gopal
Does 777 Use VORs
Mon Nov 27, 2006 9:54 pm
Does Boeing 777, being one of the most advanced airliners, still use VORs for navigation when flying between cities within the US ? Do other latest models such as A330-300 also VORs as well. When traversing oceanic routes, they use GPS systems, I think.
PhilSquares
RE: Does 777 Use VORs
Mon Nov 27, 2006 10:14 pm
On the "modern" aircraft, the primary means of navigation is via the FMS. The FMS includes the IRS/ADIRU, the FMC (flight management computers) and the FMSCDU, or the input device.
The FMC gets the aircraft's position from the IRS and then that is further refined by GPS updates as well as VOR/DME, ILS DME or VOR/VOR. The flight plans are filed, in domestic ops, using standard jet routes which include VORs. The FMS takes care of everything, but the pilot's don't select the VOR stations and then set the inbound course if that's what you're asking...
On international flights, the flight plan is loaded and the same procedure applies. The actual navigation is done by the FMC and it is updated via GPS (assuming it's available).
Hope that helps.
[Edited 2006-11-27 14:15:54]
Fly fast, live slow
avt007
Mon Nov 27, 2006 10:42 pm
The CRJ FMS works as you've described, Philsquares, but interestingly enough, when you look at how the FMS updates IRS position, GPS is at the bottom of the list, after DMEs and VORs.
PhilSquares
Mon Nov 27, 2006 10:51 pm
Quoting Avt007 (Reply 2):
On all the Boeings, and IIRC the Airbus, the first choice is GPS, then if that's not available, it looks for ILS DME/ ILS DME, VORDME/VORDME then VOR/VORDME then finally VOR/VOR. If it can't up date then the FMC then uses it's know error rate to compute the triplemix position.
Plus I don't know about the CRJ, but you can never up date the IRS position, you can only update the FMC position.
Fly fast, live slow
DeltaGuy
Tue Nov 28, 2006 12:22 am
If you go to the PROG page on many FMS's, you can see the VOR's that it's cross referencing to maintain it's proper position. Sometimes there are several in there.
DeltaGuy
avt007
Tue Nov 28, 2006 12:41 am
You're right Phil, the priority is, IIRC, multi DME, DME/DME, DME with colocated VOR, IRS, GPS. This list is for updating the FMS position, not the IRS as I said.
XXXX10
Tue Nov 28, 2006 12:58 am
Sorry for being slightly off topic here but could a modern aircraft (777, A330. 738 etc) be dispatched without a working FMS system-assuming that it was only flying over areas with good VOR coverage.
Tristarsteve
Tue Nov 28, 2006 1:41 am
Quoting XXXX10 (Reply 6):
No.
The B777 has two FMCS. One must be serviceable for dispatch, and both serviceable for FANS routes.
The A320 has two FMGCs Flight Management Guidance Computors. These are a combined FMS and AP control system. One whole system must be serviceable.
But go back to the B737-400. Ours have a single FMS and this is acceptable inoperative.
Tristarsteve
Tue Nov 28, 2006 1:52 am
Quoting PhilSquares (Reply 3):
Quoting Avt007 (Reply 5):
I agree with Avt007. The most accurate position is with DMEs and the FMS will take these first if available.
In fact for non-ETOPS A320 I wonder sometimes why we have three INS and two GPS. Seems a bit of an overkill when a single auto-tune DME is all you need!
In the good old days of the B737-200 we flew ARN-LHR over DANDI in the North sea, and with no IRS were on dead reckoning for 20 mins. I think you guys are spoiled nowadays.
gopal
Tue Nov 28, 2006 2:21 am
Thank you, everyone for the informative replies. How long does it take for a pilot to gain mastery over the FMS ? Does is require in-dept knowledge if IRS and INS ?
dalb777
Tue Nov 28, 2006 2:41 am
Can someone explain what IRS and INS are?
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
PhilSquares
Tue Nov 28, 2006 4:52 am
Quoting Dalb777 (Reply 10):
Inertial Navigation System...vs. Inertial Reference System. In the "old" days the INS would navigate. Today, the IRS feeds inputs into the FMC and the FMC navigates.
