LTU932
Is Re-engining A 747-400 With Trent 500s Possible?
Sun Nov 05, 2006 6:59 am
I don't know if this has been discussed before, but here it goes. I was thinking about any possible re-engining of the 747-400 with newer engines to increase service life and also fuel economy. More specifically, re-engining with the Trent 500 Series. I know the 747-400 isn't very old at all, but nevertheless, it's an idea, albeit a hypothetical one. Here are my questions:
1. Is it technically possible to install Trent 500 engines on a 747-400? If yes, what would such a re-engining involve in terms of modifications?
2. Would it be economically viable to perform such a re-engining programme?
3. How would the Trent 560 or 556 impact flight performance and also fuel burn on the 747? Would the Trent 500, at the same certificated MGTOW of a 747 reduce or increase its payload range?
4. How much thrust must the Trent 500 series produce for application on the 747?
I'm looking forward to your thoughts on this.
- Richie
Leezyjet
RE: Is Re-engining A 747-400 With Trent 500s Possible?
Sun Nov 05, 2006 7:29 am
Quoting LTU932 (Thread starter):
Anything is possible, so I would say yes. If they can install a GE-90 on a 747 then I'm sure that a Trent 500 would not be a problem.
Maybe in the future, like with the DC-8's and KC-135's being fitted with CFM-56's to extened the life, but it would depend on the cost of the modifications and the savings it would generate over the a/c life span from the point the modifications were done and whether it would be more cost efficient to park the a/c up and but another newer a/c.
Don't know you last 2 questions, that is highly technical info you are asknig for that would take some calculation to do.
 Smile
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
N231YE
Sun Nov 05, 2006 11:52 am
Well, considering the weakest engine option for the 747-400 is the P&W4052 (Based on info from PW, GE, and RR) putting out 52,000 lbs of thrust, I would assume either that or higher. Because both of the Trent 553 and 556 produce 53,000 lbs or more(RR), the thrust range alone seems possible. However,
I am not sure the weights on the engine, as well as other things into consideration. Being that the Trent 500 series is a newer and more advanced engine, it should be more efficient than the old RB.211's originally developed for the L1011. However, the -524G/H-T is a newer and more highly efficient RB.211 model, so that could also come into play. Someone with a higher knowledge in this field may elaborate better.
jetmech
Sun Nov 05, 2006 1:05 pm
G'day LTU932   ,
I'm no expert on this sort of thing either, but I will throw in my 2 cents anyway.
As Leezyjet mentioned, a GE-90 was fitted to a 747 for testing. Since a T-500 is much closer in size and weight to the current crop of B744 engines, it would appear to be feasible. The major modification required would be new struts. I suspect that the interface between the strut and wing is the same regardless of engine type, so most of the modification would be to the interface between the strut and the T-500.
This is more a question of non-technical factors of which I have no experience.
The following is what I presume as the maximum thrust engine option from each of the big three currently powering the B744;
Pratt & Whitney PW4062
63,300 lb (281.57 kN)
Rolls-Royce RB211-524H2-T
59,500 lb (264.67 kN)
General Electric CF6-80C2B5F
62,100 lb (276.23 kN)
RR gives the thrust of the T-556 as 56,000lb (249.1kN), so considering the less powerful engine options as mentioned by N231YE, it would seem that a B744 / T-556 combination would have a very similar MTOW.
My concern is whether RR have optimised the T-556 too much towards the A345 / A346 combination. The typical cruise speed of the B744 is 0.85M, whilst the Maximum Operating Mach Number (MMO) of the A345 / A346 is 0.86M. The B744 also has a higher wing sweep angle of 37.5 degrees compared to the A345 / A346 at 31.1 degrees.
Both of these suggest that the B744 was designed for, and is capable of a higher cruise speed. Since the A345 / A346 is the only current use of the T-500   , RR probably would have optimised it to have maximum efficiency at the typical cruise speeds of these aircraft. If the T-500 was used on the faster B744, these efficiencies (thermal, propulsive) may start to drop off. The end result may be less payload/range despite the engines probably having better fuel efficiency (TSFC?).
