USairways16BWI
No Flaps Landings...
Thu Nov 02, 2006 4:19 am
i would be worried if we started our decent, put down the gear and started approach, and still not putting down the flaps. i came across this pic
Photo © Anthony Jackson
If this is not that unusual, what would the circumstances have to be to land without flaps? And if its not, what is the problem? Light weight? strong headwinds?
RE: No Flaps Landings...
Thu Nov 02, 2006 4:22 am
The only case I can think of is if the flaps aren't working. The angle of incidence seems higher than usual as well.
Take-offs without flaps are possible in some aircraft (F70/100, A300) but I don't think they are kosher on the 330.
[Edited 2006-11-01 20:23:56]
aviopic
Thu Nov 02, 2006 4:32 am
I am not so sure this is an approach, looks more like take off to me.
There is quite some jetblast visible which to me indicates take off power instead of flight idle running engines.
Also the angle of attack seems a bit weird for a flare.
The truth lives in one’s mind, it doesn’t really exist
Goldenshield
Thu Nov 02, 2006 4:37 am
The note on the picture indicates a flapless landing.
Most likely, he's using a moderate power setting and a high angle of attack to arrest his descent and slow his airspeed down at the same time; i.e., he's on the back side of the power curve.
Tristarsteve
Because a flap asymmetry would be disastrous to flight, there are sensitive systems in place to stop it. Normally the flaps are driven by a single hydraulic motor in the undercarriage bay, driving rotating shafts out to the flaps. On each end of these shafts are rotary transmitters which tell thr Flap Control Unit how much they are going round. If the shafts become out of sync, the FCU cuts power to the Flap Motor and the flaps stop. Beside the transmitters are brakes that come on as well. Quite often , on the Tristar for example, these brakes can only be reset by a mechanic climbing up to them with a spanner. So a defect in the flap system and the flaps are stopped until you land. So a flapless landing can ensue. This is not so common nowadays, but not unusual in the past. It means you have to land much faster, and need a longer runway to do it.
The slats are driven and controlled by a similar system on the Tristar and also have brakes.
This is all very necessary because if one wing's flaps drove out, and not the other the aircraft would roll well beyond the aileron authority.
aviopic
Thu Nov 02, 2006 4:46 am
I know how the various systems work guys, it's my day time job.
Also I know that if you don't have flaps due to a failure you have little to choose from.
Still looking at this photo my impresion is: Take Off.  Smile
Quoting Goldenshield (Reply 3):
People can do weird things for a few extra hits. Top Rated Photos (by Javibi Nov 1 2006 in Aviation Photography)
Ralgha
Thu Nov 02, 2006 5:19 am
Quoting Starlionblue (Reply 1):
You mean the angle of attack? Pitch angle? The angle of incidence is the same as every other A330-301 out there.
atct
Thu Nov 02, 2006 5:31 am
Ive done a no-flap landing in a Saab 340. Hydr. Failure. It happens occaisonally. All ya have to do is fly the appch a little flatter and faster.
ATCT
Trikes are for kids!
AirWillie6475
Thu Nov 02, 2006 5:34 am
Quoting Aviopic (Reply 5):
Dude, do you know how an airplane flys? Not having flaps on takeoff could be disastrous if the plane is not designed for flap less takeoffs. It won't be airborne even it's going well above the normal takeoff speed. Not having flaps on landing is not a big deal since the plane is already airborne.
aviopic
Thu Nov 02, 2006 5:42 am
Quoting ATCT (Reply 7):
Correct, now look at the pitch angle.
Which is why is why I think it looks strange for a flare even in case of a forced flapless landing.
Quoting AirWillie6475 (Reply 8):
Temper your voice a little young boy.
Back to the study books my friend.
BoeingOnFinal
Thu Nov 02, 2006 6:12 am
From what it looks like, the AoA is to much to land, it would be to great a risk. Isn't the procedure to increase Vref speed, and then the AoA would be decreased?
Might get tricked by the photo, but it looks close to 10 degrees of pitch, which would be close to 11-12 AoA if the plane was on approach.
