Jawed
Thrust Levers Out Of Sync In Picture?
Sat Nov 18, 2006 2:25 pm
In this cockpit photo:
http://www.airliners.net/open.file?id=0943177
the two thrust levers for the engines are slightly offset, with the left one being pushed forward more. does that mean that the left engine was giving more thrust during this flight? why would that happen?
[Edited 2006-11-18 06:28:01]
Ralgha
RE: Thrust Levers Out Of Sync In Picture?
Sat Nov 18, 2006 2:58 pm
No it means that the thrust lever calibrations do not match each other. Quite common.
kaddyuk
Sat Nov 18, 2006 4:00 pm
Quoting Ralgha (Reply 1):
Throttle Stagger shouldn't occour on the B767 because it has FADEC...
troubleshooter
Sat Nov 18, 2006 4:16 pm
Quoting Jawed (Thread starter):
If you have a closer look to that picture you will see a N1 indication of 93,5% per engine so the thrust should be equal.
This job sucks!!! I love this job!!!
fr8mech
Sat Nov 18, 2006 4:28 pm
Quoting Kaddyuk (Reply 2):
I've worked on plenty of B767 that were not FADEC. I don't know if this one is or not. But EICAS shows the same thrust being produced (N1).
AJ
Sat Nov 18, 2006 5:58 pm
Only one of our 20+ 767s has FADEC! That split is nothing compared to the good old JT9Ds on the 762s.
erj-145mech
Sat Nov 18, 2006 8:47 pm
Less than 1/2 knob difference= in tolerance.
MD11Fanatic
Sun Nov 19, 2006 3:39 am
What about the altimeters? The primary and backup altimeters have the same barometer setting but they're separated by 300 ft. What gives?
boeingfixer
Sun Nov 19, 2006 3:59 am
Quoting MD11Fanatic (Reply 7):
That's common for the Pneumatic Standby Altimeter. It's called Hysteresis and is a mechanical phenomenon where the elastic properties of the bellows and mechanisms inside the altimeter produce errors. This happens after a fast ascent or descent and can also happen after a prolonged period in cruise at altitude.
John
Cheers, John YYC
113312
Sun Nov 19, 2006 4:05 am
Looking closely at the engine indications, the two engines are operating at nearly identical settings. The thrust lever stagger is typical.
The standby barometric altimeter is 300 feet higher than the captains indicator. However, this is also common. The Captain and First Officer altimeters are driven from their respective Air Data Computers and are highly accurrate. This degree of difference is common at that altitude.
Jetlagged
Sun Nov 19, 2006 4:21 am
Quoting 113312 (Reply 9):
The ADC increases accuracy by applying correction for static port position errors. The standby altimeter has no position error correction.
ZBBYLW
Sun Nov 19, 2006 7:06 am
I remember back in the good old days, i was flying in an AC 742 YYZ-YVR and i went into the cockpit and not one of the trust leavers matched, it was interesting to see for sure, another interesting thing about that flight is it was the first time i landed on 30 in YVR in a widebody come to think of it i dont even remember another time where i have seen a widebody land on 30 or 12... o well.
Keep the shinny side up!
avt007
Sun Nov 19, 2006 7:34 am
I came back from YYZ the other day, and much to my surprise we landed on rwy12, in a 767. It was a very windy day, however.
zvocio79
Sun Nov 19, 2006 7:37 am
different part number............just kidding.........perhaps the triming.........look on eicas, the thrust ratin seems ot be the same for both.
Dougloid
Sun Nov 19, 2006 7:41 am
Rigging power and speed set levers was pretty common practice on Garretts and PT6s. ....half a knob mismatch was considered pretty decent rigging.
The important thing was to get the decay rate the same on both engines. See, slapping the power levers back on the stops would set up a 700 fpm descent. If the engines did not spool down at the same rate this could cause a lot of heartache, particularly if it was something close coupled with a rapid roll rate like a MU2. That killed more than one pilot.
Sun Nov 19, 2006 6:57 pm
Quoting Zvocio79 (Reply 13):
The EEC would help preventing overboost.
regds
MEL
Users browsing this forum: KarelXWB and 3 guests
