dw747400
Another IFR Question
Tue Jan 02, 2007 5:11 am
As many of you have figured out, I'm in the final stages of earning my Instrument rating. In preparation for the checkride, I had a couple related questions about V-airways and changeover points. According to the AIM, a COP can either be marked or (obviously) take place at a fix that defines a dog leg. My question is what degree of change in course would be considered a dog leg? I'm looking at V1 down the East Coast and there is a 5 degree change in course at the WALLO intersection. Would this make WALLO a COP despite the fact it is only about a third of the way along the airway? Also, the other radial that defines the fix (CRE 034) has a DME marking at the fix. I assume a DME fix indicates that the radial can be picked up at that distance as well, but wanted to verify this.
Sorry if these questions are a bit strange, but I know tech/ops is the best place to get a fast and accurate answer from people that know!
If a visual helps, the route in question is on L-27, panels B and C.
Thanks.
CFI--Certfied Freakin Idiot
KELPkid
RE: Another IFR Question
Tue Jan 02, 2007 5:19 am
I would think any COP where you have to change aircraft heading to stay on the airway is, by definition, a dogleg. Most COP's involve only changing the receiver from one station to the next, and setting the TO bearing in the OBS selector.
As I recall, doglegs are depicted on NOS charts with an "x" at the dogleg point.
dw747400
Tue Jan 02, 2007 5:23 am
Thanks for the prompt response... I don't believe there are X's for doglegs on NOS charts--I looked and couldn't find any. In the legend you have X's for various mileage breakdown and computer fix purposes, as well as the X-flag for MCAs. Didn't see anything else.
KELPkid
Tue Jan 02, 2007 5:28 am
Quoting Dw747400 (Reply 2):
I pulled out my L-1, and I'm looking at the one dogleg I know well, (ATASY) on V165. it is depicted with an "X". I flew this airway on my long IFR cross country
EDIT: according to the L-1 legend, this X is "Mileage Breakdown or computer nav fix, no ATC functions." I'm noticing other airways with doglegs where the dogleg is marked by an intersection, seems to make sense.
[Edited 2007-01-01 21:33:26]
[Edited 2007-01-01 21:34:10]
ilikeyyc
Tue Jan 02, 2007 6:37 am
Quoting Dw747400 (Thread starter):
Think about it...You have to change to the new station and new radial to stay on the airway, so it must be a changeover point, regardless of how acute the angle is.
Quoting KELPkid (Reply 3):
Right. And non-standard COPs are marked with a rigid "S" sort of symbol.
Fighting Absurdity with Absurdity!
113312
Tue Jan 02, 2007 6:42 am
I recommend that you read, carefully, the introduction and legends for Jepp charts or NACO charts that you're using. Each element on every chart has significance. This forum really isn't the place to conduct ground school.
dw747400
Wed Jan 03, 2007 4:12 am
Quoting 113312 (Reply 5):
As you suggested, I had already read the appropriate sections of the charts, as well as the AIM and various groundschool course publications but was unable to fine a definitive answer. Your right the forum isn't the place to conduct a groundschool, but I think it is a legitimate place to gain information pertinent to a few specific concerns--though, as with any source, its best to confirm information with other resources.
Quoting Ilikeyyc (Reply 4):
The issue comes to mind because some single-segment airways do not have corresponding radials listed, yet because there is no published information suggesting otherwise, the COP is at the centerpoint.
Thanks.
