FL370
How Does A Turbo Jet/prop Work?
Sun Jan 21, 2007 1:21 pm
i was reading some papers on turbo jets/props, and my question is...
1) how does the turbo work in the engine?
2) does the turbo kick in after a certain RPM/speed like in a car?
3) and everything in between
fl370
Fly2HMO
RE: How Does A Turbo Jet/prop Work?
Sun Jan 21, 2007 1:39 pm
I think you are confusing terms here...
A turboprop is essentially a jet engine with a prop in the front and a gearbox in between the two.
You can't have a turbocharger in a turbofan/jet/prop
However, in a piston engined GA plane, say, a Columbia 400, C182T, etc., the turbocharger works just like in a car, and usually they have intercoolers as well.
Some are just "turbo-normalized", meaning the engine will produce the same amount of power at sea level as a normally aspirated version of the same engine up to a given altitude. I.E. the engine will run like it is always at sea level. Others are actually boosted, meaning the pressure from the turbocharger is greater than normal atmospheric pressure, giving additional horsepower.
There are also superchargers, but they are rarely seen nowadays, they were really popular for WWII aircraft though.
[Edited 2007-01-21 05:41:35]
[Edited 2007-01-21 05:46:12]
ZBBYLW
Sun Jan 21, 2007 1:59 pm
The turbine engine is not like a car what so ever. A car's turbo charger uses exhaust gases in order to spool up a turbine which increases the incoming air to increase the compression inside a regular internal combustion engine.
First I will start off with the turbojet engine. The air is taken from the big opening in the front of the engine, it is then compressed in what is called the compressor. Right after this we get to the combustion chamber where the Jet fuel is now added. This air/fuel now expands as in an internal combustion engine but is redirected backwards and passes through a turbine. This turbine is connected back to the compressor which sends air to the combustion chamber where the fuel is added and ignited, which goes through the turbine spools it back up and have continuous power. If you are interested in military a/c and the afterburner it is basically another combustion chamber which is positioned aft of the turbine but before the engine nozzle (where the exhaust gets directed outwards). Basically just makes another power source that pushes even more air out of the nozzle. Thus making the aircraft have more power.
So basically this is what happens. The turbo jet sucks in air and compresses it. In the combustion chamber the fuel is added and then gets shot through the turbine which makes the compressor spin. Exhaust flows out the back and forward you go.
Ok now for turboprops.
Basically what we have now is like above another jet engine, however it is now attached to a prop. The turbine at the back of the engine is still turned by the hot exhaust which turns a shaft that drives the prop. (Direct drive). There is also another system which is used on other a/c that is similar to a automatic transmission found in a car. Someone else should be-able to know about this though. So again like the turbojet the turboprop has a compressor a combustion chamber and a turbine. The air that runs threw and spools up the turbine also turns the compressor, and thus you have your continuous cycle again. The difference is that the shaft is connected to a transmission which is then connected to a propeller. This propeller is what actually creates most if not all of the trust.
Anyhow thats it for me, I am quite tired so if any of that makes sense great! Cheers Chris
Keep the shinny side up!
Fly2HMO
Sun Jan 21, 2007 2:27 pm
Quoting FL370 (Thread starter):
Wait a sec, didn't you just ask this already a couple of days ago?
