Soku39
Simulator Time For Light GA
Mon Dec 11, 2006 3:30 pm
As I enter into the simulator block of my instrument stuff I am becoming increasingly frustrated with the Frasca and Fly it (non motion flight seems, fly it using the oh so cutting edge flight simulator 2002  Yeah sure ). I see little value in using them, and they really only serve to drive me crazy as they feel nothing like a real airplane. Patterns are impossible and they're really only good for a cheap laugh when you're 500 feet off your altitude when you come back to your altimeter during the scan. Does anyone else feel these things are as worthless as I do?
The Ohio Player
lowrider
RE: Simulator Time For Light GA
Mon Dec 11, 2006 3:47 pm
Even a basic sim is useful as a proceedures trainer. You can learn to develop a scan and build situational awareness before you get into the plane. You already know the basics of flying the plane, now you will learn the basics of instrument flying, and later you will put the two together. I have taught both with and without the benefit of a sim. I liked using the sim not only to introduce instrument flying, but also to work on problem areas identified once we started in the plane. Even if my students hated the "box", they appreciated the money saved.
Proud OOTSK member
Soku39
Mon Dec 11, 2006 4:00 pm
Well the thing is they start us off in the plane. Days ago I was able to descend at constant rate, and airspeed while turning to a heading, it's easy enough in the plane. I can keep every dial where I want it and this was after about 5 hours worth of being under the hood. Granted this is not flying in actual, and I am so far from knowing what I need to, in order to be a safe instrument pilot, to me this "step down" just seems like a waste.
The Ohio Player
Mir
Mon Dec 11, 2006 5:18 pm
The thing that drives me nuts about FTDs is that the feeling of motion isn't there. Some of the ones I've "flown" recently give me motion sickness because the view outside is wide enough that it looks real but still feels like I'm just sitting there.
-Mir
united757
Mon Dec 11, 2006 11:57 pm
My flight school has a full motion simulator (Motus Fidelity), which I find to be useless in anything but procedural training. There is a delay in control input, which makes it difficult to keep your altitude. Also, it is virtually impossible to stay in the pattern, because there are no "windows", only a "windscreen".
2H4
Tue Dec 12, 2006 12:14 am
I've spent LOTS of time in Frasca 142s and various ASTs. I can relate to your frustration with the lack of stability. I used one in particular that felt like a Caravan with barrels of lead rolling around in back.
As frustrating as it can be, though, sims like that require you to develop your scan. After spending time struggling with such an unstable platform, your scan goes through the roof, and that pays off in the airplane.  yes
2H4
Intentionally Left Blank
N231YE
Tue Dec 12, 2006 4:03 am
Quoting Soku39 (Thread starter):
(non motion flight seems, fly it using the oh so cutting edge flight simulator 2002   )
You actually got a screen in those simulators? In my university, the lone Frasca 141 has no screen, just a big fiberglass wall and an instrument panel - simulators without a screen [visual depiction of environment, even if you are in simulated IMC] suck worse.
This is exactly what my university's Frasca 141 looks like, minus the Garmin GPS unit in the radio stack:
http://www.aviation.uiuc.edu/main/images/PPD/sims/frasca_141_800.jpg
Really, the only value I see in it is through learning to scan the instruments and emergency procedures.
[Edited 2006-12-11 20:05:17]
2H4
Tue Dec 12, 2006 4:29 am
Quoting N231YE (Reply 6):
The ones I used looked just like that, except we had a single, 19" monitor in front of the pilot.
I remember practicing flight team patterns late one night. It must have been 10 or 11pm, and I was one of the only people left in the building. I was about an hour into my practice, totally in the zone and completely oblivious to everything around me, when a knucklehead buddy of mine sneaked up to the sim and banged VERY loudly and repeatedly on the fiberglass shell.
After my heart rate stabilized, I headed home for a change of pants.
2H4
N231YE
Tue Dec 12, 2006 4:53 am
Quoting 2H4 (Reply 7):
 rotfl
They do that in my university-to (jokingly) simulate a bird strike. I know when I was practicing emergency procedures once, I was set up on an engine-out approach, and my instructor said "he had to go use the restroom." In reality, he went behind the unit, gave it a hard whack and subsequently shut it off, saying that I flew into a telephone pole.
pilotpip
Tue Dec 12, 2006 5:47 am
As 2H4 pointed out, the sim is useful. As much as I hated it as a student, I have come to respect it as an instructor. There are a lot of things that you can do in the simulator that I wouldn't dare do with a real aircraft. Systems failures that you can't duplicate in the air and wouldn't attempt to do either.