The maximum nominal thrust you can currently get from the T-500 is 56,000lbs (249.1kN). This is not as good as the most powerful options currently available from each manufacturer, but it is probably more than some of the less powerful options, as stated by N231YE.
http://www.boeing.com/commercial/747family/pf/pf_400_prod.html
http://www.rolls-royce.com/civil_aer...ts/airlines/trent500/technical.jsp
http://www.airbus.com/en/aircraftfam...0a340/a340-500/specifications.html
http://www.airbus.com/en/aircraftfam...0a340/a340-600/specifications.html
[Edited 2006-11-05 05:12:23]
LTU932
Sun Nov 05, 2006 2:24 pm
Quoting JetMech (Reply 3):
So, Basically, it's technically possible but in the end, the engine itself might to be modified extensively then, right? Thus offsetting the economic viability of such a re-engining programme due to the development costs of these modifications. In this case, what could be done to further optimise the engine for higher cruise speeds, like an Mmo of Mach .88 to accomodate for the 744's cruise speed (I'll designate it a Trent 600 series for this hypothesis)?
Isn't there a Trent 560 being built, which is supposed to be the engine of the A346HGW?
Thanks for your contributions so far.
[Edited 2006-11-05 06:25:40]
jetmech
Sun Nov 05, 2006 2:46 pm
Quoting LTU932 (Reply 4):
Basically, yes. The overall economic factors are always the most important issue. As is always the case, anything to do with aircraft seems to be astronomically expensive.
I'm not sure what engine modifications would be needed to optimise for a different cruise speed, but as you say, it may be cheaper to develop a new engine as opposed to modifying an existing one.
You are most probably right, I will look it up  .
[Edited 2006-11-05 06:48:37]
andz
Sun Nov 05, 2006 3:48 pm
Imagine a 747 with 4 of these  boggled
http://img.photobucket.com/albums/v155/andzz/45_FTB_Installation_09150007.jpg
Sun Nov 05, 2006 4:10 pm
Quoting Andz (Reply 6):
A 748 would look impressive with them! Too bad they have made those extra efficient engines like the GEnX..
A342
Sun Nov 05, 2006 9:55 pm
I don't think so. The PW4000 and CF6-80C are also used on the A300/310 and 767, which have a cruise speed of only about Mach 0.80.
But I think such a re-engine programme wouldn't be too useful. The Trent 500 is already technologically surpassed by other engines. If one wants to re-engine the 744, a more efficient engine should be used.
Exceptions confirm the rule.
SP90
Mon Nov 06, 2006 1:30 am
Quoting A342 (Reply 8):
Ding! Ding! Ding!  bigthumbsup
So when do you guys think we start seeing GEnx on older 747s?
A342
Tue Nov 07, 2006 2:07 am
Quoting SP90 (Reply 9):
False quote, NZ107 said that.
lightsaber
Crew
Tue Nov 07, 2006 4:37 am
Could it be done? yes. Will it? Economics will answer that. If it pays to re-engine a JT9D with CF6's... possibly.
Quoting N231YE (Reply 2):
But one little chip change fixes that. You're also talking engines slightly customized for very short hop operations. An unusual application on the 747 (The Japanese 744D's).
The maximum current certified thrust is 56k. A little birdie told me that they could be upgraded to 63k (after quite a bit of engineering though). Why maybe this thrust was from Airbus' thrust growth requirement on the A345/346...  scratchchin  naaa... I wouldn't ever have seen a document like that.  Wink
All engine lines have a thrust growth requirement. E.g., Boeing even has a thrust growth requirement for the GE90-115! Ok, usually there is a minimum time frame given. But the "rule of thumb" is 15% growth in thrust unless the airframer has a target or known "upper bound" (e.g., point at which both the wing at pylon cannot be cheaply reinforced). Rumors are the 777C required 125K thrust growth (unusually low, this is to allow more optimization at the 115K thrust point). Thrust growth requirements are far stricter if there is only one engine option for an airframe.