AirWillie6475
Sun Jan 21, 2007 3:26 pm
Suck Squeeze Bang Blow
TheJoe
Sun Jan 21, 2007 4:52 pm
Well, I think you may be a little confused when it comes to the terminology here... A "turbojet" or "turbofan" and all other types of jet engines do not specifically contain a turbo, they essentially are a giant turbo. The name "turbo" on a car comes from "turbo-supercharger" which is just a turbine driven supercharger instead of a direct mechanical drive from the engine. The turbine extracts energy from the exhaust gas of the car which would otherwise just be lost to the atmosphere. This is fundamentally how a "gas turbine" or aeroplane engine works. Well, the names "turbofan", "turboprop" and "turbojet" really just mean a turbine driven fan, a turbine driven propeller and a jet turbine. The reason for the different design is based on the propulsive efficiency of the engine which depends on the speed at which it is designed to operate. "Turboprops" have a higher propulsive efficiency at low speeds. "Turbofans" are better at transonic speeds and "turbojets" are more efficient at supersonic speeds. "Propulsive Efficiency" is just a term which tells us how good an engine is at turning the power is produces in to useful thrust for the aeroplane, normally expressed as a percentage. For example, a "turbofan" may have a "propulsive efficiency" of 80% at a certain forward speed. As this speed gets higher or lower, the efficiency may decrease. Anyway, this all a little off topic. Just a brief insight in to why the engines are named and designed the way they are.
You obviously know how a turbo works in a car. You make this clear in point two. Well, the turbo "kicks in" in a car because it has enough exhaust gas flow for the compressor to start compressing a larger mass of air...
A typical car compressor:
Big version: Width: 782 Height: 599 File size: 59kb
Turbo
If you have a look at this picture of a car turbo, you can see that the blue section is the compressor stage and the red section is the turbine, driven by high velocity exhaust gasses from the engine exhaust.
We'll now compare this to how a "Gas turbine" works. The following diagrams are from a GE J79 "turbojet".
Here is a picture of a typical compressor. It serves the same purpose as the compressor in a car turbo.
Big version: Width: 800 Height: 428 File size: 78kb
Compressor
Note the several stages of compression. One row will be a rotating or "rotor" assembly, followed by a stationary stage or "stator". Each rotor-stator pair, normally referred to as a "stage" compresses the air a little. IIRC, with enough stages, compression ratios of 30-1 are attainable. Simply speaking, for ever pound per square inch (psi) at the intake you will have 30psi at the compressor discharge.
You may ask "why do you want to compress all of that air?". The answer is simple. We burn it! The more air you compress, the more fuel you can burn. The more fuel you burn, the more power you produce. This is where the next section comes in.
The combustor:
Big version: Width: 667 Height: 559 File size: 65kb
Combustor
This is the stage in the engine where the compressed air and fuel is mixed, burnt and propelled out through the turbine. In a car turbo, this stage is achieved by the engine itself and is normally just a waste product. In a gas turbine, the combustor is specifically designed for this task. Note that the combustor does not produce more pressure in the combustion chamber, but rather increases the velocity of the exhaust gasses that are sent through the next stage of the engine. This is where the turbine does it's job.
The turbine:
Big version: Width: 433 Height: 599 File size: 55kb
Turbine
The job of the turbine is to extract as much of the velocity from the air that has passed through the combustion chamber as is required by the engine. Each turbine stage is made up of a nozzle-turbine pair. The turbine spins and extracts the energy from the velocity of the air and the nozzle guide vanes guide the air on to the next stage of turbine. The more energy that is extracted by the turbine stages, the less is left over in the exhaust when it comes out the back of the engine. Now this is where the different types of engines do different things with the exhaust gasses.
A "turbojet" will extract a little bit of energy from the exhaust to drive the compressor. The rest goes out the back as thrust. The "turbofan" extracts more energy to drive the great big fan that sits on the front of the engine. It is this fan that produces most of the thrust of the engine. If we compare two engines, a "turbofan" and a "turbojet" that are producing the same amount of thrust, we will find that the "turbojet" moves a lot less air out the back of the engine at a much higher velocity than the "turbofan". The "turbofan" moves a lot more air but does not accelerate it as quickly. This is where the propulsive efficiency and the operating envelope of an engine determine what type of engine is required.
Finally, the "turboprop" converts as much of the energy of the exhaust gasses as possible into torque for the propeller through some sort of gearbox arrangement. Only a very, very small amount of the thrust produced by the engine is from the exhaust.
All the processes which I have described are happening at the same time inside the engine. The air flows through the engine in the order which I have written in.
