BOE773
Trent Fan Blade Failure.
Sun Oct 22, 2006 12:33 pm
Emirates A330 Fan Blade - DXB 18 Oct
An EK A330-200 inbound to DXB from BHX last Tuesday 17th initiated a go-around when the #2 RR Trent engine threw a fan blade thru the inlet cowling.
jben
RE: Trent Fan Blade Failure.
Sun Oct 22, 2006 6:35 pm
BOE773... How is GE doing on their GE90-115B FADEC issues, and those other uncontained HPT failures?
AvFan4ever
Sun Oct 22, 2006 6:42 pm
Quoting Jben (Reply 3):
Software fix for the faulty FADEC algorithm has been issued, and not sure that an HPT blade issue found during a borescope inspection qualifies as an uncontained HPT failure.
PlymSpotter
Sun Oct 22, 2006 8:12 pm
I didn't see anything on the local Birmingham news about this, and after looking on the web and local news sites for the Midlands area I still can't find out any info about this. If it was indeed an uncontrolled failure then I would have thought that it would have made the news and even if it was a controlled failure the aircraft would be doing some serious downtime at BHX, perhaps one of the regular BHX visitors could confirm seeing an EK aircraft parked up and the reg perhaps?
I did though find this whilst searching, not sure what year it is from though?
DATE/SITE: 19 Feb ~1700Z Gatwick, UK
AIRCRAFT & REGN: 777 of Emirates Flt EK040
CIRCUMSTANCES: Diverted in after losing a panel on takeoff from Birmingham DEATH & INJURY: Nil
PRELIMINARY ANALYSIS2 imagery at www.iasa.com.au/280205.htm: Panel was inspection cover off #2 engine pylon
small extract from the following:
http://findarticles.com/p/articles/mi_m0UBT/is_8_19/ai_n11844080
Dan Smile
jetmech
Sun Oct 22, 2006 8:28 pm
The only source of limited information I have found is on pprune;
http://www.pprune.org/forums/showthread.php?t=248980
Quoting BOE773 (Thread starter):
The poster of this information states that a go-around was initiated first, the events with the engine happened subsequent to this. There was no concrete details on what this event was.
[Edited 2006-10-22 13:39:20]
Sun Oct 22, 2006 11:13 pm
A blade (i.e. one) caused all that damage forward of the LP turbine ?
BOE773
Mon Oct 23, 2006 1:04 am
FrancoBlanco
Mon Oct 23, 2006 4:01 am
BOE773 vs. Rolls-Royce
Round 146
Battle Of The Blades
How on earth did I survive my last flight with a RR-equipped aircraft? As we know, RR engines are flying death-traps!
Sebastian
'Pointless!' - NY Times
David L
Mon Oct 23, 2006 4:51 am
How do you feel about the incident, BOE773? Was it good or bad?
airfoilsguy
Mon Oct 23, 2006 5:03 am
Wow, lucky that the blade or blades were thrown away from the plane. Another 180 degrees and passengers could have been hit.
It's not a near miss it's a near hit!!
LTU932
Mon Oct 23, 2006 5:54 am
You are aware that there has been one incident involving a GE engine, which just might have had an even worse outcome had the incident happened in flight, right?
Photo © Gustavo Bertrán - Iberian Spotters
Photo © Michael Carter
So, in the end, the Trent 700 fan blade failure on the EK A330 is nothing compared to what happened to the pictured AA 762. In fact, the pictures of the EK A330 don't even show more serious structural damage, which means the aircraft could go back to service quickly after getting the number 2 engine changed and the number 1 engine and the rest of the aircraft thoroughly checked.
Seriously, why the hate towards Rolls Royce?
BOE773
Mon Oct 23, 2006 6:30 am
For more than 30 years, the GE CF6 family of engines has established an impressive operational record. Currently there are more than 180 customers, operating 1,900+ aircraft, averaging 4,150 departures per day, and racking up an impressive 260 million total flight hours since it entered commercial revenue service in 1971.
David L
Mon Oct 23, 2006 6:51 am
Quoting BOE773 (Reply 17):
Very good, BOE773. Copied and pasted verbatim from here:
http://www.geae.com/engines/commercial/cf6/index.html
 sarcastic
Now, what has that got to do with a blade failure on a Trent?
Mon Oct 23, 2006 7:25 am
Quoting BOE773 (Reply 6):
http://www.airdisaster.com/forums/showthread.php?t=82025
Yes that is a copy of the post from pprune http://www.pprune.org/forums/showthread.php?t=248980
Still you have not said how one blade could do this forward of the LP turbine.
And what does this have to do with the CF6 ?
Anything else you wish to copy, do you have any original ideas ?
