ZBBYLW
Differences In AC's 767-300?
Thu Nov 02, 2006 10:11 am
Hello all i have a question regarding difference in doors on AC's 763 fleet. In one of these examples we have the first sets of doors followed by two sets of window exits and a final door at the rear. Fair enough. Now in the other example we have 4 sets of doors going down the fuselage. Now i believe these would have come from CP. But still with all that aside what is the purpose of having an identical aircraft have two different options in door placement. I know that at least two of the AC 763s that have the 4 full exits have what AC refereed to as AC Club seats upfront, and a regular Y cabin. But can not confirm weather that is the same on all of these aircraft. For those of you that are interested here are two pictures of the aircraft.
Photo © Pierre-Leo Bourbonnais
Photo © Eric Fortin - AirTeamImages
Keep the shinny side up!
OB1504
RE: Differences In AC's 767-300?
Thu Nov 02, 2006 10:31 am
Perhaps it could make for easier boarding?
With the door configuration found on C-GGFJ, economy class passengers could board through the L2 door and not have to go through the first or business class cabins.
YWG
Thu Nov 02, 2006 11:32 am
It's basically just the difference between the original Canadian Air and Air Canada birds.
Contact Winnipeg center now on 134.4, good day.
Viscount724
Thu Nov 02, 2006 12:29 pm
Quoting YWG (Reply 2):
Sorry, that's not correct. I am almost certain that all 763s delivered new to Canadian were the 4-door model (2 main cabin doors at the front, 2 at the rear, and 4 overwing emergency exits) as were all 763s delivered new to AC.
I believe AC only has a couple of 6-door 763s with extra pair of doors just ahead of the wing, and those aircraft did not originate with either CP or AC. The one in the photo iabove did go from CP to AC but it was originally delivered to Aer Lingus and had several other operators including SAS before CP. The 6-door 763s were generally ordered by carriers based outside North America.
Following photos of 2 of CP's original 763s showing the 4-door layout.
Photo © Joe Pries - ATR Team
Photo © Philippe Noret - AirTeamimages
ZBBYLW
Thu Nov 02, 2006 12:35 pm
Quoting Viscount724 (Reply 3):
Great, thanks for the info i was not aware of this. Do you or does anyone else know what the difference was for. Was it to make boarding easier on the 6 door models. If so why are there the 4 door models with the 4 over wing exits. Thanks in advanced.
Cheers Chris
474218
Thu Nov 02, 2006 1:17 pm
The different door configurations were customer options and determine the maximum number of passengers:
The first photo the Hainan 767-3BG/ER has 3 pair of Type A door and 1 pair of Type III doors. The maximum seating is 290.
Photo © Yu Ming
The second photo the Delta 767-332ER has 2 pair of Type A doors and 2 pair of Type III doors. The maximum seating is 290.
Photo © Mark Mahu
The third photo of the British 767-336ER has 3 pair of Type A doors and 1 pair of Type I doors. The maximum seating is 351.
Photo © Marlo Plate - Iberian Spotters
ZBBYLW
Thu Nov 02, 2006 2:35 pm
Quoting 474218 (Reply 5):
474218 Thank you very much for this very informative answer.
Cheers Chris
474218
Fri Nov 03, 2006 12:52 am
Chris,
Thanks for the kind words. Remember you can only put as many passengers in an aircraft that can get out in 90 seconds. So those bigger doors on the BA 767 allow for faster evacuation times.
Carl
vikkyvik
Fri Nov 03, 2006 2:38 am
Quoting 474218 (Reply 7):
Question regarding the two versions that each have 4 door-pairs:
Shouldn't the Hainan aircraft with 3 pairs of Type A doors and 1 pair of Type III doors be able to seat more passengers than the Delta aircraft with 2 pairs of each, as the Hainan aircraft has a larger percentage of bigger doors?
I had thought that Type A doors could allow for evacuation of 2 people at once.
~Vik
jlb
Fri Nov 03, 2006 3:05 am
Does anybody here know how many were build of each type? I would imagine the "A iii iii A" version is by far the most common.
And why did BA chose the "A A i A" version, they do not exactly have high density seating, not even in their european configuration.
Viscount724
Fri Nov 03, 2006 5:11 am
Thanks for the further information and photos of the 3 different door configurations. I think the 763 is fairly unusual in offering that many optional door/exit configurations, although the DC-8-61/62/63 also offered a variety of door/window options (see last two photos below).
