dreampilot
What Is An Engine Rollback
Mon Jan 01, 2007 5:26 am
Will somebody please explain what happens during an engine rollback and what corrective action you should take. Thanks!
fr8mech
RE: What Is An Engine Rollback
Mon Jan 01, 2007 7:04 am
Roll-back is when the engine decelerates uncommanded. There are numerous causes, but usually the fuel control, or some input to it is at fault.
From a crew perspective, I would assume an attempt to accelerate is in order as long as there was no vibration felt or indicated. A restart if the engine went sub-idle or shut-down (flame-out).
From a maintenance point of view, depending on the engine, we would interrogate the EEC (or equivalent) and determine the fault. If non evident, we may tap the fuel system at certain points and check pressures (older engines) or even get into a borescope, though that may not yeild any clue.
ThePinnacleKid
Mon Jan 01, 2007 7:35 am
What are we talkin' about here??? A mx issue or just in normal speech???
I often call out "Roll-back" during our ERJ engine start sequence as our ITT decreases to a normal value.... the sequence of callouts for the engine start are:
- N2 (i'm watching N2 starting to turn)
- Oil Pressue (oil pressure starting to rise)
- Ignition (Ignitions have auto turned on)
- Fuel Flow (PPH is now increasing)
- Light off (ITT starts rising somewhat steadily and quickly upwards)
- N1 (N1 is turning)
- Rollback (ITT has peaked and is dropping to normal idle values... if it does not it would be heading towards it starting limits (800 degrees celcius) and we would have a "hot" start)
- 2, 4, 6, and a half... pressure, temps, vibes are good - stable start
(20% range of N1, 400 degree range of ITT, 60% range of N1, 300 pph range... three being half of six hence the half call... then finally that engines oil pressure and temps are in the green, and the vibrations are in the green and normal)
Chris
"Sonny, did we land? or were we shot down?"
Mon Jan 01, 2007 9:18 am
Quoting Fr8Mech (Reply 1):
Bae 146 - Selecting wing anti ice on at high altitude resulting is all engine rollback
B717/BMW engine - a number of uncommanded rollbacks and shutdowns in flight
CRJ - also a number of uncommanded shutdowns
777-200LR/300ER reduction to idle on takeoff when using a reduced thrust takeoff
Most aircraft either have an automatic relight or an engine relight procedure. For a rollback to IDLE, selecting TOGA can be a fix.
gkyip
Mon Jan 01, 2007 10:48 am
Quoting Zeke (Reply 3):
What do you mean by this? Do you mean the engine rolls back on the take off roll or the thrust reduction after takeoff and reduction to climb thrust?
Gary
The strength of the turbulence is directly proportional to the temperature of your coffee
fr8mech
Mon Jan 01, 2007 1:03 pm
Quoting ThePinnacleKid (Reply 2):
We also callout EGT rollback on engine starts. The poster stated 'engine rolback' which to me means: an rollback of all engine parameters.
As Zeke points out, several engines were/are affected by rollback under certain conditions or as random failures.
ftrguy
Mon Jan 01, 2007 2:07 pm
You fly for an airline and you've never heard of an engine rollback. Please tell me you're joking...
Mon Jan 01, 2007 5:04 pm
Quoting Gkyip (Reply 4):
For take off a reduced thrust setting was selected, and a number of engines went from takeoff power back to idle.
More details here RE: GE 90 Emergency AD (by Zeke Oct 6 2006 in Tech Ops)?searchid=169463&s=zeke#ID169463
ThePinnacleKid
Mon Jan 01, 2007 5:33 pm
Quoting Ftrguy (Reply 6):
No man..
If you read my post you would realize that I was making a statement for the original post'er to clarify if he was asking about rollback in ref to MX issue or ref to a callout he might have heard... if you read what I wrote you would realize that rollback as a call out during engine start is something that is quite normal and is what I WANT to say... not a bad thing... but I'm not clear as to what the Rollback he wants to know about is in reference to...
XFSUgimpLB41X
Mon Jan 01, 2007 5:49 pm
Ftrguy- Apparently I am not a true god of aviation like yourself, either. Try to keep the derogetory responses to yourself next time, OK?
Engine rollback in regards to the definition of the poster is not referred to anywhere in my manuals for the CRJ, and I wouldn't doubt that it was not referenced anywhere in PinnacleKid's ERJ manuals.
Normal reference in day to day basis for "rollback" is ITT stabilization after engine start.
Rollback in regards to the original poster would be referred to as an uncommanded engine response or uncommanded decelleration. Thus, the checklist for such an occurence would be executed.
Chicks dig winglets.
Mon Jan 01, 2007 6:23 pm
Quoting XFSUgimpLB41X (Reply 9):
Many airlines have a standard call when starting more than one engine at a time to call out "rollback" as one pilot maybe starting one, and the other monitoring an engine that is further progressed in the start.
Like the inflight rollback, the start rollback one is looking for the reduction in parameters to signal the end of the start.
dreampilot
Tue Jan 02, 2007 3:25 am
Sorry to confuse all you with engine rollback. The actual question was in regards to an interview which was "Passing the FAF, you get an engine rollback, what action do you take?" Hopefully this will clarify things a bit. Thanks!
Tue Jan 02, 2007 4:03 am
Quoting Dreampilot (Reply 11):
I would be inclined to do a missed approach, go into a hold somewhere and sort it out. If it was a fire I would be inclined to continue.
The difference is that I see one as a non-normal unstable approach, the other an emergency.
sabenapilot
Tue Jan 02, 2007 4:25 am
Quoting Zeke (Reply 12):
Non-normal and unstable approach indeed, but since the FAF is still far out from the runway, I'd say I'd simply split the cockpit (i.e. designating the F/O to just fly the plane further down the planned approach, preferably though automatics) while I take a good look at the engine parameters.
