Blackbird
VC-10 Hydraulic's And Control-Surfaces
Fri Dec 08, 2006 8:47 am
The VC-10 had a rather interesting hydraulic layout if I recall... anyone know more?
N231YE
RE: VC-10 Hydraulic's And Control-Surfaces
Fri Dec 08, 2006 8:53 am
This may be of interest to you:
http://www.vc10.net/Technical/hydraulics.html
Blackbird
Fri Dec 08, 2006 9:08 am
Thank you. Was the electrically-driven hydraulic pack system successful?
Andrea
N231YE
Fri Dec 08, 2006 9:50 am
Quoting Blackbird (Reply 2):
I am not sure. I will try to find out though.
saintsman
Fri Dec 08, 2006 4:43 pm
Actually they worked quite well.They weren't something that was changed that often.
If I remember correctly, the main issues we had was with the autopilot servo motors that were connected to the PFCUs.
Tristarsteve
Fri Dec 08, 2006 6:41 pm
I do remember pushing the steps around the aircraft to check the hyd quantitys on a weekly check.
There was no EICAS to look at!, you had to go and look at every little tank and check the level.
vc10
Fri Dec 08, 2006 7:53 pm
The PFCU system was a very reliable system, after a few initial problems, and in the 10 years I was with the VC-10 I do not recall them being a problem. The biggest problem was if something went wrong with the elevator PFCU as they were so high from the ground, and I always remember the feeling of relief after working on one, using a cherry picker, on the ramp at LHR . It was good to get down in one piece, Prior to the introduction of the VC-10 BOAC had to build a special overhaul workshop for them where the air was finely filtered as the limits on the PFCU components was very tight.
littlevc10
VC-10
Fri Dec 08, 2006 7:55 pm
Well, they are using it on the 380!
DH106
Fri Dec 08, 2006 8:03 pm
Slightly off topic, for those with an eye for detail - the the VC10 has always struck me as unique in that it doesn't seem to have any secondary nose gear doors - meaning the small ones that remain open when gear is down and covers the area where the leg itself extends through. Take a look at any VC10 piccie with the gear down and you'll see what I mean.
Is there a small 'hatch' that closes from the inside when the gear is raised to streamline the hole in the fuz through which the nose gear passes when down?
...I watched c-beams glitter in the dark by the Tanhauser Gate....
VC-10
Fri Dec 08, 2006 8:52 pm
Quoting DH106 (Reply 8):
Yes, the strut door folds in two & goes up into the bay aft of the strut
DH106
Fri Dec 08, 2006 10:33 pm
Quoting VC-10 (Reply 9):
Ahhhh - thanks. Neat arrangement.
Love the VC-10 - a very asthetic aircraft. Excellent safety record as well.
baroque
Fri Dec 08, 2006 10:54 pm
Quoting VC-10 (Reply 7):
Ok, but is that a yes or a no?  angel
VC-10
Sat Dec 09, 2006 3:39 am
I've just remembered that it was used on the Vickers Valiant before the VC-10
And the Nose Gear Door
http://homepage.ntlworld.com/paul.robinson16/Door.jpg
http://homepage.ntlworld.com/paul.robinson16/Door2.jpg
Taken from 1962 vintage course notes
DH106
Sat Dec 09, 2006 4:14 am
Quoting VC-10 (Reply 12):
Makes perfect sense now VC10 - thanks  Smile
I did manage a quick look at G-ARVM's nose gear before she was unfortunately cut up and did see a bit of the blue painted door face behind the leg!
Seems fairly simple and doesn't need a lot of space - wonder why no other airliners used a system like that.
Blackbird
Sat Dec 09, 2006 6:31 am
I think that hydraulic pack system sounds a hell of a lot better than the systems we used on our jets.
Blackbird
Sun Dec 24, 2006 9:46 am
I don't know why this didn't occur to me back then: I thought electrical systems have a higher incidence of failure than hydraulic systems?
Andrea K
Blackbird
Fri Jan 19, 2007 2:57 pm
Did those electrical hydraulic packs have mechanical linkages like an ordinary hydraulic powered plane, or was it fly-by-wire?
Andrea K
saintsman
Fri Jan 19, 2007 4:48 pm
Quoting Blackbird (Reply 16):
They are both. Mechanical for normal use and electrical for autopilot.
Blackbird
Sun Jan 21, 2007 4:45 pm
How did it achieve such reliability using an electrically powered hydraulic system. From what I remember, electrical systems have a far higher incidence of failures. What made it reliable enough if applicable, even if it was just dumb luck. :p
Thank you for your reply, Saintsman
Users browsing this forum: CrackInspector and 1 guest
GZIP: Off
