mlglaw
Weights Of Honda And/or Eclipse Jet Engine
Wed Jan 31, 2007 3:39 am
What is the weight of the engine for the new Honda light corporate jet and the new Eclipse?  Confused
Sumus Primi BLS'60 - Oderint dum metuant!
cdekoe
RE: Weights Of Honda And/or Eclipse Jet Engine
Wed Jan 31, 2007 6:42 am
The Honda HF120 engine comes in at less than 400 lbs.
http://world.honda.com/AircraftEngines/
The uninstalled weight of the PW610F on the Eclipse (excluding pumps, starter-generator and fire detection equipment) will be just under 270 pounds.
http://www.eclipseaviation.com/index...&task=viewarticle&id=436&Itemid=51
We can't solve problems by using the same kind of thinking we used when we created them.
KELPkid
Wed Jan 31, 2007 11:28 am
Quoting Cdekoe (Reply 1):
http://www.eclipseaviation.com/index...id=51
Didn't that throw the program off for a couple of years when they decided to switch engines from the Williams FX-22, because the PWC engine was actually heavier than the Williams engine (hard as that is to believe...)?
dw747400
Wed Jan 31, 2007 12:17 pm
Quoting KELPkid (Reply 2):
All sort of things had to be changed. The additional weight and thrust required a beefier structure, and those PW610s are very thirsty compared to the proposed Williams.
CFI--Certfied Freakin Idiot
mlglaw
Wed Jan 31, 2007 11:47 pm
Thanks to cdekoe's response and link; I see that the Eclipse engine PW610F is listed at 270 lbs and rated with 900 lbs of thrust, better than a 3 to 1 ratio. What is the ratio of the B777 engines (weight to thrust) and the proposed B787?  Smile
dw747400
Thu Feb 01, 2007 1:14 am
Quoting Mlglaw (Reply 4):
According to GE http://www.geae.com/engines/commercial/ge90/ge90-115b.html the GE90-115B has a better than 6 to 1 ratio. It appears they don't have data for the GenX on that site yet.
[Edited 2007-01-31 17:14:49]
[Edited 2007-01-31 17:15:26]
[Edited 2007-01-31 17:16:12]
Users browsing this forum: pikachu and 2 guests
