Lumberton
Falcon HTV Hypersonic Project Update
Fri Oct 27, 2006 10:12 pm
http://www.defenseindustrydaily.com/...n-htv-hypersonic-project/index.php
DARPA and prime contractor Lockheed Martin have decided not to build and fly the two planned HTV-1 craft after subcontractor C-CAT experienced delamination problems with the curved leading edges of the carbon-based aeroshell. Instead, they have shifted efforts to a different HTV-2 design whose multi-piece aeroshell has thinner leading edges and will be easier to build because it's less of a technical stretch. Meanwhile, thermal protection research will continue, as will research into the scramjet engines required.
DID's updated anchor article here:
http://www.defenseindustrydaily.com/...ane-program-inches-along/index.php
"When all is said and done, more will be said than done".
lehpron
RE: Falcon HTV Hypersonic Project Update
Sat Oct 28, 2006 4:32 am
Contours of the fuselage length-ways near the bay doors appear to me as misleading, would you think they are flat horizontal (parallel to freestream) or inclined (boat like fuselage)?
grandtheftaero
Sat Oct 28, 2006 6:39 am
Quoting Lehpron (Reply 1):
Perhaps you are making comparisons to the X-43? That had an "inclined" forebody because it was the inlet to the SCRAMJET engine. This machine appears to have to separate engines with their own inlets. Without the kind of airframe/engine integration found on the X-43 you are free to use just about anything with a sharp leading-edge to generate lift like a waverider at hypersonic speeds, if you don't melt it first. My apologies if I'm telling you something you already know.
Lumberton
Sat Oct 28, 2006 7:24 am
Apologies if this question is dumb, but doesn't a scramjet need oxygen? How can it be a space plane if it's powered by scramjets?
Sat Oct 28, 2006 8:26 am
Quoting Lumberton (Reply 3):
Well, all reaction engines need oxygen  Wink
Yes, I know what you meant. Ramjets and scramjets are airbreathers and thus do not carry their own oxidizer like rockets. For a spaceplane this can still be useful during the atmospheric boost phase. Also, I understand this is not a spaceplane, just a fast atmospheric transport.
lehpron
Sat Oct 28, 2006 11:57 am
Quoting GrandTheftAero (Reply 2):
Don't worry about it, I had a more detailed question and was running late to class, so I shortened it.
You are right though, I was relating this to just about every other hypersonic wave-rider concept that I have seen which had the ramp up front to lift and for the engines to compress the air. For all the data I could find, none refer ed to subsonic performance with these configurations. I had to try to estimate a body based on a delta wing, with a high dihedral and an angle of attack equalling the body's ramp angle. My results: A plane of mass similar to a 757 with twice the wing area wouldn't takeoff until about 265kts!
With performance like this, its subsonic cruise would be shotty. Since the B-1 slows to subsonic to drop bombs (which it takes care of the AoA issue with its swinging-wings), my questions are:
  • Does the payload disperse below Mach 1 requiring the vehicle to waste valuable energy to slow and re-accelerate?
  • Does the payload get dropped 'in space', like a projectile?
  • If, heaven forbid (at least in my mind), the bay doors open while in the atmosphere and sonic, would payload dropped experience a kind of ground effect resulting the sudden change from the still-air bay environment to the high pressure compression zone of the lower body outside? Would the munition 'float' for a a second (potential bay recontact) before dropping away?
  • Quoting Lumberton (Reply 3):
    Air gets thinner as you go up higher, it doesn't go to zero, per se. For a scramjet powered plane to work it must already be in motion many times the speed of sound. Air compresses approximately per square of the Mach number. Thin air combined with really high speed thickens the air for the engines to use and lifting the plane. The higher you go the faster you need to be. This was/is the idea behind SSTO (Single Stage To Orbit) vehicles that used hybrid engines of rockets and scramjets.
    Speed isn't the only thing; Aeroenvironment (funded by NASA) built a solar-electric-powered airplane that flew above 25 miles up at around 20 KTAS, that plane compensated by having a massive aspect ratio and was really light.
    grandtheftaero
    Sun Oct 29, 2006 5:02 am
    Quoting Lehpron (Reply 5):
    You bring up a good point. High-speed weapons release was what I first thought of when I saw this configuration. I'm an engine guy so this topic far outside my comfort zone but just what I know about aerodynamics tells me that opening up a weapons bay at hypersonic speeds is a bad idea.
    Users browsing this forum: HBJZA, ooslc, xbgb2003 and 2 guests