Lightsaber
LTU932
Tue Nov 07, 2006 5:24 am
But weren't both the PW 4000 and CF6-80 built based on the JT9D and CF6-50 respectively? Those were originally designed for higher speeds, especially on the 747.
Jetlagged
Tue Nov 07, 2006 7:18 am
Quoting NZ107 (Reply 7):
I'll say Big grin
Photo © David Oates
A342
Wed Nov 08, 2006 5:11 am
Quoting LTU932 (Reply 12):
The CF6-6, the very first version of the CF6, entered service on the DC-10, which also has a lower cruise speed. However, the differences between the CF6-6 and CF6-80 are quite big.
BTW, the CF6-80 entered service on the A300/310 and 767 before being used on the 744, so it was not specifically designed for the 747. The same should apply to the PW4000.
Also, the RR RB-211 first entered service on the L1011 before being used on the 747.
These might just be examples, but I think they show the speed difference between the different aircraft isn't really important.
legoguy
Fri Nov 10, 2006 7:14 pm
Nice! I have never seen a picture of a 747 with a 777 engine before! Is there any other photos of the whole aircraft flying with the engine?
Also airbus used there first a340-300 to test the a340-500/600 engine as well as the a380 engine. They also used the left inner engine to perform the tests. Is there any reason why both manufacturers used the same side to test the engines?
Can you say 'Beer Can' without sounding like a Jamaican saying 'Bacon'?
BOEING747400
Sat Nov 18, 2006 4:13 pm
Maybe they could design more unique versions of the Trent 500 series more suitable for the 744 than either 345 or 346? An example would be like Trent 560 (60,000 lbs thrust) for basic 744 and Trent 565 (65,000 lbs thrust) for 744ER. I guess you could also make the Trent 570 (70,000 lbs thrust) for 748 as well. Then the 744 series would have new engines instead of being forced to retire due to old age.
sunrisevalley
Mon Nov 20, 2006 5:55 am
Seems to me that NZ incorporated a Trent section ( not sure which one) into their RB211's to improve fuel burn. Not sure if they did all their engine inventory or not.
prebennorholm
Fri Nov 24, 2006 7:21 am
When talking reengining of old planes, then only very few examples have been seen.
Talking about Trent 500 on the 744, then it must be kept in mind that such engines carry a price-tag in the $10M range. Four of them is similar to the price of an all new 737 or 320 plane. There has to be a substantial advantage to make such a program viable.
I am not aware of one single civil jet airliner reengining program where the main driving force was not that otherwise the plane would be doomed for noise reasons, or would be seriously handicapped by hushkits. That counts for the 721 Tay, 722 PT-8-2xx, and the DC-8-6x CFM56 programs.
That a GE-90 can be mounted on a 747 wing for test purposes (as seen in reply #6) proves nothing. It is not integrated with the plane at all. It takes off and lands as a three engined plane - no problem when not heavily loaded - and the GE-90 test engine is during flight test not operated by the flight crew at all. It is operated by a minor army of engine test engineers in the cabin.
The flight crew only has instruments where they can read current N1 speed of the test engine, and then the captain has the authority to let the test engineers shut it down, should it be needed because something else goes wrong on the plane.
To really integrate a different engine with a plane requires an R&D program with costs running into dozens of million $$$.
So there has to be a range of things considered before such a program can be initiated:
- There has to be a very significant efficiency gain, most likely due to the planes otherwise being crippled by noise restrictions or hushkits.
- There must be a substantial number of customers to make the R&D and certification programs viable.
- The planes must have decades of residual lifespan.
I can't imagine that all those considerations can come out with a black bottom line figure for the B744.
andz
Sat Nov 25, 2006 1:09 am
Quoting Legoguy (Reply 15):
Photo © Jet City Aviation Photography
Photo © Je89 W.
