3DPlanes
Yet More Takeoff Distance Question(s)
Fri Jan 26, 2007 3:33 am
Having read through previous posts, AND having downloaded the Boeing performance docs, I still have some questions about takeoff performance for large aircraft...
In my POH for a Warrior or 172, there are charts for calculating takeoff roll and required distance to clear a 50' obstacle. You enter the charts using temperature, go up to pressure alt, then over (and maybe down) to weight, then over (and up or down) for wind - ending up with the distance.
The Boeing charts are similar, but there are only two charts - one for standard and one for +15c.
Having flown into short grass strips with trees on all sides eek , I know that GA is different... And I understand that large aircraft fly into known airports (usually), hence they already know the runways are long enough, and that if the temp gets hot they can reduce fuel or cargo to get within the available length.
But where do they get numbers or data for abnormal conditions? Like when it's +35c in Pheonix? Or when you land your A320 at a closed field in Ireland? Does that come from the FMS? Does each airline work out it's own numbers, based on their SOPs? (Although the airline flight manuals I have access to don't have these charts in them.) And the Boeing docs from their site are for airport planners, not pilots/dispatchers...
What about bizjets? A G-V or Citation X could be asked to fly into nearly any field the client/owner wanted. Do they have charts to work things out?
"Simplicate and add lightness." - Ed Heinemann
SlamClick
RE: Yet More Takeoff Distance Question(s)
Fri Jan 26, 2007 3:56 am
Quoting 3DPlanes (Thread starter):
In real-world airline flight operations we approach it somewhat differently. We don't care what the takeoff roll is going to be. Our interest is how much weight can we lift under today's conditions and still meet all the legally mandated excess performance criteria.
I don't know what charts you are looking at but I have Boeing 737-300 takeoff charts for a number of different airports right in front of me. They have a seperate weight limit line for temperatures about every two degrees or so from minus 30°C up to plus 52°C even though the engines were flat-rated to fifty.
On-line airport ("Regular" airports in our ops specs) we have these charts (unless we are using performance computers) If we intentionally fly into an off-line airport for a charter or something the company will get us the charts for those runways. If we have an emergency and land at some place really wierd we will not take off until the charts are in our hands.
By the way, since you mentioned PHX and +35°C my chart says 117,400 lbs would be the takeoff limit based on "climb" and not "runway" restrictions. Ths is at Flaps 5, packs Auto. If I needed to lift more out of PHX on this day I might have access to a "Flaps 1 Improved Climb" chart that could give me a bit more weight capacity in that configuration and procedure.
But again, I just don't care about the ground run. Runway length is fixed, the temperature and winds and anti-skid status are what they are - allowable takeoff gross weight is THE variable.
SlamClick
Fri Jan 26, 2007 4:01 am
These are mostly operated under Part 91 where airlines operate under the more restrictive Part 121. Part 91 operators get almost no FAA supervision at all, as compared with airlines, and the safety record of any given corporate flight department is pretty much up to their pilots. It takes some courage to say: "I'm sorry sir, this plane can't do that." to your boss. Especially when some other pilot has already done it for them.
It is why I would rather drive a truck than fly corporate.
3DPlanes
Fri Jan 26, 2007 9:52 am
Quoting SlamClick (Reply 1):
That seems to be the rub - I haven't seen charts for a specific airport.
What you explain makes sense. It would be like taking a grass field near me with 2500' available and (knowing the field elevation) working out the max weight for a number of temps, where I could still takeoff from that field. I don't care how much runway I use, just as long as I can takeoff and clear the trees at or below a certain weight - based on the temp.
But, what about baro pressure? Wouldn't a low pressure system change the mix? Or is there enough margin built in? Basically, I'm wondering about density alt.
The GA charts work out density alt by figuring it during the mix. I don't have to calculate the actual value - just start at the temp and go up to the pressure alt for the field that day, and thereby work from a density altitude "value" (disregarding humidity), even though I don't know the actual number.
SlamClick
Fri Jan 26, 2007 10:04 am
Quoting 3DPlanes (Reply 3):
They are probably not available for free. What might be is a "runaround graph" or "web of death" type graph chart for the generic calculations, without considering runway-specific factors such as obtacles but they would probably have runway slope, wind and temperature skews.
