AirWillie6475
Etops Question
Wed Jan 03, 2007 7:26 pm
Hey what does ETOPS mean?
Just kidding. Actually my question is what do airlines do or what are their procedures when a plane has a depressurization as a result of the loss of an engine while they are in ETOPS area, especially if they are at later stages when they might not have a lot of fuel left to burn at lower levels.
fr8mech
RE: Etops Question
Wed Jan 03, 2007 7:51 pm
Why would the loss of an engine cause the aircraft to depressurize? Redundant engineering prevents that from happening. It would require multiple failures. For your scenario you would need:
1) An engine failure
2) An opposite engine pnuematic failure
3) An APU bleed failure
To answer your question, I believe all ETOPS calculations take into account a lower altitude.
RE: Etops Question
Wed Jan 03, 2007 11:33 pm
Quoting Fr8Mech (Reply 1):
And speed. For example, if a 777 loses an engine it probably cannot maintain its current cruise altitude and speed with that much less power available. So it will have to go lower anyway. In the event of a pressurization failure coupled with the engine failure (as Fr8Mech explains, this is extremely unlikely) the aircraft would go lower still until the air was thick enough. However, you're talking one in a zillion chances here. It's probably more likely that the other engine quits, and ETOPS rules "accept" that risk as it is.
airfoilsguy
RE: Etops Question
Wed Jan 03, 2007 11:36 pm
Quoting AirWillie6475 (Thread starter):
Engines
Turn
Or
People
Swim
 Smile
It's not a near miss it's a near hit!!
SlamClick
RE: Etops Question
Thu Jan 04, 2007 12:22 am
There are two major categories of answer for your question.
1. ETOPS on the NAT tracks.
2. ETOPS on random route elsewhere in the world.
Remember that there are alternate airports for the ETOPS portion that meet the rule in use, 120 minute, 180 minute etc. These places are not your filed destination but are well short of that. From Europe to the US over the north Atlantic for example, you pass mid-ocean less than one third of the way to your destination.
My point is that if you are no longer continuing to Munich but are diverting to back to Gander then you have tons of surplus fuel to burn in an engine-out, lower FL cruise to the alternate.
mrocktor
RE: Etops Question
Thu Jan 04, 2007 3:49 am
Uncontained failure.
RE: Etops Question
Thu Jan 04, 2007 4:14 am
ETOPS are really planning guidelines, the three major scenarios we look at our equi-time points (ETP)s are :
Engine failure with drift down to single engine drift down height (say cruise FL200-250)
Engine failure with depressurisation (cruise FL100 on one engine)
Depressurisation with no engine failure (cruise FL100 on two engines)
Generally if required at the planning stage fuel will be "built up" at ETPs to take into account these scenarios. This is the critical fuel requirement for the flight, so effectively if required to "build up" fuel at a ETP, fuel in excess of what is required for the flight is carried.
On a non-ETOPS flight, the critical amount of fuel is what is normally required to say get to your destination, do an approach, divert to your alternate, and land with the required reserves.
1: ___XXXXXXXXXXXXXXXXXX_--_ETOPS_DATA_--_XXXXXXXXXXXXXXXX_PN_0000
2:
3: ETOPS_ENTRY_N0000.3E00000.7________ETOPS_EXIT__N0000.2E00000.5
4:
5: ENRT_ALTN
6: AAAA_SUITABLE__1806/2215
7: BBBB_SUITABLE__1937/2202
8:
9: ETP_AAAA/BBBB_01/48_1849NM__P003/P007__BURN_0054_N00000E000000
10:
11: ______________AAAA/BBBB_-_EQUAL_TIME_POINT_DATA_-_ETP1
12:
13: DIVERSION_SUMMARY_..._______________AAAA________________BBBB
14: TIME_________02.04__@_AVG_0432KTAS
15: F.L._________0100
16: FOB__________007225
17: CRUISE_DIST_________________________0899________________0907
18: AVG_W/C_____________________________P003________________P007
19: ENROUTE_TEMP________________________P009________________P011
20: ETP_TEMP_/_FL100_______P012_________P010________________P010
21: AVG_GWT_______________________223251____223424____223248____223432
22:
23: BURN_SUMMARY_FL100_...________2_ENG.____1_ENG.____2_ENG.____1_ENG.
