ATR72 As A Freighter
Thu Dec 14, 2006 11:18 pm
How effective & Efficient is an ATR72-500 converted Freighter.Any operators using them Worldwide currently.
regds
MEL
IAHFLYR
RE: ATR72 As A Freighter
Thu Dec 14, 2006 11:30 pm
I saw a FEDEX ATR not long ago but IIRC it was an ATR42 not a 72!
miamiair
Fri Dec 15, 2006 12:28 am
Quoting HAWK21M (Thread starter):
DHL Aviation Americas operates them in Central America.
My mistake, they operate the ATR42
[Edited 2006-12-14 16:29:05]
charlienorth
Fri Dec 15, 2006 1:52 am
regds
MEL
I only have dealt with the pax version,but I do believe it would make a very efficient freighter,especially hub to smaller markets...are you going to be working these possibly??
Work hard fly right..don't understand it
gigneil
Fri Dec 15, 2006 7:04 am
Fedex Feeder does operate ATR72 freighters, but I do not believe any of them are -500s.
N
lowrider
Fri Dec 15, 2006 12:39 pm
Northern Air Cargo also operates them, but I am not sure that they are -500's either. For what it is worth, I have been told that you can flight plan them for 10,000 lbs of payload and 2000NM. Its not a fast plane, but it can probably accomplish that mission for less than just about any other plane out there. It would probably be a direct replacement for the Convair 580. If the scarcity of available used ATRs is any indication, they are very effective.
Proud OOTSK member
LAXintl
Fri Dec 15, 2006 9:14 pm
A342
Fri Dec 15, 2006 9:37 pm
Yes, no ATR-72-500 has been converted to date, just the older -200/-210s.
[Edited 2006-12-15 13:39:39]
Exceptions confirm the rule.
Sat Dec 16, 2006 4:47 pm
Quoting Charlienorth (Reply 3):
Possibility......
Quoting Laxintl (Reply 6):
Thanks.
Quoting A342 (Reply 7):
Any significant differences betwen the two Externally.
regds
MEL
A342
Sat Dec 16, 2006 7:57 pm
Quoting HAWK21M (Reply 8):
The -500 has swept six-bladed props, while the -200/-210s have normal 4-bladed props.
gigneil
Sun Dec 17, 2006 3:54 am
I'd also like to point out there is no STC for converting the -500s at this time, but I am sure that it could be arranged if someone desired to do so.
NS
Sun Dec 17, 2006 7:41 pm
Quoting Gigneil (Reply 10):
Any list of Worldwide ATR72 operators.
regds
MEL
charlienorth
Tue Dec 19, 2006 7:31 am
If you get ATR-72's,learn 90VU,it's the rack behind the F.O,it's a lot of relays and boxes that can make your life easier if you know your way around..
Tue Dec 19, 2006 4:20 pm
Quoting Charlienorth (Reply 12):
learn 90VU
Why the name 90VU.Any reason.
regds
MEL
charlienorth
Wed Dec 20, 2006 1:38 am
Quoting HAWK21M (Reply 13):
regds
MEL
Have to go back through my books,the VU is the FIN,Functional Ident. Number,each shelf on the rack will have it's individual FIN((91VU,92VU etc)really helps when you are chasing relays,80 VU is behind the capt,mostly nav&com boxes,every electrical componant has a FIN and it corresponds on the ASM & AWM,it helps tremendously.
Wed Dec 20, 2006 6:35 pm
Quoting Charlienorth (Reply 14):
Panel numbers.Very dfferent from Boeing.
regds
MEL
charlienorth
Thu Dec 21, 2006 2:24 am
Quoting HAWK21M (Reply 15):
regds
MEL
Yes quite...also gets to be your friend when you get used to it  Smile
Thu Dec 21, 2006 7:25 pm
Quoting Charlienorth (Reply 16):
Any sketch of the CB panels layout.
regds
MEL
charlienorth
Fri Dec 22, 2006 1:20 am
Quoting HAWK21M (Reply 17):
regds
MEL
Not sure if I have any of my old training books from the ATR,will try to check after the holiday.
Fri Dec 22, 2006 3:18 am
Quoting Charlienorth (Reply 18):
Thanks.BTW.Merry Christmas.
regds
MEL
charlienorth
Fri Dec 22, 2006 5:44 am
Quoting HAWK21M (Reply 19):
regds
MEL
Thank you sir!!
Sun Dec 24, 2006 10:56 am
What type of Loading Equipment is that.
regds
MEL
Users browsing this forum: CALTECH, jaxfss and 19 guests