Finally, we'll briefly talk about the construction of the engine. Inside the engine have a number of shafts which we call "spools". In modern Aero engines we have up to three spools.
The following is a simplified airflow schematic of a turbofan engine:
Big version: Width: 529 Height: 341 File size: 26kb
Gas Turbine Schematic
A spool is one of the major rotating assemblies of the engine. In the picture provided, the green "spool" is the low pressure spool, containing the low pressure compressor (LPC) and low pressure turbine (LPT). It is driven by the "low pressure turbine". Note this spool also drives the fan. On the 737 engine, which is set up in a similar manner to this one, we call this spool "N1". This is indicated to the pilot in terms of a percentage of "N1", 100% being max power. The purple spool which has the high pressure compressor (HPC) and high pressure turbine (HPT) is the high pressure spool, driven by the high pressure turbine. You guessed it, it's called "N2". This is also indicated to the pilot in terms of percentage of "N2", 100% being max power. These two rotating speeds give the pilot an indication of how much power the engine is producing. Note that a number of turbine stage can drive a number of compressor stages. Three turbine stages may drive seven compressor stages. In the car turbo I have used as an example, one turbine stage drives one compressor stage. In the simplified turbofan diagram above, the last four stages of turbine on the right hand side are the LPT and they drive the fan on the front of the engine (left hand side) and the three stages behind it, which is LPC. The two purple stages on the right hand side of the engine (just before the LPT) is the HPT. This drives the last seven stages of compressor (the HPC). Note that the N1 spool shaft runs down the engine on the inside of the N2 shaft which is also spinning. This is where things can start to get a little complicated!
Anyway, I hope this has given you a little insight in to how a "turbojet/prop/fan" works FL370. If you have any questions, just post them here. I'll keep a look out!
To all those die hard tech/ops people out there, this is just a basic overview of how an engine works. Nothing too in depth. Please feel free to add anything I may have forgotten or correct me if have made any mistakes. Thanks!  Smile
ZBBYLW
Mon Jan 22, 2007 2:02 am
Quoting AirWillie6475 (Reply 4):
Not at all, note a turbojet, turboprop and turbo fan engine are not internal combustion. Suck squeeze bang blow only works with conventional 4 cycle internal combustion engines. Go read thejoes or my response, I think the joes is better though with diagrams and what not.
Cheers Chris
HaveBlue
Mon Jan 22, 2007 2:54 am
Nicely done TheJoe.  Smile
Here Here for Severe Clear!
SlamClick
Mon Jan 22, 2007 4:10 am
Quoting ZBBYLW (Reply 6):
Not at all
Actually, as inexact an explanation as that is, it is equally inadequate for a jet as for a piston engine. Like a recip, a jet engine also has:
intake
compression
(ignition event)
power
exhaust
The least descriptive of these words is "bang" to represent the burning of the fuel. It sounds like an explosion is represented but in a properly running engine the fuel charge does not explode, it burns evenly in a carefully engineered pattern. Of course in the burners of a jet engine it is continuous and in a reciprocating engine it is intermittent, even though it happens neary 200 times per second in any given cylinder in some racing engines. It may be common to refer to these as "strokes" in piston engines but that is somewhat incorrect as intake and exhaust valves do not open and close exactly at the beginning or end of these strokes. It is more proper to refer to them as "cycles" as they are only approximately matched to strokes. Jets have the same cycles.
Well, yes they are. An example of an EXternal combustion engine would be a steam engine where the fuel is burned in the firebox, heating water to make steam, the steam is stored under pressure and used in cylinders at any distance the designers choose, to develop the torque, then exhausted overboard or returned to desuperheaters and condensers. An extreme example would be a "fireless" locomotive such as were used in sugar cane fields. The boiler was back at the motorhouse and the locmotives carried only a steam tank which was serviced on each round trip.
In a jet engine it is all done in the same unit and in the same sequence as in a piston engine.