24: _______________________________LRC_______1LE_______LRC_______1LE
25: DIVERSION____111111__02.10____111111____111111____111111____111111
26: HOLD_________111111__00.15____111111____111111____111111____111111
27: MAP__________111111___________111111____111111____111111____111111
28: CONTINGENCY__111111___________111111____111111____111111____111111
29: ANTI_ICE_____111111___________111111____111111____111111____111111
30: ICE_DRAG_____111111___________111111____111111____111111____111111
31: APU__________111111___________111111____111111____111111____111111
32: TOTAL________022500__02.15____020000____018000____022500____019000
33: FOB__________019500
34: QTY_DIFF.___-003000
Sorry about the formatting above, the best I could do to get it formatted correctly.
This is a snippet from a fake plan showing the ETOPS data between two Airports AAAA and BBBB.
It is saying that the single engine flight time at the ETP will be 2:04 min at 432 kts.
As you can see the two engine long range cruise (2 ENG LRC), which is the two engine depressurised cruise I mentioned before to either AAAA or BBBB are the more critical fuel scenarios, as going to AAAA from the ETP we would need 20t of fuel, to BBBB 22.5t.
At this ETP however we only have 19.5t of fuel (line 34) so we would need to add 3t of fuel as an ETOPS build up to have enough fuel at the ETP to meet the critical fuel requirements.
1: ___XXXXXXXXXXXXXXXX_--_FUEL_ANALYSIS_--_XXXXXXXXXXXXXXX_PN_0000
2:
3: TAXI_______________1.000
4: FLIGHT___________105.000__00.00__PERF_FACTOR_P00.0%
5: APPROACH__________01.500
6: ARR_ALLOWANCE_____01.500
7: CONTINGENCY_(_5%)_04.000__00.00
8: HOLDING_BBBB______00.000__00.00
9: DIVRSN_TO_CCCC____02.000__00.00
10: S/HOLD_AT_CCCC____00.000__00.00__AV_CRZ_F/F_-_00000_KGS
11: F.F.R.____(HOLD)___2.000__00.00
12: ETOPS_B/UP________03.000__00.00__INC._BURN_PER_0000KGS_00000
13: MIN_REQUIRED_____120.000__00.00
14:
15: PLANNED_ADDIT_____00.000__00.00
16:
17: PLANNED_FUEL______00.000__00.00
18:
19: ADJUSTMENT_______.......__.....
20:
21: TOTAL_FUEL_______.......__.....
The required ETOPS build up would then find its way onto the fuel analysis (line 12) where the extra 3t is added.
Hope this answers your question.
fr8mech
RE: Etops Question
Thu Jan 04, 2007 5:12 am
Quoting Mrocktor (Reply 5):
And an uncontained failure, that punctures the fuselage in a sufficient manner to depressurize the aircraft, without destroying the wing, is an even more remote possibility than the triple failure I cited.
And yes, I know about the uncontained failures on the early CF6 engines. Still giving the overall usage, very remote.
SlamClick
RE: Etops Question
Thu Jan 04, 2007 5:18 am
ETOPS certification really runs along the lines of single item failures like engine failure OR loss of cabin pressure, but not both.
ETOPS has a more restrictive MEL than for around-town flying. If you have a deferred maintenance item that could adversely affect your ability to make an alternate in the event of ___ the plane is probably going to be routed the long way around or even parked until it is fixed.
OldAeroGuy
RE: Etops Question
Thu Jan 04, 2007 11:09 am
Quoting SlamClick (Reply 8):
No, the ETOPS regulations specifically require that Twins cover an engine failure and depressurization when doing mission fuel planning.