I just put the second pic in to show a better perspective of the SIZE of that GE-90!
xv408
Sat Nov 25, 2006 1:33 am
Ref the NZ 524G and Trent fit, that is the 524G-T, which uses an HP system that is more or less a Trent 700. Similarly the 524H-T. Significant improvement in efficiency.
xv408
Sat Nov 25, 2006 1:41 am
On the OP, also bear in mind that take-off thrust and cruise thrust are not necessarily directly related, so even though T500 and 524G have similar take-off thrust, the cruise thrust of the T500 may be down some way. So it would have to be run harder, which moves the engine away from it's maximum efficiency. The T500 is also 1500lb heavier than the 524G (assuming the charts are comparing simialr powerplants). This probably reflects in part the much higher bypass ratio of the T500 (7.6 vs 4.3).
legoguy
Sun Dec 10, 2006 11:34 pm
Quoting Andz (Reply 19):
Thanks for those pictures. I was looking around youtube and came across this video of the 747 with the 777 engine
http://www.youtube.com/watch?v=BZW0zA1r6bE
BOE773
Mon Dec 11, 2006 1:58 am
It would be much smarter to re-engine 747s with modern GEnx powerplants instead of old Trents. There would be much more in fuel savings.
jetmech
Mon Dec 11, 2006 3:52 pm
Well look who's back  Wow! !
Quoting BOE773 (Reply 23):
I believe that the RR Trent 1000 is a very new engine design, and of a similar "vintage" to the GEnx. Perhaps it would also make a good alternative to the Trent 500 in the remote possibility that the 744 gets re-engined scratchchin ?
N231YE
Tue Dec 12, 2006 6:15 am
I'd hate to break it to you BOE773, but the the GEnx is no better than the Trent 1000. They both are more advanced versions of existing engines. As a matter of fact, the composite fan case and blades are not new to the GEnx, having been developed for the GE-90.
LTU932
Tue Dec 12, 2006 6:58 am
I started this thread so we can have a civil discussion with aviation experts on the viability of such a re-engining programme and my questions have been answered, for which I'd like to thank all those who contributed.
Quoting BOE773 (Reply 25):
I was banned for a month 'cause they did not like my reference to the fried tail end of a Trent!!
They just can't take some critisism!! They might ban me again for these remarks like a bunch of immature kids. As if I care.
I'd be interested in the Trent 1000 specific differences from it's ancestors.
I doubt that it will have a composite fan case and composite fan blades like the GEnx.
BOE773, please, if you can't contribute positively to this thread I started, then please leave. I didn't post this, so you can hijack it with just saying that the GEnx is better than the Trent 500 without a detailed explanation on why it would be better. I have enough of your Rolls Royce bashing, OK?
BOE773
Tue Dec 12, 2006 7:00 am
I'd expect the latest GEnx to have a higher power/weight ratio than the latest Trent as the former will have more composites.
The original post was for re-powering the 747-400 with Trent 500s.
Can you imagine how ludicrous this would be.
tepidhalibut
Tue Dec 12, 2006 7:13 am
Nice to see the GEnx catching up with the RB211.  I seem to recall the original RB211-22 had composite wide-chord fan blades, and the 535E4 introduce the Kevlar fan containment system. Now, I don't argue that the GEnx has even more up-to-date materials, but it's not surprising with 35/25 years more experience.
If you could wait a moment, I'll put on my flame-proof underpants. I'm sure I'll need them.
EDIT : Apologies for the BOE773-baiting: it's an instinctive reaction. (Like picking at a scab.)
[Edited 2006-12-11 23:18:23]
litz
Sun Dec 17, 2006 2:49 am
A couple years back, I was in MCO, and DL had a 738 parked right next to a 777 ... you could clearly see the engine on the 777 was as large as the whole fuselage of the 737 ... and that's with RR engines, not the "big boys" ...
- litz
BOEING747400
Sun Dec 17, 2006 6:07 am
I would think that it's more economically and financially viable to produce new 744 aircrafts with entirely different engines from the older GE, PW, and RR ones from the past. Therefore, I imagine that Boeing could manufacture upgraded 744 and 744ER models with brand new GEnx and/or RR Trent engines in the 60,000-70,000+ thrust levels for higher cruising speeds like Mach 0.88 and longer ranges like 15,000+ kms. Then the updated 744 models could become more competitive against their Airbus counterparts such as the 345 and 346.