ZBBYLW
Mon Jan 22, 2007 6:01 am
Quoting SlamClick (Reply 8):
Right then I stand corrected on all of that...
However just looking for some clarification, while the jet engine is not an external combustion engine, I have always been told that an internal combustion engine is more or less a regular piston engine where everything happens inside these cylinders. Could you go into a bit more depth on where the jet engine lies, weather it meets halfway or is in fact a internal combustion engine.
SlamClick
Mon Jan 22, 2007 6:11 am
Quoting ZBBYLW (Reply 9):
I think I'd rather leave that to someone with the engineering education who can speak with more actual authority than I can on it. That is what I've been taught in professional level instruction (military and airlines for example) and I've accepted it because it made sense as described. If someone else can add or even dispute what I said, I'd welcome that input.
Another example has occurred to me, and that is the Wankel rotary engine. Again, an internal combustion engine but without pistons. The faces of the trochoid rotors act in a manner similar to piston domes or turbine blade surfaces. The epicycloid chambers (don't you love Mazda brochures?) act in a manner similar to cylinder walls, cylinder heads and the surfaces of the closed valves in piston engines and as the confines of the compressor section and the turbine section of jet engines. All achieve the same intake-compression-ignition-power-exhaust cycles. The rest is just differences in shape.
Some good discussion might be found of this online. Sorry, but I have company coming and cannot look it up myself.
Goldenshield
Mon Jan 22, 2007 6:31 am
Here's an interesting engine being worked on right now.
Quasiturbine
Try debating this one.  Smile
Fly2HMO
Mon Jan 22, 2007 9:16 am
Well, in jets everything happens inside as well, I personally wouldn't count them as external engines at all, not even with afterburners.
Quoting Goldenshield (Reply 11):
That would be internal combustion, like a wankel
A stirling-cycle engine would qualify as external combustion in my book.
[Edited 2007-01-22 01:34:27]
ZBBYLW
Mon Jan 22, 2007 9:28 am
Quoting FLY2HMO (Reply 12):
I can understand how all the steps are the same.... how there is the intake, the compression the power and exhaust, I was always under the impression that it had to be confined in the space. It is hard to wrap your head around a new concept of something you thought you knew, o well. I think I got in now though... That new engine you showed there looks like a glorified Wankel rotary to me.
David L
Mon Jan 22, 2007 10:09 am
Quoting ZBBYLW (Reply 13):
  • In a piston engine, the actions are performed sequentially in time but in the same space. I.e. there's a suck, then a squeeze, then a bang and then a blow, all in the same place.
  • In a turbine, the actions take place sequentially in space but at the same time. I.e. one part of the engine is constantly sucking, one part is constantly squeezing, one part is constantly producing the "bang" and one part is constantly providing the "blow".
There are some excellent details above.
Quoting FLY2HMO (Reply 3):
Yes, here:
How Does A Turbo Work In A Turbo Jet? (by FL370 Jan 16 2007 in Tech Ops)
... but judging by the thread starter's comments in the first thread, I'm guessing he didn't know it had been moved to Tech/Ops and thought it had been deleted.
Edit: After all that, I forgot to mention that, as long as all that takes place inside the engine, it's an internal combustion engine.
[Edited 2007-01-22 02:24:09]
jetstar
Mon Jan 22, 2007 10:13 am
Excellent explanation TheJoe.
I would like to add one thing and that is about the tailpipe and how important it is in a jet engine.
As in your picture of the simplified airflow schematic of a turbofan engine, it shows the tailpipe or nozzle end smaller at the discharge end that the turbine end. Remove the tailpipe and all you have is a gas turbine engine like an APU, the exhaust gas airflow just dissipates without creating much thrust from the exhaust gases. It is the reduced size at the discharge end that increases the velocity of the exhaust gas and creates the thrust that makes the engine into a jet engine.