Fly fast, live slow
SlamClick
Tue Nov 28, 2006 5:05 am
IRS is inertial Reference system.
INS is inertial Navigation system.
If I'm not mistaken the Reference is the newer, updated version.
The "inertial" part of the system uses extremely sensitive and accurate accelerometers and ring-laser-gyros to sense movement in all three axes.
The "reference" means that it uses other elements to confirm, refine and present the navigation and flight data. These may include GPS or DME/DME and even manual position updating to correct as you go.
So you are sitting on the ramp, about to power the system up. Your company Jepp chart has the latitude/longitude to a tenth of a minute of arc for the very gate you are parked at. You enter that into the system and start it up.
The system goes through some self-checking. Among the things it does in this phase is find local vertical and measure the rotation of the earth. It uses this to find north - possibly confirmed with a fluxgate compass. It compares the earth's rotational speed with the latitude as a validity check for present initial position. It may also check the initial position against the stored position when it was shut down. If they differ by more than a couple of miles it may ask the pilot to confirm the new position. If a catering truck pulls up to 1R door and bumps the airplane at this time it could fail its initial checks.
Before moving the airplane, the flightplan will be input to the flight management computer. Not so long ago you had to input the forecast winds along your route of flight. Those may well come via ACARS now which saves many keystrokes.
When the airplane begins to move, the airplane notes that movement. It does by two methods - the little accelerometers and RLGs and also by the changing of "present position" as determined by GPS or DME/DME readings.
The system provides not only navigation but flight information including the artificial horizon which it derives from knowing UP. It also gives vertical speed and compass heading among other things.
So when you are underway, by its movement-sensing it knows how fast you are actually going and it what actual direction over the ground. It will compare the compass heading and the true airspeed from the air data computers with the actual direction and speed of travel. The difference between these is the wind factor, both wind direction and speed can be determined from these - in realtime.
We fly along with the VOR receivers in an "auto" mode, allowing the system to tune VOR station along the route of flight. It will try to select two where the bearing to the station is as near as possible to 90 degrees from each other, and use those stations DME readings only to confirm or update present position. If you look at an enroute chart you can see that 102nm from this VOR and 86nm from that VOR occurs at two locations or cusps in the overlapping circles. Of course it knows which of those two would make sense from its last known position (about a tenth of a second ago  Smile) and it also had the radials so it never has an ambiguity problem.
If ATC clears us direct "Hector" for example, which is a VOR out in Southern California from which some LAX arrivals begin, they expect us to overfly Hector. Our plane will do that but it will navigate to the published lat/long of Hector without necessarily actually tuning it. We can just type HEC into the scratchpad and line select it onto the flight plan. (depending on the type of system)
Anyhow that is kind of an overview, the broad strokes on how a typical system might work. I've been trained on two different Boeing systems and two different Airbus system so individual features have all kind of run together. Sorry.
Questions?
BoeingOnFinal
Tue Nov 28, 2006 5:33 am
This is why you guys are on my respected users list, I learn so much valuable information. Starting to wonder if I should just stop reading the theory books and just ask you guys instead :p
Anywho, how is a point like HEC chosen? Do they have to VOR radials crossing at as close as 90 degrees, and put that as one navigation point into the FMS system?
norwegianpilot.blogspot.com
avt007
Tue Nov 28, 2006 5:44 am
Excellent description Slamclick. I'll add my two cents- IRS find true north, then using a database of magnetic variation for your location, it displays magnetic north. The one other thing it needs is longitude. Latitude it can figure out on it's own, but you have to enter longitude, then you are in business.
Tristarsteve
Tue Nov 28, 2006 6:08 am
Quoting BoeingOnFinal (Reply 13):
Most waypoints are the sites of VORs.
20 years ago they all were, but with the advent of FMC navigation on all airliners today, they can be situated anywhere. The FMC computor can work out where they are by doing the math.
By the way the math involved in an IRS system is all calculus. Remember that from school? The IRS measures acceleration, then integrates it to find speed, and integrates it again to find position. And you wondered why you learned integration!!
Goldenshield
Tue Nov 28, 2006 7:02 am
Quoting TristarSteve (Reply 7):
No.