This is done per regulation, independent of the probability of the two failure conditions.
Quoting Zeke (Reply 6):
Zeke is correct as this is the second of the three failure cases he lists.
This is an area where ETOPS Twins have a safety margin that may not be present for Quads. Quads are not required by regulation to plan for this type of scenario. It's up to the individual airline Ops Department, with nudges from their POI (Principal Operations Inspector) perhaps, to consider it.
The proposed LROPS rules would make all Twins, Tris and Quads do mission fuel planning considering an engine failure with a depressurization and level the playing field in this area.
RE: Etops Question
Thu Jan 04, 2007 1:27 pm
Quoting OldAeroGuy (Reply 9):
OAG,
The bit you have not painted is that with the 330/340 share the same fire detection and suppression systems they both have the ETOPS equipment on them. The systems on the 340 have a greater level of redundancy than the 330, with the same ETOPS safety requirements as the 330, including the ability to use the APU up to 41000'.
The only Quads that I know of that do not have ETOPS levels of fire detection and supression systems fitted standard come from the USA. I cannot recall being able to use the APU on the 744 in flight.
I think you comments are relevent to the 744/777 comparison, but not to the the 330/340/380.
I am not aware of any operator that does not allow for a depressurization with all engines on a Quad, which is more critical than the case of a three engine depressurization.
Which operators do you know of not plan for depressurization with a Quad ?
mrocktor
RE: Etops Question
Thu Jan 04, 2007 8:08 pm
Quoting Fr8Mech (Reply 7):
Not necessarily true. Statistically uncontained failures occur once every million to ten million engine hours, the "vulnerable area" is about 1/10th of the engine circumference. The triple failure is probably a couple orders of magnitude less likely - from a purely mathematical point of view.
More importantly, uncontained failures are not treated statistically in aircraft certification. It is required that the aircraft survive the uncontained failure except in cases where the aircraft configuration makes that impossible (such as damage to the opposite engine).
BAE146QT
RE: Etops Question
Thu Jan 04, 2007 8:56 pm
Quoting Airfoilsguy:
Engines
Turn
Or
People
Swim
777 Captain on PA: "Sorry folks, we've had an engine failure so we're going to be about two and a half hours late to our destination"
Passenger: "Man I hope we don't lose the other one. We'll be up here all day."
Todos mis dominós son totalmente pegajosos
fr8mech
RE: Etops Question
Thu Jan 04, 2007 8:57 pm
Quoting Mrocktor (Reply 11):
That's a pretty big range.
mrocktor
RE: Etops Question
Thu Jan 04, 2007 10:23 pm
Quoting Fr8Mech (Reply 13):
One order of magnitude is a pretty tight range for things that happen that infrequently  Wink . When the AC that deals with uncontained failures was first published (1989) the statistical data indicated 1 in a million, current technology engines are in the 1 in ten million range. Since we have airplanes of all ages flying, I gave the range of possibilities.
OldAeroGuy
RE: Etops Question
Fri Jan 05, 2007 1:03 am
Quoting Zeke (Reply 10):
I thought we were talking about mission fuel planning under various scenarios. Where did I say anything about fire detection/suppression?
But while we're on the subject, the amount of fire suppressant is important for the route flown. Using your comparison of the A330 to the A340, no A330 is required to carry more than 222 minutes of fire suppressant (207 min ETOPS + 15 min Hold contingency). The current regulations do not require the A340 to be carrying 255 min of fire suppressant (240 min diversion + 15 min Hold) even though it could be flying in an area that would require a 240 min diversion or longer.
This is another operational discrepancy that will be addressed by the proposed LROPS rules. Airplane capability and fitted equipment will be matched to the missions being flown, not the number of engines carried.