TheJoe
Mon Jan 22, 2007 2:45 pm
Quoting Jetstar (Reply 15):
You raise a very good point Jetstar. A turbojet without a propelling (convergent) nozzle wouldn't be much of a turbojet at all. Thanks for adding that.
Yes, the jet engine is an internal combustion engine, it just follows a different working cycle. Speaking totally from a general point of view, piston engines follow the Otto cycle or "constant volume cycle" while gas turbines follow the Brayton or "constant pressure" cycle. These describe the working cycles of the engine. I don't have enough time to write much about this right now, as an in depth explanation of these cycles is a little complicated and could take a long time! If you're curious, look up "Otto cycle" or "Brayton cycle" on the internet. If anyone else would like to describe the process, feel free!
mrocktor
Tue Jan 23, 2007 2:10 am
Quoting TheJoe (Reply 16):
The way I understand it, an internal combustion engine is one where combustion occurs in a chamber not connected to the external environment. This is a case in piston engines (valves are shut when combustion occurs) and false in jet engines (the combustion chamber is open to the environment all the time - in front and in the back).
Incidentally, it also is false in steam engines, where the combustion chamber is also connected to the external environment (by the chimney). The term was created to differentiate between the "new" piston engine type and steam, after all.
[Edited 2007-01-22 18:11:10]
FredT
Tue Jan 23, 2007 2:37 am
How about sticking with the terms we learned while studying engineering?
Turbine engines
and
Reciprocating engines
and be done with all the hair splitting?
Fly2HMO
Tue Jan 23, 2007 5:31 am
Quoting Mrocktor (Reply 17):
Um huh, so whats the case when the valves are open?  scratchchin  Big grin
I can't remember any kind of engine that truly is external combustion other than one operating with the stirling cycle, maybe somebody can refresh my memory.
Analog
Tue Jan 23, 2007 6:59 am
Quoting FLY2HMO (Reply 19):
Aerospike?
http://en.wikipedia.org/wiki/Aerospike_engine
Maybe also ramjet, as the combustion is in a tube that's open to the outside world, unlike a turbojet, where the combustion is followed by a turbine.
timz
Tue Jan 23, 2007 7:49 am
Steam locomotive?
Analog
Tue Jan 23, 2007 7:53 am
Steam turbines when not nuclear powered (fission is not combustion).
Blackbird
Tue Jan 23, 2007 12:15 pm
Quasi-Turbines could be quite useful as an automotive engine. It would produce more HP with the same size, and as a result better efficiency
N231YE
Tue Jan 23, 2007 1:10 pm
Quoting TheJoe (Reply 5):
Very nicely put.
Quoting Blackbird (Reply 23):
Quasi-Turbines
Interesting...it looks like a 4-sided rotor derivative of the Wankel engine.
I don't get the efficiency part though. If it is in fact a derivative of the Wankel, then its weight and power are a plus, but its fuel efficiency is a negative.
mrocktor
Wed Jan 24, 2007 4:32 am
No combustion is going on...
TheJoe
Wed Jan 24, 2007 2:32 pm
According to engineering text, a gas turbine is referred to as an internal combustion engine.
http://en.wikipedia.org/wiki/Internal_combustion
Read the first couple of paragraphs. I have plenty of other quotes from various engineering texts to support this as well.
mrocktor
Wed Jan 24, 2007 8:36 pm
Quoting TheJoe (Reply 26):
Interesting. I have not seen that usage and find it conceptually deficient. But I'm done nitpicking  Wink
Wed Jan 24, 2007 11:55 pm
Quoting Analog (Reply 22):
As Timz says, steam locomotives and so forth have external combustion. The fuel is burned, heating water in a boiler. This is external to the engine. The hot steam is used to push pistons, which turn the wheels.
jetmech
Sun Jan 28, 2007 7:09 pm
G'day Techies  Smile,
I have been doing a bit of reading about the internal / external combustion issue, and I think I now understand the fundamental difference.
An External Combustion process is one where a fuel is combusted to produce heat in a body of fluid. This heat is then transferred to another, separate body of fluid. This second body of fluid is then used to produce work.