AirWillie6475
Fri Jan 26, 2007 4:43 pm
15c is standard temperature.
Airlines is not much of a problem. Everything is worked out for the pilots they just basically confirm the info sent by the company, all they have to do is fly. It's more challenging for charter/biz operators. Those pilots actually have to familiarize themselves with all aspects of the trip because they are basically the only ones responsible for the safety of the flight. Often times they fly into uncontrolled airports, remote fields they have to be a little more prepared. Not hard work just more work.
Fri Jan 26, 2007 5:05 pm
At our airlines we stopped working things out in the cockpit, too many accidents (like SQ in NZ out by 100t on takeoff mass, 747 in Halifax with the mass from the previous sector) are occurring as people make silly mistakes under time pressure.
We just load the mass, QNH, runway, runway condition, MEL/CDL items and temp in ACARS, and the performance computers/engineers back in the main office send us back a message back via ACARS with our speeds, flap, and derate/reduced thrust.
BAE146QT
Fri Jan 26, 2007 5:55 pm
Quoting SlamClick:
Unless that place is a levee in New Orleans, presumably.
I guess by definition, the guy who flew that plane out of there was a test pilot...
Todos mis dominós son totalmente pegajosos
CosmicCruiser
Fri Jan 26, 2007 9:29 pm
Quoting Zeke (Reply 6):
ah, yes never let pressure to go make you hurry and make mistakes.
we just input that info into the PAT onboard and it generates the data.
a389
Fri Jan 26, 2007 11:20 pm
The numbers you're talking about are FAR take off (other charts for landing) runway length requirements used for runway planning purposes. As you said they are for ISA conditions (15C, sea level) and generally for ISA+15C.
If you want to use then in different conditions you have to correct them (up to a certain extent) for different temperatures, altitudes, runway slopes, etc.
Also when determining the runway length for an aerodrome you need to consider types of aircraft/range/frequency, access possible stop or clearways, costs, etc and you end up with a runway length or better with declared distances.
Those are then used on a case by case basis to determine specific conditions for each operation (weather, loads ...)
A389
SlamClick
Sat Jan 27, 2007 12:15 am
Quoting BAe146QT (Reply 7):
I don't know what you are referring to. My post, however, was only about airline operations and actual revenue flights.
miamiair
Sat Jan 27, 2007 1:41 am
Quoting SlamClick (Reply 10):
I think he is referring to a TACA 737-300 that had a double flame out and had to land on a levee.
BAE146QT
Sat Jan 27, 2007 2:56 am
Quoting Miamiair (Reply 11):
Yessir. I'm afraid I was overcome by the desire for dry humour.
It was kind of relevant though, since it addresses the question of "What do you do when the figures just aren't available?".
The answer, one supposes, is that you calculate, then calculate again. And once you've done that, you get someone else to fly the damned thing.
Actually it occurs to me that this sort of thing must be quite common in some parts of the world - especially where the gravel deflector is used as a matter of course. And I'll bet the T-43 pilots have some stories to tell...
KELPkid
Sat Jan 27, 2007 3:13 am
Part 91, usually. I would imagine that they must compute an accelerate-stop distance, at least...even piston twin drivers must do that one. Helps determine the point at which you are committed to a takeoff, and at what speed you would be able to safely stop on the remaining runway...
SlamClick
Sat Jan 27, 2007 3:15 am
Sorry, never even heard about that event. (Guess I need to lurk in Civ/Av more  Smile)
I have no idea what they did to retrieve their airplane. Don't know to what extent the US FAA would involve themselves in a "foreign" embarassment. I expect that cranes and barges might have been involved in the recovery.
BAE146QT
Sat Jan 27, 2007 3:36 am
Quoting SlamClick (Reply 14):
Sorry, never even heard about that event. (Guess I need to lurk in Civ/Av more )
TACA flight 110, in 1998. It flamed out because of a heavy downpour and the FAA got blamed for certifying an engine that you can't aim a firehose at, apparently.
I would have sworn that I heard about it from you! Damn your prolific hide, sir.
