MD11Fanatic
Fadec Or EEC On DC-10-30?
Sat Nov 11, 2006 9:50 am
Is there a FADEC or EEC system that controls the CF6-50C2 engines on a DC-10-30 or is it an entirely mechanical process?
[Edited 2006-11-11 01:51:35]
Jetlagged
RE: Fadec Or EEC On DC-10-30?
Sat Nov 11, 2006 9:55 am
The CF6-50C2 uses a hydro-mechanical fuel control unit. No EEC or FADEC.
CosmicCruiser
Sat Nov 11, 2006 9:56 am
No there's no fadec or eec on the dc-10-10 or -30
DeltaGuy
Sat Nov 11, 2006 10:33 am
Most aircraft of this vintage, as jetlaged said, used a hydro-mechanical fuel control unit. The EEC didn't find it's way into engines till later.
On the engine I work on (P&W F100-220), there is a DEEC (Digital Electronic Engine Control), but on previous models there was an EEC. In either model, a hydro-mechanical fuel control is used for backup in secondary mode (loss of all electrical power). I'm sure other engines of newer design also incorporate such similar backups.
DeltaGuy
F14D4ever
Sat Nov 11, 2006 10:46 pm
EEC is a Pratt term; GE use FADEC exclusively (at least on the commercial engine side) to designate their digital electronic engine controls.
FADEC was not available on the CF6 series until the advent of the -80C2 variant. CF6 models equipped with FADEC are explicitly designated with an F suffix: CF6-80C2D1F, for example, is a FADEC-equipped engine with a rating plug for the MD-11.
"He is risen, as He said."
Tristarsteve
Sun Nov 12, 2006 12:35 am
Quoting F14D4ever (Reply 4):
EEC Electronic engine control
FADEC Full authority digital engine control.
The RB211-535E and RB211-524G/H both have EEC. As far as fuel control goes they control the whole works elecronically. But both have another means of airflow contol. The -535 has a separate electrical airflow contoller (sorry cant remember its name!), and the -524G/H have a totally analogue system.
When RR moved on to the Trent, they added airflow control to the EEC and it became a FADEC.
Quoting DeltaGuy (Reply 3):
No, the Trent engines do not have a backup mechanical fuel control. They do have back up electrical supplies.
IFIXCF6
Sun Nov 12, 2006 3:35 am
"EEC" is not just P&W, as GE90's have an EEC. The CF6-80C2D1F (and all CF6-80C2xxF's) have an "ECU" as the black (actually grey) box. FADEC is the system, and EEC or ECU is the box. -80C2's that do not have an "F" suffix, as explained prior, are not FADEC, and do not have an ECU. They do have a "Power Management Control", which refines the MEC. But it is not "Full Authority", thus not FADEC.
So, having drifted well off course of the original post, no the -50's of the DC10-30 are not EECed, ECUed, PMCed, or FADEC. Cables and rigging only! I hope this helps!
Mike
F14D4ever
Sat Nov 18, 2006 2:31 am
Quoting IFIXCF6 (Reply 6):
Interesting. I stand corrected.
Thanks.
Users browsing this forum: 77west, RetiredWeasel, trevisan26 and 19 guests