An Internal Combustion process is one where fuel is combusted to produce heat in a body of fluid. This same body of fluid is used to produce work.
Most items of turbo-machinery used in modern aircraft are of the internal combustion type, that is, heat is added via the combustion of fuel to a given body of fluid (air). This same body of fluid is then expanded through the turbines to produce work.
An example of an external combustion turbine may be the steam turbine's used in coal fired power-plants. In some coal fired power plants, the cycle may be arranged to add heat to a closed circuit of water (this may be highly pressurised to prevent the water boiling). The heat in this closed circuit is transferred via a heat exchanger to another, separate circuit of water. The water in this second circuit responds to the input of heat by changing phase from liquid water to steam, which is then expanded through a turbine to produce work.
A nuclear power plant usually has these separate fluid circuits to prevent the leakage of radiation into the environment, but a nuclear process is not a combustion reaction.
Yes, most "classical" steam engines combust a fuel to heat the air in the boiler. This heat is transferred to a separate stream of fluid (liquid water) that runs through numerous tubes arranged inside the boiler. The heat causes this water to change phase into a vapour (steam) which is then used to produce work.
It depends. If the steam is made (and then stored?) using a process that requires an exchange of heat between separate bodies of fluid it would be external. If the steam is made (and then stored?) using a process that does not require an exchange of heat between separate bodies of fluid, it would be an internal combustion process.
The extreme nature of this arrangement IMHO, is that fact that steam is produced (and stored in a big reservoir?) and then transferred with some clever (mechanical ?) arrangement to the separate locomotives. The physical distance between where the fluid is heated and where it is used to produce work should not have a bearing upon whether the entire process is classified as internal or external combustion.
Most of the pieces of turbo-machinery used to power modern commercial aircraft are of the internal combustion configuration. An internal combustion engine is one where the same body of fluid that produces work is the one that is heated by the combustion of fuel. An external combustion engine is one where a transfer of heat occurs between separate bodies of fluid.
I believe that you may be thinking along the intuitive definition of the words internal and external. If we use this definition, a "classical" steam locomotive would be classed as an internal combustion engine, which it is not. The only external combustion engine under this definition would be some sort of open fire.
The distinction between the two types of engines does not rely on whether power is produced in a "closed" piston-cylinder arrangement or an "open" turbine arrangement, what is important is whether or not heat is transferred between separate bodies of fluid.
I would say that after-burning is also an internal combustion process, as heat is being added directly to the same body of fluid that is used to produce the work output of the engine. This work is in the form of added exhaust gas momentum, not mechanical work.
I don't think that the physical enclosure or environmental isolation or "openness" of a particular combustion process has any bearing on whether it is internal or external.
A Stirling engine has a closed, physical piston arrangement yet it is an external combustion engine as an exchange of heat occurs between the body of fluid in which the heat is first produced, and the body of fluid that produces power.
A open, roaring fire used to hear a column of air above the fire, with the rising convection currents then used to spin a fan type arrangement (to get work output) would be an internal combustion process (an extremely inefficient one) despite being almost completely open to the environment.
Quoting Mrocktor (Reply 25):
Whether the mechanically driven valves of a piston engine are open or closed does not change the type of engine it is. The essential factor is whether an exchange of heat has occurred between separate bodies of fluid.
Quoting Starlionblue (Reply 28):
Doesn't the entire cycle and mechanical arrangement constitute an engine? The physical distance between where the fuel is combusted and where work is produced should not influence whether a combustion process is internal or external.
Regards, JetMech
Mon Jan 29, 2007 1:00 am
Quoting JetMech (Reply 29):
The definition is like this "An external combustion engine is a heat engine which burns fuel to heat a separate fluid (usually water) which then, in turn, performs work.". In other words, the working fluid is separate from the fuel, unlike in internal combustion.
Users browsing this forum: dw747400 and 2 guests