How do you know that depressurization only is more critical than an engine failure plus depressurization for a Quad? Both are going to be flying at 10,000 ft unless there is an inordinate amount of pax O2 onboard. How are you sure that the fuel flow at 10,000 ft with four engines operating is worse than with three engines operating? You're assuming that the TSFC for the all engine power setting is so much worse than that for the three engine power setting that windmilling drag and control drag for the engine inoperative case can be ignored. At least Twins are required to check this condition. Have you ever checked it for a Quad? If a check and fuel planning is a requirement for a Twin, why shouldn't it also be a requirement for a Quad? After all, the probability of an engine failure combined with a depressurization is higher for a Quad than a Twin simply because there are more engines to fail. The ability to use the APU at FL410 won't help keep the airplane pressurized if an outflow valve is stuck in the open position.
By the way, if you're right about the TSFC relationship for four engine vs three engine operation at low altitudes for a Quad, I'm surprised that Quads don't shut down an engine during low altitude holds (said with tongue firmly in cheek)
RE: Etops Question
Fri Jan 05, 2007 2:44 am
Quoting OldAeroGuy (Reply 15):
All of our 330/340 aircraft carry 240-280 minutes. The 340 has the same system as the 330. Two bottles, one with an immediate discharge, the other with a 240+ minute slow release.
That is not standard feature on quad aircraft coming form the USA.
Because that is what our plans say. Depressurization with 4 engines burns more fuel than the 3 engine case, the LRC remains basically the same, fuel flows are reduced on 3 engines.
Yes we do check this (the flight planning system) every flight.
We do, our 330 guys fly 340s and vise versa, the plans between types are almost identical.
Nimrod shuts down the two outboard engines at low altitude to extend endurance.
RE: Etops Question
Fri Jan 05, 2007 3:11 am
Quoting Zeke (Reply 16):
Indeed. But there are AFAIK lubrication issues unless the design specifically allows it.
OldAeroGuy
RE: Etops Question
Fri Jan 05, 2007 4:51 am
Then your A330's are carrying additional weight that isn't required.
Tell CX Ops that you've got an idea to improve fuel burn by reducing fire suppressant on the A330. There is no operational issue since the A330 can never need more than 222 min. to be legal.
Does every airline with Quads check three engine vs four engine depressurization? Is the answer always that the four engine pressurization is worse?
Quoting Starlionblue (Reply 17):
So does the P3, but they have a feather button. In addition, two engines shutdown is symmetric with no control drag and now you really can be in the sweet spot for TSFC.
pygmalion
RE: Etops Question
Fri Jan 05, 2007 5:17 am
Quoting OldAeroGuy (Reply 18):
The shut down of the outboard engines for sub hunters is based on "loiter time" or hold on station time to maximize finding a slow moving sub or ship (relatively slow that is) not a "best range" fuel burn scenario. Completely different mission. When I was a P3 flight engineer ( long long ago) , we kept very close track of fuel remaining vs fuel needed at best 3 engine cruise to ensure if poo hit the fan we could make it home. You could not assume you could make it back on 2 engines even if you climbed like a pig to some better cruise altitude. It would climb on two but it was slow. Loiter time was better with 2 shut down and feathered but it was NOT best range
RE: Etops Question
Fri Jan 05, 2007 5:40 am
Quoting Pygmalion (Reply 19):
Very good point. So this kind of strategy is not applicable for planes that are actually going somewhere. But for the P-3 loitering that is not the primary mission driver.
pygmalion
RE: Etops Question
Fri Jan 05, 2007 6:04 am
It was great to spend 14 hours in the plane but not really go anywhere.  sarcastic
airfoilsguy
RE: Etops Question
Sat Jan 06, 2007 3:35 am
Do etops rules apply to biss/Private jets?
RE: Etops Question
Sat Jan 06, 2007 6:30 pm
Had a look at a few failures on the 346 with a 1000 nm diversion at 260t. I did it for one engine inoperative, 4 engines depressurised, 3 engine depressurised, and 2 engine depressurised.