I know little about A330, but a 737 rotates 3 degrees per second on rotate point, witch would look pretty similare to this on a takeoff.
norwegianpilot.blogspot.com
SlamClick
Thu Nov 02, 2006 6:15 am
No-flap landings were a QRH procedure so I don't have the good skinny in front of me, but they were pretty serious - very high landing speeds. Might even have been the reason for the big Bus having 235 MPH tires where the usual standard is 225.
As you well know, takeoffs are optional; landings are mandatory. A no-flap landing might become necessary (What else are you going to do? Leave it up there?) But a no-flap takeoff is not an authorized maneuver in the A-330.
The only real question here is why the photographer didn't get the firetrucks in the shot. They sure as hell should have been chasing this plane.
474218
Thu Nov 02, 2006 6:18 am
Quoting TristarSteve (Reply 4):
Steve,
On the L-1011 only the slat brakes require a spanner (9/16") it pushes the plunger in and unlocks the brake. The flaps have a knurled knob that extends and can be pushed in by hand.
I have a funny story about the L-1011 slat asymmetry brake. I spent over twenty years in L-1011 product support and the flight controls was one of the systems I covered. In Product Support we were on call 24 hours a day. So on Christmas day about 1986 we had just sat down to Christmas dinner, when I got a phone call from a ATA mechanic in Minneapolis. He asked how many foot pounds torque does it take to reset the slat asymmetry brake? I said I didn't know exactly but a 9/16" wench (spanner) pulled with one hand is all I ever used. He said he weighed 180 pounds and he had hung on a one foot long breaker bar and the brake would not reset. I told him to change the brake because there must be something broken inside and when back to my now cold Christmas dinner. About two hours later the same mechanic calls me back and says he has finally reset the brake and the system been checked out. Then he proceeded to tell me that its 20 degrees below zero in Minneapolis and by putting a heater on the brake for an freed it up.
As for the original picture, the A330 is landing, the horizontal stabilized would be trimmed further nose down if it was taking off.
CRGsFuture
Thu Nov 02, 2006 6:21 am
Well the question is now, wouldn't pitching the airplane up at this speed allow some of the thrist to bleed off into lift. I know when I do no flap landing with the C172 my instructor tells me to pitch up a little more to allow air to bleed off and try to get to the 65 kts speed.
Flying you to your destination; your girlfriend to her dreams.
SlamClick
Thu Nov 02, 2006 6:33 am
Quoting 474218 (Reply 12):
Not only that, but if it was taking off, it would still be solidly on the ground. Ground run would be well beyond the end of the runway and VR higher than tire speed limit.
Quoting CRGsFuture (Reply 13):
Swept-wing A-330 vs straight-wing airplanes, virtually no basis at all for comparison. HUGE differences in flying characteristics.
Thu Nov 02, 2006 6:35 am
Quoting Ralgha (Reply 6):
Brainfart sorry.
Quoting SlamClick (Reply 11):
I agree. But I didn't say that first thing. Dang forum automation.  Wink
BTW nice to have you back Captain Click.
Tristarsteve
Thu Nov 02, 2006 6:39 am
Must be 20 years since I reset a L1011 Flap brake. Sorry got them back to front.
When we first had the A320 in 1988, we regularly got slats locked on engine start. Like every 10th departure. They have a mechanical lock, but you can reset them through the CFDS in the cockpit.
But they must have modified them because it hasn't happened for years.
474218
Thu Nov 02, 2006 7:08 am
The "Angle of Incidence" is the FIXED angle that exist between center line of the aircraft and cord line of the wing. So it can't look higher than usual, because it FIXED.
runway777
Thu Nov 02, 2006 7:18 am
i agree
"kalli, be the best pilot you can be, who happens to be a girl" -Joe White
CosmicCruiser
Thu Nov 02, 2006 7:33 am
Quoting SlamClick (Reply 14):
Oh so right, In the MD-11 a no flap ldg is a big deal where you want to be as light as possible because Vapp will be very high and close to max tire spd. A long rnwy is needed and very little flare to prevent any floating.
