goinv
How Does An Aircraft Rotate?
Wed Oct 25, 2006 1:21 am
You're in an aircraft sitting at the end of the runway. Forward thrust is applied. At a predetermined speed Vr is reached (rotate) followed by V2 (which I understand is the speed at which the aircraft can become airborne)
How does the aeroplane lift it's nose wheel up in the air to start the climb ?
I would assume that there are no mechanical or hydraulic systems on the plane (like a road digger which phsysically lifts the nose).
Is it as simple as "at Vr there is sufficient wind passing over the control surfaces so that when the pilot flying pulls back on the stick the ailerons (?) move causing a change in wind direction over the control surfaces which forces the noise of the plane up ?
Sorry if some of my terminology is wrong and if this is a question with an obvious answer.
Many Thanks
Be who you are, The world was made to measure for your smile. So Smile.
RichardPrice
RE: How Does An Aircraft Rotate?
Wed Oct 25, 2006 1:29 am
Quoting Goinv (Thread starter):
Thats it, in a nutshell, terminology not-with-standing.
Boeing Nut
The horizontal stabilizors, or rear wings if you will, apply a downward force to the tail which occurs when the pilot pulls back on the stick or yoke. The in turn increases the angle of attack of the wing which creates lift and presto! Airborne.
N231YE
Wed Oct 25, 2006 1:30 am
Yes, it is that simple, but the control surfaces that control pitch are the elevators, not ailerons.
Boeing Nut
Don't worry, the only dumb question is the one that isn't asked.
cdfmxtech
Wed Oct 25, 2006 1:39 am
http://selair.selkirk.bc.ca/aerodynamics1/Stability/Page2.html
Pretty helpful
The small little wings on the aft end of the airplane called Horizontal stabilziers have panels on them called elevators. These elevators are go up and down and control whats called the PITCH of the aircraft. If the pilot pulls back on the control column, he wants the plane to go NOSE UP. The elevators will move up and the air acting on the surface will make the aircraft pitch up. Since the elevators are in the back, the nose of the aircraft starts to ROTATE upwards. This is as basic as I can make it.
You assume correctly.
Yeah, you could say that. Just substitute "airflow" for wind and "elevators: for ailerons.
The only stupid question is the one not asked.
Slcpilot
Wed Oct 25, 2006 1:48 am
As a very young child I was very disturbed. It was very difficult for me to see how the power from the engines was transmitted to rotational power in the wheels for taxi and T/O.
I also had a hard time understanding why, when "sitting" on a board, I was unable to lift with sufficient strength to hold my self in the air. It was easy enough to dismiss it as weak arms.
Thankfully, two weeks ago, both questions were answered.
Cheers!
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
brownbat
Wed Oct 25, 2006 2:21 am
The pilot pulls up on the yoke. Without the pilot the plane will still be at the gate.
vikkyvik
Wed Oct 25, 2006 3:17 am
Also note that V2 is not the speed at which an aircraft can become airborne. Technically, an aircraft will likely be able to become airborne even below Vr.
V2, I believe, is the takeoff safety speed. It is the speed that the aircraft must be able to achieve, with an engine failure after V1, in order to meet climb gradient and obstacle clearance requirements.
Quoting Boeing Nut (Reply 2):
Indeed, though a better way to phrase it would be to say that increasing the angle of attack increases the lift. The wings are already generating a significant amount of lift before rotation. Rotation increases the lift past the point where lift is greater than the weight of the airplane (hence, the airplane climbs).
~Vik
N231YE
Wed Oct 25, 2006 3:29 am
Quoting Vikkyvik (Reply 8):
True, but not safely. A Cessna 172R, for example, can rotate in as little as 40kts, however, one will be flying on "ground effect." If one goes one-wingspan length above the runway, the ground effect diminishes, and if the aircraft is not at or above the normal Vr (Cessna 172R: 57kts), then one will stall.
Actually, that is how soft field takeoffs are conducted.
vikkyvik
Wed Oct 25, 2006 4:03 am
Quoting N231YE (Reply 9):
Yep. Hence "technically..."  Smile
I would say that that depends on the circumstances (mostly, on the aircraft, and on what the pilot is trying to do with said aircraft). Obviously, I don't know for sure, but I'd say that it's not a hard and fast rule that once above ground effect, if not at or above Vr, stall will result. Anyway, I'm pretty sure we're in agreement  Smile
Quoting SLCPilot (Reply 6):
Now I'd like to know what happened two weeks ago.  Confused  Wink
Boeing Nut
Wed Oct 25, 2006 4:08 am
Quoting BrownBat (Reply 7):
Incorrect.
Photo © Ben Wang
 duck
N231YE
Wed Oct 25, 2006 6:41 am
Quoting Vikkyvik (Reply 10):
Yeah, I subconsciously read over the "technically" part-my bad, but I guess I explained it a little more in depth.  smile
pilotpip
Wed Oct 25, 2006 11:20 am
Quoting Boeing Nut (Reply 11):
Incorrect
The only difference with that one is that the pilot is sitting in a La-Z-Boy in front of a computer monitor.  Smile
DMI
lehpron
Wed Oct 25, 2006 11:33 am
More lift you mean. It is not like the wing creates no lift prior to the point when an aircraft rotates. Since the wing is lifting some of the weight off the ground, it puts less stress on main undercarriage when the tailplan pushes the aft of the plane down.
It would be nice if that tailplane force is the only downforce the wheels feel with the wing completely lifting the plane.
A wing lifting doesn't mean going up, it means held up, that more lift will allow the plane to go up and less lift will make it go down.
LFutia
Wed Oct 25, 2006 12:00 pm
Quoting XJRamper,
RUN to the back...... NOW!!!!
[Edited 2006-10-25 05:00:43]
Wed Oct 25, 2006 11:38 pm
Pulling back on the Control column operates Elevator PCAs on the control surface to deflect the Tail down,raising the nose.
regds
MEL
Users browsing this forum: ARNPEK, Bing [Bot] and 1 guest