Most important at your stage in training, is developing a good instrument scan. While you did just fine under the hood in the airplane, the hood doesn't totally simulate being in the clouds. You will get spatial disorientation, and you will have trouble with your first experience in actual. With a view limiting device you can still cheat. The horizon and other things may still be percievable that prevent you from truely relying on the instruments.
Another good thing about the sim is something that you'll start to understand more as you begin doing holds and approaches. It saves a lot of time and money on your part. You blow a hold or miss the FAF? Rather than getting vectored around again, the instructor resets things. You can do two or even three approaches for every one you do in the airplane. You don't have to worry about loitering over a busy VOR (not fun IMO. For every pilot on flight following there are two that are doing their own thing) spending more time concerning yourself with traffic than with the task at hand. And again, I can't stress this one enough, you can set up situations tailored to the lesson of the day and also situations that wouldn't be safe to replicate in the air.
DMI
APFPilot1985
Tue Dec 12, 2006 9:54 am
I was playing around with this the other day, and while its flight characteristcs weren't as accurate as the real aircraft (it is wayy to sensitive) it still helped with procedures, not to mention that if you could trim the FTD and get it to fly hands off, you can do it in the real thing.
Stand Up and Be Counted Visit Site Related to Voice your opinion
onetogo
Tue Dec 12, 2006 2:34 pm
Oh man, here at Purdue SMASHING the shell as loud as possible and yelling "BIRDSTRIKE!!!!!!!" are everyday occurances. Pretty hilarious.
ThirtyEcho
Tue Dec 12, 2006 5:20 pm
THIS ISN'T A SIMULATOR.
It is a procedures trainer. It was never intended to simulate flight.
Ask your instructor about the difference.
AirWillie6475
Tue Dec 12, 2006 6:32 pm
There is no substitute for real IMC. FTDs are a waste of time and money and should be used by 50 year olds. If you have MS flight simulator on your hard drive there is no excuse why you should be using a FTD.
2H4
Tue Dec 12, 2006 11:59 pm
Quoting AirWillie6475 (Reply 13):
None of us have argued otherwise.
Tell that to the major airlines that use them in their training syllabus.
By the way....have you gone through airline new-hire training? Do you have a type rating? If the answer to the above questions is no, then I don't think you're qualified to determine the value of FTDs as training aids...
2H4
APFPilot1985
Wed Dec 13, 2006 2:04 am
I meant to post this is my last post but for some reason it didn't get across. If you can't see the benefit of something like this
http://www.eaa-fly.com/2.0/en/MainFlugzeugePCATD.html
Then I don't know what to tell you. Some companies like Flight Express even use much more basic PCATD's as the simulator during the interview so them must put some stock in them.
3DPlanes
Wed Dec 13, 2006 2:13 am
Until you can show me an OBS, radio stack, or manual trim wheel that I can change by using a mouse or keyboard shortcut, I'd suggest that your statement above is bunk.
And I'm one of the few on this forum that thinks that MSFS can actually be useful, so don't count me in with the "50 year olds" that you are mocking.
Just as you state that there is no substitute for actual IMC, neither is a 19" flat panel a substitute for using a trim wheel, resetting a DG, fiddling with switches/breakers/lights on the overhead, breaking your scan to tune a VOR, etc.
And to the original poster, I'll add that while I feel your pain (currently working on my instrument rating), many folks elsewhere - instructors and students alike - have opined that if you can master the "squirrely as hell" Frasca or Elite FTDs, then the real A/C seems calm by comparison.
And as part of the benefit of an FTD, I recall the story about a student calling the instructor over to say she thinks the "sim has a problem," when in reality she's lost vacuum and the HSI has been slowly precessing. His response - "Are you declaring an emergency?"
"Simplicate and add lightness." - Ed Heinemann
united757
Wed Dec 13, 2006 5:17 am
I used MSFS frequently before I started taking flying lessons (and I still do) and I found it to be extremely helpful in procedural training, though not so much for flight simulation. In fact, on my first lesson my instructor was very impressed with how I knew where most of the instruments were and how to work them. I always use it in between lessons and practice things I did on previous flights. I actually think that if I were to not use MSFS, it would really have an impact on my flight training.