XFSUgimpLB41X
Thu Nov 02, 2006 7:41 am
No flap landings in the CRJ are a big deal as well.. our max tire speed is 182... at heavier landing weights you are running right up on that speed.
Same technique as Cosmic mentioned... it is definitely a situation where you want to have the trucks standing by. Unfortunately on the CRJ a no flap landing is the most common emergency... I believe there are a couple occurences a month.
I have been pretty lucky and have only had my flaps fail at 20, which is a faster approach (in the 160's at most normal weights) but not as critical as a completely clean wing.
Chicks dig winglets.
Thu Nov 02, 2006 8:54 am
Quoting 474218 (Reply 17):
Yeah I knew that. Just had a brainfart.
Then again, I can think of two aircraft with variable angle of incidence.
[Edited 2006-11-02 00:55:05]
SlamClick
Thu Nov 02, 2006 9:06 am
Quoting Starlionblue (Reply 21):
Well, if the chord line is a straight line from trailing edge to leading edge all airplanes with trailing edge flaps, leading edge flaps, slats or droops have variable incidence.
BTW I can only think of the wonderful F-8 Crusader. What am I overlooking?
2H4
Thu Nov 02, 2006 9:14 am
Quoting SlamClick (Reply 22):
The Martin XB-51:
Although, I can think of one more.....
2H4
Edit: Correction.....two more....
[Edited 2006-11-02 01:16:23]
Intentionally Left Blank
SlamClick
Thu Nov 02, 2006 9:20 am
Quoting 2H4 (Reply 23):
The Martin XB-51:
You're not talking about the big crack that showed up in the wing when William Holden was flying it?
2H4
Thu Nov 02, 2006 9:25 am
Quoting SlamClick (Reply 24):
No, that crack supplemented the stock variable-incidence wing with which it came equipped from the factory.  Smile
There are actually four additional aircraft that are/were equipped with variable-incidence wings.....
2H4
oly720man
Thu Nov 02, 2006 9:26 am
Here are some other aircraft landing at around the same point, with flaps, for the sake of comparison....
Photo © David James Clelford
Thu Nov 02, 2006 9:33 am
The other one I had in mind is the Corsair, which in the end is a modded Crusader.
Trust 2H4 to go into orbit as usual. Big grin
474218
Thu Nov 02, 2006 9:48 am
The Corsair II (A-7) did not have the variable Angle of Incidence the F-8 Crusaders did.
Photo © David Ilott
2H4
Thu Nov 02, 2006 9:53 am
Quoting Starlionblue (Reply 27):
I didn't think the Corsair had a variable-incidence wing....  confused
Heh heh...I do what I can...  biggrin
Here are the others I've come up with:
Supermarine Seagull:
Supermarine 322 (S.24/37) Dumbo:
http://i12.tinypic.com/3yyqqdg.jpg
And, of course, all of these contraptions:
 Wink
2H4
Quoting 474218 (Reply 28):
Learn something new every day. Thx!
vzlet
Thu Nov 02, 2006 10:07 am
Incidence on the Martin XB-51 was adjustable:
"That's so stupid! If they're so secret, why are they out where everyone can see them?" - my kid
AJ
Thu Nov 02, 2006 10:13 am
Quoting Aviopic (Reply 2):
I would have though my portfolio held enough credibility for you not to suggest such a thing, but just to satisfy you:
2H4
Thu Nov 02, 2006 10:24 am
Man, I love that last shot, AJ. Nice work on all of them!
2H4
474218
Thu Nov 02, 2006 10:55 am
Those A330's are really hot, they can smoke their tires on takeoff.
By the way AJ great photos.
OPNLguy
Thu Nov 02, 2006 11:35 am
You know, for eons, I've always wondered what that aircraft from "Towards The Unknown" was--now I know (finally!)  Wink
Back to the original topic, wasn't there a recent thread about a passenger(s) freaking out because the A300 they were on was landing or taking off (can't recall which) with zero flaps, and that, for the A300, zero flaps were a normal setting?
vzlet
Thu Nov 02, 2006 9:39 pm
The Martin XB-51
Quoting Vzlet (Reply 31):
Not sure how I missed 2H4's heavily illustrated post. Sorry about that!