Data below
EnginesAltitudeTimeFuel
4FL370ReferanceReferance
3FL370+3%+5%
4FL100+27%+71%
3FL100+24%+51%
2FL100+19%+58%
OldAeroGuy
RE: Etops Question
Sun Jan 07, 2007 3:09 am
Quoting Zeke (Reply 23):
Data below
Interesting. Do you have these data as a function of weight?
RE: Etops Question
Sun Jan 07, 2007 3:50 am
Quoting OldAeroGuy (Reply 24):
Yes in the QRH and FCOM 2, takes a bit to do all the calculations as they have initial reference weights that need corrections made to them based on the actual weight and level.
Also for the 2 and 3 engine diversions, the fuel flows are given as kg/hr/engine, and the speeds as IAS, so I needed to convert IAS to TAS, work out the stage length and then multiply that by the number of engines.
[Edited 2007-01-06 19:53:55]
buckfifty
RE: Etops Question
Sun Jan 07, 2007 5:45 am
The cargo hold has two bottles, one which will release it's contents in 60 seconds for fire retardation. The second one is for the afformentioned slow release suppression. The same bottles are used for the fore and aft compartments, but can only release into one compartment at a time, by the use of explosive squibs which, for obvious reasons, cannot be reset. So if we pressed the wrong button (i.e. fire in aft, pressed fwd), then we're basically f'ed.
From what I was told (it isn't written anywhere in the manuals, so can be taken with a grain of salt) it isn't the amount of supressant that gives the 280 min flow time, but the metering device which limits the flow of suppressent to around 280 mins. Both the quick release and slow release bottles are of the same size, and are interchangeable.
RE: Etops Question
Sun Jan 07, 2007 6:50 am
Quoting BuckFifty (Reply 26):
The system in the 330 & 340 are the same, the first bottle is larger, it is the one on the left in the photo below, the second one is a "top up" as the compartments are sealed.
AFAIK the bottles are not interchangeable.
OldAeroGuy
RE: Etops Question
Sun Jan 07, 2007 11:52 am
From what I was told (it isn't written anywhere in the manuals, so can be taken with a grain of salt) it isn't the amount of suppressant that gives the 280 min flow time, but the metering device which limits the flow of suppressant to around 280 mins.
Fire suppression depends on holding a given percentage concentration. Metering the second bottle is what holds the concentration.
If the flight time is less, the amount of suppressant in the second bottle can be reduced.
buckfifty
RE: Etops Question
Sun Jan 07, 2007 2:41 pm
Quoting Zeke (Reply 27):
Thanks for the info eh. I was told this during a line check, but with pictorial evidence, I suppose I can refute this the next time out.
Quoting OldAeroGuy (Reply 28):
From what I understood before, I thought because the bottles were interchangeable, that by economies of scale, there won't be a need to reduce the suppressent. But a picture speaks a thousand words I suppose.
HiFi
RE: Etops Question
Mon Jan 08, 2007 10:44 pm
Correct.
Furthermore, ETOPS regulation demands that all failure conditions not shown to be extremely improbable will not cause fuel exhaustion.
In other words: either you make a failure extremely improbable (P<10e-9), or you make sure that there is enough fuel for the aircraft to land at its destination or at the closest suitable airport. Doesn't matter if when depressurized you have to fly lower, or if deployed spoilers increase drag.. there is enough fuel. Such failures and their effects on fuel consumption are included in the fuel tables of the ETOPS aircraft manuals, not necessarily in an explicit form, but they are  Wink
Quoting Airfoilsguy (Reply 22):
No, at least not in the FAA.. ETOPS applies only to Part 121. The ETOPS NPRM, which may soon become a law, will make ETOPS effective in Part 135 (charter operation, for instance), for diversion ranges of 180 minutes and up.
EASA is a bit more restrictive about this...
no commercial potential
HiFi
RE: Etops Question
Thu Jan 11, 2007 12:19 am
Quoting HiFi (Reply 30):
Update: that just happened this week...
Users browsing this forum: Aircellist, AwyrCymru, E2 and 3 guests
