mohavewolfpup
Water Coming Out The Emergency Exit?
Wed Oct 25, 2006 8:39 am
Last year on final approach (and throughout the flight now and then) from PHX>PHL on southwest N775SW, I was taking photos. after a while, I was aware of water running down from the top of the emergency exit door (was seated on the left side of the plane closest to the door) into my lap. It wasn't like a gushing torrent of it, just would come now and then. yes it was raining some, especially on final approach into the airport (great coming through the clouds!) but I always wondered what was going on.
It didn't seem like a threat, I figured if the aircraft had a giant leak in it, the crew would know, so I didn't get all panicked about it.
The leak seemed to come from the sealing area around the top of it, and ran from there. is this just cabin temps combined with the outside temp, or something else?
incidentally also, that poor window would need a replacement at some point, it started out clear when it took off from PHX, but when it PHL it was very dinged up with star cracks from the engine kicking out debris possibly? made photos hard to take after a while! It wasn't ice, as it never melted off, especially when the plane landed and we sat/taxied to the terminal for a bit (flew july 6th 2005, not exactly winter! Big grin)
Jamie757
RE: Water Coming Out The Emergency Exit?
Wed Oct 25, 2006 9:24 am
Quoting Mohavewolfpup (Thread starter):
I think this was condensation that you experienced, I've had a similar experience on a 752.
Looks like ice to me.  Smile
Rgds.
"I feel like a turkey who's just caught Bernard Matthews grinning at him!"
EMBQA
Wed Oct 25, 2006 9:31 am
Very-very common. Most all windows have a small hole or drain to allow this condinsation to vent out. If you look at your pic you can just seen the drain in the very lower edge.
As for rain coming in that is common as well around doors. As the plane depressurzes water can seep in around the door seal. It's common to find water soaked insulation below the overwing doors.
[Edited 2006-10-25 02:37:19]
mohavewolfpup
Wed Oct 25, 2006 10:53 am
Quoting Jamie757 (Reply 1):
i'm sure it wasn't ice, it never left off the window. I watched as it grew in scope also. the more we flew to the destination, the more dinged up the window got. hard to tell in the photo also, but you could see the tiny cracks/dings in it when you looked at it from the right angle. it reached a point also that it was so bad, I couldn't take photos of the citys below anymore. due to the 10-20 minute delay on the ground taxing in also, it never melted then either. I always weight until about 98% of the plane empties out so I can get out my luggage above, and it still didn't  Wink
maybe someone serviced N775SW for this problem, I don't know. i'm just a wolf flying on a plane (no, I don't claw the seats up, you are all safe!)  Wink
474218
Wed Oct 25, 2006 11:11 am
The picture is ice crystals on the inside surface of the outer window pane. You stated there was water dripping on you, I am sure some of that moisture also worked its way in between the inner and outer window pane.
mohavewolfpup
Wed Oct 25, 2006 12:52 pm
Quoting 474218 (Reply 4):
i'm sure it wasn't ice, it never left off the window. I watched as it grew in scope also. the more we flew to the destination, the more dinged up the window got. hard to tell in the photo also, but you could see the tiny cracks/dings in it when you looked at it from the right angle. it reached a point also that it was so bad, I couldn't take photos of the citys below anymore. due to the 10-20 minute delay on the ground taxing in also, it never melted then either. I always weight until about 98% of the plane empties out so I can get out my luggage above, and it still didn't melt!
please read what I post, I doubt ice takes that long to melt in summer.
did you read this part?
It wasn't ice, as it never melted off, especially when the plane landed and we sat/taxied to the terminal for a bit (flew july 6th 2005, not exactly winter!)
it was july 6th 2005, and when I finally got out of the plane and into the taxi terminal, it was very humid feeling. I am not flying to Inuit Country up in canada in december, I flew at the peak of summer......
oh yeah, when I noticed the "ice" everyone calls it forming, it was still sunny out. I got a beautiful ride in my favorite plane of all time, a 737 with sun shining in. felt nice and was a moment to remember. It was a warm sun also. so apparently this "ice" defied sun shining in, which would have melted some of it. why did more form later on then? I would say the flecks in the window started forming about 1.5 hours outside of phoenix at this point.
amazing...
seanp11
Wed Oct 25, 2006 3:00 pm
If it looks like ice, it probably was ice. Glass tends not to crack in straight lines, while (water) ice will always form in the same crystal form.
And it is possible for the ice to take a while to melt, especially if
Quoting Mohavewolfpup (Reply 5):
When it is well below freezing, the sun won't make any real difference in melting the ice or not.
If the glass were actually fracturing, the lines of the fracture would be curved to some extent. That is just how glass behaves. It is called conchoidal fracture. These things, let them be cracks or ice crystals, are straight. If your picture was better resolution, I could probably get a better idea, but those really do look like ice crystals.