KELPkid
Wed Dec 13, 2006 5:42 am
Quoting 2H4 (Reply 5):
2H4
 checkmark
If there was one thing I learned in real life about the 172 while getting my instrument rating, it is that the plane seems to be very squirrely about the yaw axis in particular, and this attribute screwed up more than one ILS or LOC approach for me where I wasn't paying very close attention to my heading. The Frasca (and some devoted attention by my flight instructor  Smile ) quickly got me scanning the DG at the required rate...
However, no simulator in the world can duplicate the real life IFR experiences like finding out the inside of most cumulus clouds is a very bumpy place, what it's like to blunder into an embedded cell while on an approach (ATC told us, after we started experiencing 500-1000 FPM climbs and descents, that they were painting a level 3 cell where we were...we were IMC the whole time so we had no idea, and my instructor thought it was me being rough on the controls  Wink ), or gusty winds on the final approach course. These things require the genuine article Big grin
AirWillie6475
Wed Dec 13, 2006 5:47 am
Quoting 2H4 (Reply 14):
Dude were talking about basic 172 instrument training.
Quoting United757 (Reply 17):
 checkmark
AirWillie6475
Wed Dec 13, 2006 5:59 am
That's what happened to me when I was going for the private except I my instructor didn't like that I flew the panel too much. I remember it took me a few lessons to focus my attention on the outside rather than the panel, too much FS I guess Smile
dw747400
Wed Dec 13, 2006 7:01 am
Quoting AirWillie6475 (Reply 20):
This is common for pilots who have a lot of time on FS.
By the way, having flown FTDs and FS2004, I can tell you both are valuable procedural trainers and neither is a substitute for an airplane. But, a well-designed FTD is better than anything MS has put out yet. At OSH Elite had a full-panel mock-up on display ($30,000 price tag) and it was amazing. It was very close to a real plane in feel, though visual cues on the outside were difficult to use (no peripheral vision on the flare for example). It is the only FTD I've used where I felt I was doing more than just practicing procedures, but actually working on flight skills.
CFI--Certfied Freakin Idiot
Scooter01
Wed Dec 13, 2006 7:16 am
Maybe a bit off topic here, but I wonder what Edwin Link would have come up with if he was alive?
united757
Wed Dec 13, 2006 10:00 am
Same here
 Wink
Woodreau
Wed Dec 13, 2006 10:05 am
Any one try the Baron G58/Bonanza G36 flight simulators at Flight Safety in Wichita? It's got a outside view screen and the interior cockpit is equipped with the G1000 panel.
I think its main audience are the people who buy these G1000 equipped planes and Raytheon includes the flight training at Flight Safety as part of the purchase price.
flight152
Wed Dec 13, 2006 12:19 pm
I do, they are great in learning insturment approch procedures. Unless you have the money to poney up the money for the real thing for all the extra hours here at Kent, I don't see what you are complaining about.
APFPilot1985
Wed Dec 13, 2006 1:12 pm
Quoting Woodreau (Reply 24):
that is exactly what diamond has done with the FTD that I posted earlier. It is great for getting you acclimated to the aircraft and the systems before your start burning the big bucks in the actual aircraft.
pilotpip
Wed Dec 13, 2006 1:48 pm
I've been flying a G36 quite a bit and I will have to say that it can't be as nice as the real thing.  Smile
DMI
Fly2HMO
Wed Dec 13, 2006 3:11 pm
Quoting Onetogo (Reply 11):
Lots of scuff marks in our frasca level 6 sims due to people jumping on the "cowling" Big grin
I could bitch and bitch and bitch about how crappy and unrealistic they are I.E. the control loads on a level 6 frasca ftd are designed to be used by a 500lb gorilla. Yet, I just passed my instrument stage check and, had I flown mainly in the real Seminole, I probably would have had a lot more trouble passing the sim check, since the sim is so much more demanding than the real plane itself.
O and its a lot of fun to do go scudrunning at 999kts in a level 6 C172 sim Big grin
Soku39
Wed Dec 13, 2006 3:37 pm
I stand a little bit humbled from all the pro sim posts. I still dislike them and hate how little it resembles anything in flying, but will be looking for some of the more positive aspects you guys have shared while I spend time in them.
The Ohio Player
pilotpip
Thu Dec 14, 2006 4:30 pm
Like I said my friend, as a student I hated it. As an instructor I respect it for the valueable tool that it is. Just another way to teach a student how to do things in an environment that won't kill them, or more importantly, ME! Also beats the pants of getting vectored around for over an hour for two or three approaches.
I still look like a fool when I strap into one though  Smile
DMI
Users browsing this forum: raedgar, RetiredWeasel, SCAT15F and 2 guests
