A342
Help Needed With Part 139 Aircraft Design Groups
Sun Feb 04, 2007 6:04 am
On a website about TEX, I found the following quote:
"Airline operations: RSTD TO FAR 139 DESIGN GROUPS AI; AII; AIII; BI AND BII."
But nowhere I could find explanations for these design groups. Maybe you can help me.
Thanks in advance.
A342
Exceptions confirm the rule.
N231YE
RE: Help Needed With Part 139 Aircraft Design Groups
Sun Feb 04, 2007 9:33 am
I believe that that is airport reference code (ARC).
If so, then the first character (the letter) is the aircraft approach category, and the second character (the number) is the aircraft design category based on wing span.
corey07850
Sun Feb 04, 2007 11:29 am
It's based on wingspan and approach speed:
Wingspan:
I = <49'
II= 49-78'
III= 79-117'
IV= 118-170'
V= 171-213'
VI= 214-262'
App. Speeds:
A= <91kts
B= 91-120kts
C= 121-140kts
D= 141-165kts
E= >166kts
A342
Sun Feb 04, 2007 7:53 pm
Quoting Corey07850 (Reply 2):
Thank you, that was helpful !
kc135topboom
Mon Feb 05, 2007 6:08 am
Wingspan:
I = <49'
II= 49-78'
III= 79-117'
IV= 118-170'
V= 171-213'
VI= 214-262'
App. Speeds:
A= <91kts
B= 91-120kts
C= 121-140kts
D= 141-165kts
E= >166kts
No, aircraft design groups (ADG) is based on wingspan only. The aircraft approach catagory is based on final approach speeds. You can find the ADG in AC150/5300, Airport Design. ADG VI is a new catgory created just for the An-124, A-380, and B-747-8.
corey07850
Mon Feb 05, 2007 9:13 am
Quoting KC135TopBoom (Reply 4):
What the original poster provided (AI, AII, BII, etc) are referred to as Airport Reference Codes... The first letter refers to the category of approach speed (of which I provided before) and the Roman numeral refers to the aircraft's classification based on their wingspan (of which I provided above)...
For example an aircraft with an ARC of "AI" would mean a plane with a wingspan less than 49' and an approach speed of less than 91 knots.
The terminology provided by the original poster isn't worded correctly... Look up AC150/5300-13 Appendix 13 for a list of aircraft based on their ARC. It's not so much a Part 139 thing as it is an Advisory Circular
Users browsing this forum: MSNbot Media and 2 guests