Doesn't look like it. They changed an engine, fuelled it to the minimum, turned it around and flew it out of there like it was a repositioning flight.
Here's a link;
Taca 110 737 "Crash Landing" In New Orleans (by TriJetFan1 Nov 15 2004 in Civil Aviation)
Oh look - It was Gen_Av. Heh. And another;
http://aviation-safety.net/database/record.php?id=19880524-0
SlamClick
Sat Jan 27, 2007 3:42 am
Quoting BAe146QT (Reply 15):
I did a quick google and saw one picture - looked like it was pretty well stuck in the mud.
Sounds like the FAA is also guilty of approving an engine you can't suck mud with!
3DPlanes
Sat Jan 27, 2007 4:13 am
Quoting AirWillie6475 (Reply 5):
I should have been more clear... The charts are for standard, and for standard+15c. Same thing for my PHX example - I meant standard+35c, so 50c, not 35c.
Regardless, as SlamClick said, the charts used by the airlines just use the temp to work out the max weight - since the runway length is known.
But what about baro pressure? Since density alt comes from both temp and pressure (and humidity), where does the pressure come into the figuring?
It sounds like the charts I'm talking about (the "web of death" as Slam calls them) DO exist, just not at the individual pilot level - like in GA.
SlamClick
Sat Jan 27, 2007 4:27 am
Quoting 3DPlanes (Reply 17):
The airport analysis page is specific to the airport, which implies to the field elevation. They assume standard baro pressure and are okay to use unless the altimeter setting deviates (ie is less than) from standard by xx mb or more. This is usually to be found in the company (non-type-specific) operations manual. It takes a LOT of deviation to affect operations.
The pages I have at hand do not even have a baro correction table, where they do for antiskid inop or headwind/tailwind. These adjustments might be a weight change but more likely just a V1 adjustment.
The "climb limit" page is applicable to all runways.
Runway limits are each in their own column and slope & obstacle data is already figured.
Landing limits would be on a separate page.
A342
Sat Jan 27, 2007 5:38 am
Let me throw in a question here: If there is no obstacle at the end of the rwy, how long does it at least have to be ? The takeoff roll distance for a given aircraft, or the distance the aircraft needs in order to clear the (non-existant) 50ft obstacle ?
Exceptions confirm the rule.
KELPkid
Sat Jan 27, 2007 5:47 am
Quoting A342 (Reply 19):
Cessna gives you the numbers both ways, so you could use the "without" numbers.
A342
Sat Jan 27, 2007 6:21 am
Quoting KELPkid (Reply 20):
Ok, but is that permitted ?
Sat Jan 27, 2007 6:22 am
Quoting CosmicCruiser (Reply 8):
Is PAT like the BLT ? As that was the problem with both the accidents I listed.
KELPkid
Sat Jan 27, 2007 6:45 am
Quoting A342 (Reply 21):
For not-for-hire operations (part 91), single engine, the only thing that matters is that you get off of the ground safely. It's your call, as you're the one who will be calling the NTSB and/or FSDO to report the accident should it not work according to plan...there's no rule as to which takeoff/performance numbers you must use, although by law the manufacturer must provide them for your use  Smile A departure into the trees/power lines/rising terrain, in the absense of mechanical failure, will result in the NTSB determining the probable cause as "Inadequate preflight by the pilot in command."  Wink
A342
Sun Jan 28, 2007 6:07 am
Quoting KELPkid (Reply 23):
Just one more question: How about privately operated twins ? I guess, like on airliners, you could calculate the runway length needed for a safe single-engine takeoff after V1 (or what's the speed called at that you reach the "point of no return") ?
I'm sorry if I can't express it professionally !
SlamClick
Sun Jan 28, 2007 6:37 am
Quoting A342 (Reply 24):
For the USA, we have FAR 91.13 that basically says that on one may operate an airplane (whether or not they intend to fly) in a manner as to endanger another person's life or property.
It might be argued that if you own the airplane outright, you might be able to legally crash it on your own property so long as no public assets like fire fighters would be endangered as a result.
Beyond that there is little supervision in place for private owners of twin-engine airplanes. Sadly, they kill themselves in great numbers when they suffer engine failures that should be survivable.