Stealthz
Wed Oct 25, 2006 3:25 pm
You can rest assured that what others have told you about frozen condensation between the window panes is what you saw here.
If the engine was kicking out enough debris to do this much damage during your flight we would likely be reading half a dozen threads in Civ/Av speculating what might have happened to 775SW on that tragic flight between PHX & PHL, and your family grieving your loss!
airfoilsguy
Wed Oct 25, 2006 7:24 pm
The wing is blocking the engine. If it was the engine doing that to the window there would be a big hole in the wing to allow it to happen. It is most lickely ice on the second window. The air between the first window and the second window takes a while to warm up.
It's not a near miss it's a near hit!!
BAE146QT
Wed Oct 25, 2006 8:15 pm
Perhaps it would help if someone was able to explain to our canine friend here why the ice remained for so long after landing?
At a guess I would say that the aircraft was cold soaked at altitude and because glass is a poor conductor, the inner pane remained cold for some time after?
Further, I've definitely read threads here about clear ice remaining on the wings of aircraft for *long* after they have landed.
Todos mis dominós son totalmente pegajosos
David L
Wed Oct 25, 2006 9:55 pm
Further to the comments above, look at the condensation patterns around the mystery marks. There's clearly a temperature difference around those white blobs.
If that had been the case, I think you'd have heard it.  Smile
Wed Oct 25, 2006 11:45 pm
It def looks like Ice.
regds
MEL
Jamie757
Thu Oct 26, 2006 12:16 am
Don't think so, have a look below, the window is forward of the engine..
http://i18.photobucket.com/albums/b110/jamie757/DSCF0010.jpg
Quoting EMBQA (Reply 2):
It was raining at the airport when I experienced the same thing so that explains it.
Quoting BAe146QT (Reply 9):
I'd agree with this.
Rgds.
[Edited 2006-10-25 17:33:12]
474218
Thu Oct 26, 2006 12:22 am
The aircraft flew at -65 degrees for several hours. It will some time, even on a hot day, to heat the surface enough to melt any ice. I read what you said, but I have worked on aircraft for over 40 years and I know those are ice crystals in your photo.
Quoting Seanp11 (Reply 6):
Its not glass its stretched acrylic (plastic).
seanp11
Thu Oct 26, 2006 2:51 am
Quoting 474218 (Reply 13):
I'll have to take your word on that. I thought that the windows were laminated glass, with an acrylic inner pane.
Does anybody know here if acrylic breaks in the same pattern that glass breaks?
But yeah, those definitely look like ice crystals.
Thu Oct 26, 2006 6:33 pm
Quoting Seanp11 (Reply 14):
Crazing is a more serious issue here.
regds
MEL
Curmudgeon
Thu Oct 26, 2006 8:38 pm
The star patterns are ice. This pattern is common, and is much like a snowflake growing in place. If I had a dollar for every time I've seen that...
The dripping wasn't leaking-it was condensation. As you reported, there was high humidity on the ground. During descent, the aircraft's air conditioning systems are only just running, due to the reduced bleed air available from idling engines. The humidity in the cabin increases, and condensation forms on the still very cold metal ribs just behind the trim. This is most noticeable around windows and doors. (It is impossible for rain to leak into a pressurised airframe)
Rest assured that the same happens in the cockpit. Some aircraft (I'm thinking of 747-200's specifically) drip ice water right down the captain's neck during arrival. Part of the descent checks used to be the strategic placement of wads of Kleenex around trim openings in order to avoid the water torture caper.
Jets are for kids
Sat Oct 28, 2006 1:09 pm
Quoting Curmudgeon (Reply 16):
The B752 with its "Over powerfull Packs"  Smile has this problem.Especially if the drip is right over the Rudder trim knob on P8.
regds
MEL
jetjack74
Sat Nov 04, 2006 4:12 am
On the DC10, it was common that the seam between the door panel joining the with the removable slide bustle, that water would run down the front of it form condensation freezing during flight that builds up around the window port. Very common. On the 757, when the door is open and you look down at the floorin each corner, you'll see little drains for the condensation that melts.
Made from jets!
legoguy
Fri Nov 10, 2006 7:29 pm
LOL. As everyone else has stated, it's ice. If it was debris from the engine you would have heard small noises as the debris cracking the window. The first time I remember seeing this happen was when I was young. I got ennoyed because I couldn't enjoy the view out of the window however IIRC, I got to go up to the cockpit and the view there was amazing!
Can you say 'Beer Can' without sounding like a Jamaican saying 'Bacon'?
smcmac32msn
Sun Nov 12, 2006 5:55 am
What kind of debris would you be hitting at 30,000+ ft in the air?! Microscopic alien life forms?! LOL. Dude, give it up, its ICE. Ice, Ice, Baby!
Hey Obama, keep the change! I want my dollar back.
Users browsing this forum: AT72 and 2 guests