In the worst of situations, there is still ample time (roughly 5 min) to simply shut down the engine and land one engine out, whereas a decision to go-around on one engine at idle (possibly even flaming out somewhere during the missed approach) would also definitely lead to a non normal situation but then at high thrust.
Obviously, the closer you get to the minima, the more go-around minded I'd be getting for this sort of event as you need to be more concentrated on the stable approach aspect and the subsequent landing and one needs to judge each situation independently, but let's say that for as long as I am not marker inbound, I would be still be 'landing minded' rather than automatically 'go minded'.
ftrguy
Tue Jan 02, 2007 5:00 am
I apologize for my earlier comments. I was extremely upset when I wrote it and I guess I took it out on him. Once again I apologize...
ThePinnacleKid
Thu Jan 04, 2007 3:13 am
Quoting Ftrguy (Reply 15):
It's alright... apology accepted. More importantly to me though... just read the full post next time before jumping on someone.. you would have seen I know full well what a rollback is... I was just looking for the scenario in which we are talking about because it can mean very different things.
By the way, there is no mention anywhere of "rollback" as an official term in any of our ERJ manuals... and the scenario you are ref, which thank you for the clarification Dreampilot, would actually be called by our QRH "Engine Failure/Precautionary Engine Shutdown." In general day to day operations rollback is simply the ITT "rolling back" towards a normal stable idle value after it hits its peak value during the normal engine start sequence.
Chris
Clydenairways
Tue Jan 16, 2007 3:21 am
ALF502 engines installed on BAe146 aircraft had been prone to a phenomenon known as “rollback” ,which was an uncommanded power reduction and loss of thrust in certain icing conditions.
There were also instances where simultaneous rollback occurred on multiple engines on the same aircraft.
Aircraft were restricted to FL260 until a modification was developed to prevent this..
iwok
Fri Jan 25, 2008 8:56 am
Quoting Clydenairways (Reply 17):
What was the modification?
iwok
CosmicCruiser
Fri Jan 25, 2008 3:16 pm
Since a few here have gotten their "feathers ruffled" may I remind us all that one should really qualify statements that are a/c or airline specific. For example here we never say "rollback" to confirm a stable eng start. To me a rollback is the abnormal and uncontrolled reduction in thrust and not necessarily an emerg.
Quoting Sabenapilot (Reply 14):
Of course I'm speaking from only our ops but I'll make another point of view here. If you really do decide to shutdown the eng then you're obligated to run the eng. shutdown inflight chk list and brief an eng out app and ldg.. FAF inbound is not the best place to do this so yes the miss would be in order. For the most part (at least in my jet) after the eng has been shutdown if there is no apparent reason for the rollback (no fire/damage) then a re-light is an option so here's another chklist. If I'm on final and this eng "rollsback" I may just continue since I've lost no systems. I would weigh each situation on it's own in this respect considering wx, airport and what jet I'm in.
I'm sorry but I feel just the opposite. If I'm at mins and that rnwy is 1/2 mi or less in front of me this jet is landing. If I'm out there being vectored around and this happens I'd be asking for a big vector or hold and sort it out. Sometimes the best decision may go somewhat against the taught procedures. Here's a couple of good examples. In my jet a loss of the second eng (3 eng jet) after t/o or inflight requires a big chklist long pattern and a slat/no flap app & ldg. BUT if you're on final and a second eng fails the memory items are just "flaps 28, Vapp" and you land. Different thinking for diff situations. An old trick in the sim for a 2 eng jet was V1 cut on T/O come around for the ILS and on final get a fire warning in the remaining eng. Do you go by the taught chklist and pull that fire handle? Better not or you'll never see tomorrow.
Getdonnie
Fri Jan 25, 2008 4:55 pm
Guys,
I am a complete novice and at best an aviation enthusiast. Your posts are overwhelmingly educational and a bit intimidating. My question pertains to the physical support systems when there is a thrust issue. Is there or will there be a comparative support system for engine thrust issues as they arise much like when the RAM turbine is deployed to supports the aircraft flaps and vertical stablizers when there are problems with the hydrolic pumps?
Jetlagged
Fri Jan 25, 2008 5:40 pm
Quoting Getdonnie (Reply 20):
There have been such systems which usually operate at takeoff to boost the thrust of engines after one has failed. The later 727-200s with JT8D-17R engines had an APR system (automatic performance reserve), the MD-80 has ARTS (automatic reserve thrust system ?). Earlier 727s had a system to trip off the air conditioning packs in the event of engine failure on takeoff and the Fokker F.28 has a similar bleed trip system. Propeller driven aircraft have auto feather which does not increase thrust but significantly reduces drag if an engine fails.
Usually these systems are armed at takeoff when all engines are set above a threshold level. In other flight phases the autothrottle can usually compensate for the loss of engine thrust automatically. In the case of the BA 777 the lack of engine response made this ineffective.
tdscanuck
Fri Jan 25, 2008 5:50 pm
As Jetlagged notes, there are a lot of ways this can be addressed. On 737's, pushing the thrust levers full forward will cause the engine to go to the maximum thrust allowed for that model, regardless of the thrust rating of that engine. As a result, unless you're running the maximum thrust rating already, the engine has a thrust reserve that can be tapped in an emergency.
Tom.
ThrottleHold
Sat Jan 26, 2008 7:50 pm
Quoting Iwok (Reply 18):
Itwas some kind of alteration to the bleed band to change the amount of airflow through the engine.
Sat Jan 26, 2008 8:42 pm
Quoting Tdscanuck (Reply 22):
Thankfully some types eg 757s have EECs with supervisory & limiter functions.  Smile
regds
MEL