MDorBust
Thu Nov 02, 2006 11:45 pm
And, much further down the runway.
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
AJ
Fri Nov 03, 2006 5:50 am
Quoting 2H4 (Reply 33):
2H4
Quoting 474218 (Reply 34):
Thanks very much guys!
onetogo
Fri Nov 03, 2006 1:18 pm
Quoting OPNLguy (Reply 35):
Yeah, was pretty amusing. As far as I know, the A300 departs regularly with no flaps, however they do throw all of the slats out.
thegreatchecko
Sat Nov 04, 2006 6:18 am
True, but some of the newer electronically controlled aircraft, like the A320 you refered to, can be quite tempermental. I was co-pilot on a brand new aircraft that was having electrical signaling issues that caused the flaps to fail.
As I am sure you are intimately familiar, the computers work great when everything is "happy", but the moment something goes just a bit off, it goes to hell.
Yes it does, but unlike in a Cessna 172, where lowering the flaps may allow you to fly 20 or so knots slower without stalling at max weights, flaps in a heavier swept wing aircraft allow you to fly 60 maybe 70 knots slower, especially when they are heavy.
In other words, flaps affect the lift generating characteristics of the wing much more dramatically in a heavy jet than in a straight wing cessna. Without the flaps out, the plane simply will not fly anywhere near as slow as it would with flaps, thus the higher landing speeds.
I never was too good at the technical aerodynamics explanation, but these usually worked pretty well to get the point across without going too nuts and getting too complicated.  Smile
Checko
"A pilot's plane she is. She will love you if you deserve it, and try to kill you if you don't...She is the Mighty Q400"
XFSUgimpLB41X
Sat Nov 04, 2006 12:49 pm
So about those zero flap landings..
I did not one.. but TWO today. Same plane broke twice. 170 knots and 173 knots respectively down final. I'll post more later.
AgentM
Sun Nov 05, 2006 1:28 pm
No doubt it is landing, if you look at a larger image, you can see taxiway A3 past the airplane which is near the 16R end of the runway.
Here's a sat image centered on A3 -
http://maps.google.com/maps?f=q&hl=e...n=0.016819,0.043259&t=h&iwloc=addr
EridanMan
Thu Nov 09, 2006 2:39 pm
How Fundamentally Similar are no-flaps landings in a Heavy to their smaller cousins? (PA-28-140).
I did a half dozen flap-less landings in my Cherokee a few days ago for the first time, and as a low-time pilot, I'll tell you- the touchdown deck-angle was almost scary (I was honestly concerned about a tail-strike, and I couldn't see the runway at all).
It seems to me that this bird is the exact same type of configuration, and it strikes me as simple physics... Flaps increase drag and lift... Flying at a higher AOA increases lift and drag... same basic principle, flaps just make it a lot easier.
CF188A
Mon Nov 13, 2006 2:50 am
could this just have been like a 40+ MPH headwind ... or something of the sort... in which flaps would actually complicate a landing. I have been on approach many times where I felt as though i could walk faster than the plane itself. Have you ever flown , your aware of your quick approach speeds, the flaps drop quickly, and it feels as though u are going 90 degrees directly up ? The compensation required is obviously a greater pitch. Lets say the winds were extremely strong or gusting like crazy no allowing for a stable landing, could it be possible they would land with no flaps? Just a question so dont rip me apart.
Dream as if you'll live forever. Live as if you'll die tomorrow~ RIP ... LJFM
pilotaydin
Mon Nov 13, 2006 3:02 am
this a/c is France registered, i bet it was being tested for delivery to a new owner  Wink
The only time there is too much fuel onboard, is when you're on fire!
AJ
Thu Nov 16, 2006 11:09 am
Quoting Pilotaydin (Reply 45):
Sorry if you are joking, but most of PAL's widebody Airbusses carry French Overseas regsitrations (F-O).
