stevesdream69
Galley Installation
Thu Feb 08, 2007 5:01 pm
Does anybody know, in the steps of building an aircraft, at what step the galley installation is foreseen? Is it one of the last things? Or is it in the early steps of the building? Differences between regional aircrafts and long range?
TheJoe
RE: Galley Installation
Fri Feb 09, 2007 11:11 pm
Well, I've never built an aircraft, but in maintenance, the galley units are amongst the first things to be taken out and nearly the last major item to be put back in!
I can't speak for all aircraft types, but from my experience the galley units are split inside the aircraft before removal and re-assemble inside the aircraft when they are put back in. I guess this is fairly obvious though as some of the units are quite large! This can be quite a pain because they are often large and awkward items to move around. There's no way you can get lifting equipment in to the cabin, so you get as many blokes as you can to help move it around and position it!
For example, on a 737-800 the aft galley and toilets can be installed first along with the fwd toilet and fwd L/H galley unit. The seats can then be loaded and installed followed finally by the fwd R/H equipment stowage cabinets.
Sat Feb 10, 2007 6:55 pm
Since a Galley is Simply Fixed in todays Commercial Aircraft.Its normally Fitted last in the Cabin.Help that way as Seats,Carpets,Floorboards can be moved thru easier.
regds
MEL
troubleshooter
Mon Feb 12, 2007 8:47 pm
Galley Installation (by Stevesdream69 Feb 8 2007 in Tech Ops)
This job sucks!!! I love this job!!!
BAE146QT
Mon Feb 12, 2007 9:20 pm
"Groundhog Day!" [SFX] Smashed alarm clock [/SFX]
Todos mis dominós son totalmente pegajosos
Users browsing this forum: Cubsrule, United1689 and 1 guest