A few years ago I was teaching the ATP written test prep course. Normally an instructor will "teach to the middle of the class" which means too basic for the brightest students and a stretch for the weaker ones. In this class I had a USAF U-2 instructor pilot and a fifty-something business man who owned a pressurized twin. There was no "middle" of the class.
When I started into the Performance part of the course it was obvious that the twin-driver had no clue in hell what all those charts were in the back of his airplane manual. None! Fortunately the U-2 pilot DID know what that stuff was about and was able to help me with this guy. I'll bet he has never summoned the courage to take the written exam. The U-2 pilot is probably an airline pilot today.
So what do light twin drivers do?
Who knows? It us up to them.
CosmicCruiser
Sun Jan 28, 2007 7:40 am
Quoting Zeke (Reply 22):
Sorry but I am not familiar with a BLT (short of the sandwich, LOL) but the PAT is the perf comp. on board. The only way it's wrong is if you input bad data and we have enough cross checks that any errors SHOULD be caught. Of course I again emphasize the importance of not letting an on time push make you hurry. I've seen a number of times when my cockpit setup is disrupted by ramp or maint folks bringing new info or questions to the cockpit and it's easy to lose your place or forget where you were so I usually pick a point that I knew was complete and start over. The co. will never criticize one who puts safety first.
A342
Mon Jan 29, 2007 5:12 am
Quoting SlamClick (Reply 25):
Ok, thanks for the answer.
OPNLguy
Mon Jan 29, 2007 5:53 am
This incident occurred about 3 years after first deliveries of the 737-300s to various airlines, and investigation of this (and other) flameout incidents revealed that the design of the nose spinner of the CFM56 engine was allowing too much water to be ingested into the engine's core. The spinner (at the time) was more pointed " > " and they changed it to a blunter, more rounded " ) " that would allow more precip to be deflected into the bypass section, and not into the core. They also made internal changes to the engines.
As far as the TACA aircraft, it suffered FOD damage on the landing from ingesting whatever, and one engine had to be changed right there on-site on the levee. Once it was changed, the aircraft was ferried off the levee (don't know who actually flew it; Boeing perhaps?) back to MSY (the original destination) where they changed the other engine. TACA later disposed of the aircraft, and it later flew for Aviateca, America West, Markair, and Morris Air, and is today in Southwest's fleet as N697SW.
SlamClick
Mon Jan 29, 2007 7:22 am
Okay, I do remember this issue:
Quoting OPNLguy (Reply 28):
The spinner
Known at my airline as "Madonna" cones (pointy)
and "Dolly" cones (big, bulging rounded)
KELPkid
Mon Jan 29, 2007 5:02 pm
You can compute an accellerate-stop distance, which provides the speed of "the point of no return" (i.e. you're commited to the takeoff after that speed), which for a safe takeofff better be greater than Vyse and Vmc  Smile . It takes into consideration density altitude, runway length, and aircraft loading. I don't know if it's mandatory, however from my commercial ground school (which included multi), the implication seemed to be that computing the accelerate stop distance was a standard procedure. I don't think I've seen anything in Part 91 that mandates it for twin operations, however I'd think a prudent operator would compute it.
Mon Jan 29, 2007 6:20 pm
Quoting CosmicCruiser (Reply 26):
BLT from what I understand is the Boeing Laptop Tool.
CosmicCruiser
Mon Jan 29, 2007 9:16 pm
Quoting Zeke (Reply 31):
Yea, that's what I guessed but curious how they gooned it up so bad. Were there no cross checks? Didn't some one say this doesn't look right? I can tell you of a couple of FMS mistakes that have caused some guys problems but how did they screw up the BLT? I just had an F/O put the wrong altimeter setting into the PAT but it was caught on the chk and it wouldn't have been a big deal anyway.
Mon Jan 29, 2007 10:27 pm
Quoting CosmicCruiser (Reply 32):
Not 100% sure, have not seen the report, what I understand of the NZ SQ incident was they were out by 100t on ZFW, TOW was then also out be 100t.
The Halifax one, from what I hear they had the loads from the previous sector, which was also significantly out.
Users browsing this forum: Dalmd88, gloom and 2 guests