I'm afraid the above scenario probably wouldn't be possible because Boeing has already started to advertise and market the new 748 as a replacement by now.
LTU932
Sun Dec 17, 2006 2:09 pm
Quoting BOEING747400 (Reply 30):
What about the wing? Would they have to re-design the wing for it to cope with? Wouldn't this thus also require that the Mmo be increased and other aerodynamical improvements be done for a Mach .88 cruise to be possible?
baroque
Sun Dec 17, 2006 10:46 pm
Quoting TepidHalibut (Reply 28):
Wonderful analogy, better than that of scratching the swelling of a mosquito bite.
I don't suppose there is any point in mentioning to him that there are details of the Trent 500 at
http://www.rolls-royce.com/civil_aer...e/downloads/airlines/trent_500.pdf
and for more details
http://www.rolls-royce.com/civil_aer...ucts/airlines/trent500/default.jsp
or for the Trent XWB at
http://www.rolls-royce.com/civil_aer...e/downloads/airlines/trent_xwb.pdf
and
http://www.rolls-royce.com/civil_aer...lines/trentng/technology_flash.jsp
Fans, blisks and contra-rotation, whatever you want.
BOEING747400
Mon Dec 18, 2006 2:55 am
Quoting LTU932 (Reply 31):
Yes, I would think that maybe the wing could be modified to become a little larger and have raked wingtips instead. Wouldn't that work in improving the 744/744ER performance in cruise speed and range along with a new set of 4 GEnx and/or RR Trent engines rated between 60K-70K lbs. thrust each?
A342
Mon Dec 18, 2006 11:10 pm
Um, no. Boeing will build the 748 and no other jumbos. And why would you want M0.88 cruise speed ? Nobody needs that. There's a reason why Boeing had to dump the Sonic Cruiser.
andz
Tue Dec 19, 2006 12:32 am
Quoting Litz (Reply 29):
I recall seeing a photo of a BA 737 and 777 which showed this comparison, unfortunately I haven't been able to find it to post it here. This one is pretty good though:
Photo © Erwin
litz
Tue Dec 19, 2006 11:01 am
Quoting Andz (Reply 35):
You know ... that's kinda like driving a SUV ... from the cockpit you can see clear across the shiny top of the airplane in front of you ...
 Smile
- litz
FTOHIST
Sun Jan 21, 2007 2:24 am
Quoting Prebennorholm (Reply 18):
That a ge-90 can be mounted on a 747 wing for test purposes (as seen in reply #6) proves nothing. It is not integrated with the plane at all. It takes off and lands as a three engined plane - no problem when not heavily loaded - and the ge-90 test engine is during flight test not operated by the flight crew at all. It is operated by a minor army of engine test engineers in the cabin.
I hate to dredge this thread up from last year--no wait, I do want to dredge this thread up from last year. Most of the quoted text here is not accurate. No matter what test engine flies on N747GE (not just the GE90), the pilots have full throttle control over all flight regimes. I won't go into detail on what the controls engineers can or cannot do from the cabin, but the cockpit does indeed use #2 for anything it needs. And there are quite a bit more engine instruments in the cockpit other than N1, BECAUSE THE PILOTS NEED TO USE THEM.
This is only one aspect of GE's test operation that sets it apart from other engine manufacturers where the test bed is more like a flying test cell. The west coast organization of GE flight test has always used this sort of setup--since 1952.
tito
Sun Jan 21, 2007 8:00 pm
In regards to the original question about Trent re-engining of 747-400. The RB211-524G/H can be retrofitted with the Trent high pressure section making the engine a -524G/H-T ("T" is for trent). So in a way its half of a Trent re-engine.
Users browsing this forum: Baidu [Spider], thepinkmachine, Yahoo [Bot] and 10 guests
