trav110
What's Coming From The Wing Of This IL96?
Wed Jan 24, 2007 7:28 am
Photo © Christoph Schaemer
Looks like some type of fluid, any ideas?
CM767
RE: What's Coming From The Wing Of This IL96?
Wed Jan 24, 2007 7:31 am
Probably just condensation.
[Edited 2007-01-23 23:31:55]
But The Best Thing God Has Created Is A New Day
MDorBust
Wed Jan 24, 2007 7:32 am
It looks to be coming from the fuel dump masts.
Likely the tanks were overtopped and the excess is draining out after rotation.
*EDIT*
On second thought, it looks to be in landing configuration.. So... errr.. I'll concur with condensation.
[Edited 2007-01-23 23:33:27]
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
trav110
Wed Jan 24, 2007 7:33 am
Quoting MDorBust (Reply 2):
Ah, that might explain it. I've never seen the masts so far inboard, though. Peculiar.
Charliejag1
Wed Jan 24, 2007 7:36 am
I think its probably condensation, but what about blown flaps? Do the russians use them at all?
ordryan28
Wed Jan 24, 2007 7:37 am
I initially thought it was coming from the fuel dump masts as well. But considering it's landing, that cannot be right...
Just a unique version of condensation in a unique location  Smile
Whoever said winning is not everything never fought cancer.
airfoilsguy
Quoting Charliejag1 (Reply 4):
What is that?  Confused
It's not a near miss it's a near hit!!
N243NW
Wed Jan 24, 2007 1:44 pm
Quoting Airfoilsguy (Reply 6):
What is that?
Bleed air taken from the engines and "blown" over the underside of the wing and trailing edge flaps, therefore increasing airflow over the flaps and creating more lift. I'm sure someone can elaborate more, as I'm not an expert on exactly how they work.
-N243NW Big grin
jben
Wed Jan 24, 2007 4:49 pm
I think it's the chemtrail dispenser, seems to have suffered a serious leak.
:p
Actually, it's probably just condensation, given the time of year and the location, it sounds about right to me.
jetmech
Wed Jan 24, 2007 5:37 pm
Quoting N243NW (Reply 7):
Most of the blown flap mechanisms that I have read about actually blow air across the top of the wing surface and flaps. The Coanda effect causes the air to "stick" to the upper contours of the wing and flap. When the air is blown across a deflected flap, it will be vectored downwards. This makes additional lift.
Photo © Peter Marianic
Regards, JetMech
MD11Fanatic
Wed Jan 24, 2007 9:47 pm
The C-17 has blown flaps, doesn't it? The original 707 prototype experienced with this too and achieved stall speeds well under 100kts with it!!!
vikkyvik
Wed Jan 24, 2007 11:24 pm
Quoting JetMech (Reply 9):
I might be wrong, but I thought "blown flaps", at least as seen on the C-17, were simply flaps that are extended down behind the engines - into the exhaust stream. They thereby exert a downward force on the jet exhaust, and create more lift.
Corrections welcome  Smile
~Vik
474218
Thu Jan 25, 2007 12:30 am
I agree that it is condensation, but why do you think its landing? The flaps appear to be only about a third to half way extended, which would suggest takeoff.
David L
Thu Jan 25, 2007 2:01 am
Quoting 474218 (Reply 12):
I was hoping someone else would ask that! Two clues I can think of are the flap position and the attitude but I don't see those as necessarily indicating a landing. But, if it's landing, why are the trails in question extending down and back, even some way behind the aircraft?
airfoilsguy
Thu Jan 25, 2007 4:03 am
My guess is take off. Otherwise the photographer took a pic of it landing then waited for everyone to deplane, fuel up, new passenger boarding, and push back in order take a pic of push back.
Photo © Timo Breidenstein
sovietjet
Thu Jan 25, 2007 4:33 am
Could it be snow? It kinda looks like it...
A342
Thu Jan 25, 2007 5:10 am
As one can see when looking at the left FTF (seen from behind the aircraft), that stuff is coming from the upper side of the wing, not out of the FTF. So I don't think it's fuel.
Quoting Vikkyvik (Reply 11):
Both methods are possible.
Exceptions confirm the rule.
dhhornet
Thu Jan 25, 2007 6:17 am
How about De-icing fluid?
MidEx216
Thu Jan 25, 2007 6:41 am
Quoting Airfoilsguy (Reply 14):
Those two pictures, though taken of the same airplane at the same airport on the same day, were not taken by the same person. So, chances are one person took a picture of it it's arrival, and then the other took a picture of it about an hour later pushing back for departure..
airfoilsguy
Thu Jan 25, 2007 8:46 am
Quoting MidEx216 (Reply 18):
Yes, you are correct. Improper use of the search function on my part.  ashamed
474218
Thu Jan 25, 2007 9:15 am
Definately taking off, check the flap position on a landing IL96:
Photo © Diego Ruiz de Vargas - Iberian Spotters
BAE146QT
Thu Jan 25, 2007 9:30 pm
Quoting JetMech:
I've always loved the Coaler. I don't know why, but there is something really aesthetically pleasing about it to me.
Quoting A342:
Agreed.
One is internally blown flaps, where the bleed air is channelled through the wing and then vented out the back. I have a feeling that this was really only common on fighters, with a centrally-mounted engine like the F-104.
The other is externally blown flaps, which Vik was describing. Interestingly, the A380 uses this concept.
By the way - check out the stall speed on this thing;
http://www.airliners.net/open.file/0587535/M/
Todos mis dominós son totalmente pegajosos
Fri Jan 26, 2007 12:29 am
Quoting BAe146QT (Reply 21):
Anyone aware that these type Flaps exist on the IL96.
regds
MEL
MidEx216
Fri Jan 26, 2007 9:03 am
Yeah, that, and I've been taking a liking to the Tu-154. Don't ask why, but those are the only two Russian commercial jets that I really like.
Users browsing this forum: rendezvous and 24 guests