Some older types had variations depending on the model, especially combi models such as the 707-320C and DC-8-50F which had an extra emergency exit (slightly taller than the standard overwing exits) approximately even with the rear edge of the wing. That was to meet evacuation requirements since the overwing exits could be within the cargo compartment and unusable by passengers when the aircraft was used in mixed passenger/cargo configuration.
Example of all-passenger 707-320B with only the front and rear doors and 2 pairs of overwing exits, and 707-320C with main deck cargo door and the extra slightly taller emergency exit just behind the wing:
Photo © Kjell Nilsson
Photo © Bob Harrington - Bobqat Photographs
And all-passenger DC-8-62 and combi -62CF with main deck cargo door and extra exit in similar location as 707-320C:
Photo © Trevor Ogle
Photo © Marcel Walther
Example below of DC-8-63s with significantly different door/exit and cabin configurations. Have included photos of both sides as they're not the same. CP has the forward galley at the front of the aircraft but behind a small cabin with the two windows on the right side opposite the main passenger door onthe left side. That small cabin was used as a first class lounge although most of the time it had 6 economy class seats which were sold when demand warranted. That forward cabin/galley layout matched CP's earlier DC-8-40/50s. The KL DC-8-63 has the forward galley much further back, just ahead of the wing in the area where there are no windows. The forward passenger door is at the front on the left side as usual, but the galley service door on the right side is much further back in the galley area ahead of the wing.
Photo © Bob Garrard
Photo © Dré Peijmen
Photo © Gerhard Plomitzer
Photo © Robert Pittuck
474218
Fri Nov 03, 2006 6:03 am
Quoting Vikkyvik (Reply 8):
I got my information directly from the 767 Type Certification Data Sheet (TCDS) No. A1NM. Since the TCDS is a FAA document I don't try and interrupt what they say I just report what the read.
CanadianNorth
Fri Nov 03, 2006 10:35 am
Just look at the specific type of 767-300.
Boeing uses customer codes for most of its aircraft. For example, you will always see the full name as Boeing 767-3xx, with xx being the customer code. The customer code for Air Canada is 33, and for Canadi>n Airlines it is 75.
So...
-333/ERs were delivered new to Air Canada.
-375/ERs were delivered new to Canadi>n Airlines.
-Pretty much anything else will have come from other carriers.
For example, look at the thread starter's photos. First photo is a -375/ER, so it was delivered to Canadi>n brand new from Boeing. The second photo is a -3Y0/ER, therefore it came via another carrier (or multiple carriers). Reason why the doors are different: Canadi>n used the setup seen in the first photo, and whoever as Y0 for a customer code opted for the configuration seen in photo 2.
Canadi>n Airlines was bought out and merged into Air Canada, making the majority of Air Canada's Boeing fleet a mix of 33s and 75s.
CanadianNorth
Way to go, nice and slow, never late, 748!
411A
Fri Nov 03, 2006 10:42 am
As to the type of doors, and the maximim seating allowed, lets look at two examples.
Lockheed TriStar (standard body airplane).
Most were delivered with six large doors and two smaller doors at the rear.
Maximum seating 365 (IIRC).
However, several were delivered with eight large doors, and in this case the maximum seating allowed is 400.
B707-320B/C
Most were delivered with 2 entry doors, 2 galley doors and 4 overwing exits.
Maximum seating, 189.
However, some were also ordered and delivered with the above, and in addition, two extra exits just aft of the wing, one or each side.
Maximum seating, 215.
What the original customer wants, the customer gets...at extra cost, of course.
vikkyvik
Fri Nov 03, 2006 11:03 am
Quoting 474218 (Reply 11):
Fair enough. Thanks for providing the data.
Quoting 411A (Reply 13):
Interesting examples. Thanks again.
~Vik
LTU932
Fri Nov 03, 2006 3:16 pm
DL also has a few 767-3P6ERs from Gulf Air with the three pairs of Type A doors and one pair of Type III doors. They also have at least one 767-324ER, originally built but for never delivered to CO, with the same configuration as the ex GF aircraft.
Photo © Mick Bajcar
Photo © Darren Wilson
Quoting CanadianNorth (Reply 12):
Y0 stands for GPA Group. I guess it's a leasing company, so who knows why they ordered the aircraft with that configuration.
Users browsing this forum: Google [Bot], Okcflyer and 13 guests
