QFA380
Why No Retractable Gear On Aerobatics Planes?
Fri Nov 03, 2006 4:54 am
Why do no aerobatics planes have retractable gear? I have never seen one that does. Wouldn't it help quite abit if the plane was more streamlined?
Photo © Rob Epstein
Photo © Fanie Kleynhans
Photo © Howard J Curtis
2H4
RE: Why No Retractable Gear On Aerobatics Planes?
Fri Nov 03, 2006 5:01 am
Quoting QFA380 (Thread starter):
Weight. Aerodynamics are comparatively less important, as aerobatic aircraft spend the majority of their time in low-speed flight.
2H4
Intentionally Left Blank
KELPkid
Fri Nov 03, 2006 5:03 am
A Couple of guesses here:
The gear hanging out in the breeze helps generate drag (which can be a good thing in aerobatics...you might not want a plane that picks up speed in a hurry when you point the nose below the horizon). Also, a hydraulic pump (for a conventional single) would be an added, unecessary complication.
BTW, I can think of one common aerobatic aircraft with retracts (although it is ex-military): the T-34:
Photo © C. Nolan Huizenga
ZBBYLW
Fri Nov 03, 2006 5:09 am
Hey i have thought about this too. I think both the answers above are good answer but perhaps also the added stress of +/- 10 G's on an airplane with retractable gear would be a bit much and to strengthen them, the weight comes back into the picture. Also the thought like posted above off the added drag is very interesting indeed, but it just doesnt look as cool when doing a low and over.
Cheers Chris
Keep the shinny side up!
FredT
Fri Nov 03, 2006 6:36 am
Weight for a very small benefit in the intended regim of flight is the main reason, just as stated above. No doubt about it. Complexity and cost would be two other reasons. Why mess with and pay for a gear retraction system when you get very little, if anything, in return?
Rgds,
/Fred
sprout5199
Fri Nov 03, 2006 8:24 am
Quoting KELPkid (Reply 2):
And if the need to overcome the drag arises, just put a bigger engine on it. I'm sure the aero pilots would say "hmmm bigger engine? Is good"
Just my  twocents
Dan in Jupiter
QFA380
Fri Nov 03, 2006 9:02 am
Thanks for all you replys, has cleared up something I have been thinking about for a while.
Users browsing this forum: ansonchristo and 4 guests
