allstarflyer
US Ramtaf Vs. NWS Forecast
Sat Feb 03, 2007 11:53 am
Can anyone with USAirways explain to me why the US RAMTAF is considered a superior forecast to that of the NWS? This applies directly to me and the work I do with USAirways, and sometimes it's a circus act juggling both of them - if the US RAMTAF shows no need for an alternate, but the NWS forecast does, you bet your cookies I'm slappin' an alternate on that flight. But I have to dispatch under the RAMTAF - and sometimes (in certain stations - and none in particular, they all do it), the RAMTAF is HOURS older than the NWS forecast.
With the NWS usually being a fine forecasting product, can somebody explain to me the necessity of the RAMTAF at US Airways?
-R
Living the American Dream
fxra
RE: US Ramtaf Vs. NWS Forecast
Sun Feb 04, 2007 6:16 am
I can't explain the reasoning at US AIrways per se, but my carrier only orders a RAMTAF when the destination airport is illegal according to the NWS forecast. Sometimes the RAMTAF will come out better for us, sometimes it won't. The best i can say is watch the last few observations and see if the trends better match the RAMTAF or the NWS.
I have found that RAMTAF's we get are about 50/50 better than the NWS forecasts (or the local government agency). Then again we had 3 diversions a couple weeks ago at the same central Asian airport by basing the dispatch on the RAMTAF. However, said airports forecasting agent has about an 20% accuracy i think.
I believe that the RAMTAF is still valid over a more recent NWS forecast due to it being issued from a different authority. But, I would imagine that's a question for you ASI/D and for flight ops management.
Of course, there's always the option of ordering a new RAMTAF. DOes US have their own met department?
Visualize Whirled Peas
lowrider
Sun Feb 04, 2007 6:21 am
Quoting Allstarflyer (Thread starter):
If one of the airports on your flight plan is not covered by a TAF, you can order a RAMTAF so you have weather data. The NWS does not issue TAFs for all airports.
Proud OOTSK member
allstarflyer
Sun Feb 04, 2007 8:53 am
Quoting Lowrider (Reply 2):
 thumbsup  Good call, but I haven't had need for the RAMTAF, exclusively (I don't believe), for that situtation.
Quoting FXRA (Reply 1):
Not sure, but I think they do.
-R
JayDub
Wed Feb 07, 2007 8:12 am
Ahhh, the 'SCAM'-TAF. If only the flying public had any idea that we can pay the right price and get the weather we need to be legal for launch.
Seriously, sometimes a RAMTAF is what it takes to keep the operation running when the NWS TAF for a destination is overly restrictive (i.e. - 1/4sm in the main body for 6 hours when the fog is obviously lifting rapidly).
I don't think the RAMTAF is considered "superior". It is just a matter of which forcast will allow you to dispatch the flight and which one will not. If your company's OpSpecs allow you to get a second observation...and that second observation is less restrictive...go with the less restrictive one (unless, of course, you don't feel comfortable with dispatching the flight based on the RAMTAF).
I would agree with this wholeheartedly. Our job is safety of flight...in this instance, I would definitely go conservative.
Why are you required to dispatch based on the RAMTAF when there is a perfectly good and legal NWS TAF available? Shouldn't you be dispatching based on the most current available weather reports and forecasts?
[Edited 2007-02-07 00:44:42]
"Travel is only glamorous in retrospect." - Paul Theroux
Users browsing this forum: StereoTechque, tupperjets and 1 guest
