2006 12:31 pm
Quoting PhilSquares (Reply 4):
Is there an echo in here?
Max Q
Thu Oct 26, 2006 2:39 pm
On the 75/6 to disengage the autobrakes you only need to slightly retract the spoilers to smoothly disengage the autobrakes, it does not require full retraction.
David L
Thu Oct 26, 2006 6:05 pm
Quoting EssentialPowr (Reply 6):
In defence of PhilSquares, I wasn't sure if you meant the autobrakes are only disarmed while the switch is between settings. It was a slightly modified echo.  Smile
PhilSquares
Thu Oct 26, 2006 8:47 pm
EssentialPowr, having a bad day? What I attempted to do was clairify your post. I can tell you after doing work with and for Boeing, it's one of the things that's tested when an aircraft is delivered. As for the echo, I'd suggest you get your hearing tested!!!
Fly fast, live slow
EssentialPowr
Fri Oct 27, 2006 4:27 am
Phil Squares,
I respectfully submit that the point had been adequately made. I feel people should read other's posts and if they "clarify" them, note that.
I just feel it makes the forum better, and I practice what I preach.
cheers-
Bobster2
Fri Oct 27, 2006 5:44 am
Quoting EssentialPowr (Reply 10):
I believe you meant others' posts. Note how the position of the apostrophe clarifies the meaning.  Smile
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
EssentialPowr
Fri Oct 27, 2006 6:24 am
Quoting Bobster2 (Reply 11):
Absolutely, thank you. "Others" is plural, therefore the possessive form is others'.
Users browsing this forum: Armadillo1, atcdan and 16 guests