That may be applicable in Europe, but here in the states, we have pretty good navaid coverage. If one were to go down along the intended route of flight, it will be rerouted using good navaids, and pilots will just have to manually tune the navaids, and then use the autopilot to follow the radials, or fly them manually.
bond007
Tue Nov 28, 2006 7:27 am
Quoting Goldenshield (Reply 16):
Good god man!
I'd need to get the old textbooks out  Smile
hmmm....Radials....navaids....aaahh, I see them now in the index.
Jimbo
dalb777
Tue Nov 28, 2006 8:18 am
Quoting SlamClick (Reply 12):
Wow, thanks so much for that explanation. I have always wondered how that system works.
IAHFLYR
Tue Nov 28, 2006 8:54 am
But doesn't the Honeywell and Smiths FMC's need to have the larger database to use the localizer DME's otherwise they are taken out of the NAV solution?
Quoting Avt007 (Reply 14):
A very good description that even I the lowest common denomitor can slightly gasp!!
BoeingOnFinal
Tue Nov 28, 2006 8:57 am
Thank you Tristarsteve. So the IRS calculates points from the coordinates it currently "think is correct"?
And, how often does the IRS needs "updating"? The directional gyro needs updating every 15 minutes because of the earth rotation, so I guess the IRS gyros are affected by that as well?
timz
Tue Nov 28, 2006 9:09 am
Quoting Tristarsteve (Reply 15):
20 years ago they all were ...
In 1986? There were named places on the charts, defined only by their lat-lons, weren't there? Say, along the California-to-Hawaii routes? You're saying those weren't "waypoints"?
meister808
Tue Nov 28, 2006 9:55 am
Quoting Timz (Reply 21):
In 1986?
20 years ago is getting newer and newer all the time...
-Meister
PhilSquares
Tue Nov 28, 2006 1:07 pm
Quoting BoeingOnFinal (Reply 20):
Today"s IRSs are extremely accurate due to the lack of moving parts when you compare them with the first generation INS. But, once they're aligned and in flight, the only updating that goes on is the FMC position. On the 744 you can select POS and you'll get the input of the IRS on the ND. Sometimes they're real close, other time, you'll see one drifting away from the other two. Even that isn't unusual. The error induced by the IRS into the FMC is adjusted by the other external inputs, such as GPS/ILSDME, VORDME and VOR bearing. But again you can't update the IRS in flight only the FMC.
Quoting IAHFLYR (Reply 19):
The Nav database in the Honeywell system is large. There are several upgrades available to expand the memory if required. I've flown 774 who lacked the memory to have stored routes because of the lack of memory and conversely, at my company, just about every route we fly is stored with multiple routings to each destination.
Fly fast, live slow
Tristarsteve
Tue Nov 28, 2006 4:08 pm
No.
Sorry, I was quoting from the Boeing produced MEL. Perhaps your airline has amended it with agreement from Boeing so you can fly without an FMCS. But how do you tune the VORs? There are no control panel. Manual tuning is via the CDUs. These CDUs are also the only way to align the ADIRU.
Goldenshield
Wed Nov 29, 2006 1:16 am
Quoting TristarSteve (Reply 24):
Sorry, my bad. You were talking about the panel itself, and not the actual flying without FMS.
SlamClick
Wed Nov 29, 2006 1:52 am
I had questioned that statement myself but hadn't bothered to post.
I wasn't flying in Europe in 1986 but I can assure you that here in the US the majority of named locations used in air navigation were not actual VORs. The word "waypoint" at the time was commonly used to represent a location used by RNAV and derived either from lat/long or by radial/distance from one or more VOR sites. If it was not defined in relation to a VOR it was probably denoted by a four-pointed star rather than a triangle.
The majority of named locations were probably "intersections" on V and J air routes. The depiction legend on Jeppesen charts, for example, would tell you exactly how the fix was established.
radelow
Thu Nov 30, 2006 12:42 pm
I have to echo the comments from some people here... You guys are awesome! Thanks for the easy to understand explanation of how this stuff works...always wanted to know that.
Users browsing this forum: Starlionblue, Vinka and 1 guest
