747400sp
Does John Travolta 707 Have Hush Kits?
Sat Feb 17, 2007 8:30 am
Last time I saw Jet Ella Clipper flying, it did not seem to be as loud as 707s supposed to be. It did not get as high pitch as 707 I have seen landing before. Get John put some hush kits on his toy? If so when?
EMBQA
Sat Feb 17, 2007 9:09 am
No... it is does not have Hush Kits
N231YE
Sat Feb 17, 2007 9:47 am
Quoting EMBQA (Reply 1):
Are you sure? It looks like the fan nozzle of the JT3Ds have had the "collar extension:"
Photo © Chris Anders
...compared to a "regular" JT3D:
Photo © Ellis M. Chernoff
411A
Sat Feb 17, 2007 10:32 am
Stage three hushkits are fitted.
airfoilsguy
Sat Feb 17, 2007 10:35 am
Quoting N231YE (Reply 2):
They look the same to me. Plus I thought the hush kit goes in back where most of the noise comes from.
Photo © David Oates
Photo © Frank C. Duarte Jr.
It's not a near miss it's a near hit!!
N231YE
Sat Feb 17, 2007 11:04 am
Quoting Airfoilsguy (Reply 4):
You are comparing the JT3C, which is a turbojet...not the same engine as on Travolta's 707, which is a turbofan JT3D.
I am not sure of any other hushkits for the JT3D, other than the fan duct extension...correct me as needed.
[Edited 2007-02-17 03:05:16]
LTU932
Sat Feb 17, 2007 11:49 am
There are some subtle differences between them. You just have to look harder.
Quoting N231YE (Reply 5):
Don't forget that back in the day, JT3Cs were easily convertible to JT3Ds, which could have provided some noise reduction before the retrofit with the stage 3 hushkits. More importantly, the first picture in reply 4 is of a Rolls Royce Conway powered 707 (a former LH 707-430 to be precise), and the Conway cannot be conpared at all with the JT3, given that it was conceived as a turbofan from the beginning, while the JT3 was originally a turbojet (as the JT3C) and later evolved to a turbofan (as the JT3D). Correct me if I'm wrong though.
sovietjet
Sat Feb 17, 2007 12:32 pm
If I was Travolta, I'd get me some JT-3Cs  Smile
113312
Sat Feb 17, 2007 3:45 pm
Why would you want JT-3C? It was much lower thrust and higher fuel consumption. You just think that the organ pipes on the exhaust are sound suppression. Well, they were in 1959-62. However, even with those, it was VERY LOUD compared to the later fan versions which didn't need the pipes. The JT-3D turbofan had higher thrust with less noise without the pipes. The later stage III kits have an extended inlet which allowed for additional inlet sound suppression taming the fan buzz and whine.
N231YE
Sun Feb 18, 2007 12:14 am
Quoting LTU932 (Reply 6):
My correction, you're right, the first photo is a 707-400, RR Conway Powered.
Just a side note, the RR Conway was often referred to as a "bypass turbojet," not a turbofan, due to its extremely low bypass ratio.
747400sp
Sun Feb 18, 2007 12:17 am
Quoting 113312 (Reply 8):
So what! I like LOUD jets.  Big grin
LTU932
Sun Feb 18, 2007 12:48 am
Quoting Sovietjet (Reply 7):
Not just that, make sure those JT3Cs are also waterburners.  Wink
Photo © Charlie Atterbury
I wish I would have been there, when pure jets were still flying.  bigthumbsup
Quoting N231YE (Reply 9):
Curious that you mention this term, because I read on the RR website that the Conway was the first turbofan engine to enter service when it was introduced for the 707.
http://www.rolls-royce.com/history/timeline/1940-1959.jsp
I guess the term "bypass turbojet" is simply an unofficial type designation for the Conway.
N231YE
Sun Feb 18, 2007 3:42 am
Quoting LTU932 (Reply 11):
I just remember reading this in a few books...but as stated, the bypass ratio of the Conway was very low, thus why it probably had the "organ pipe" nozzle (similar to the JT3C) attached to it.
Nonetheless, the Conway still was a very advanced and interesting engine for its time.
TimT
Sun Feb 18, 2007 7:08 am
There is a misconception (IMHO) htat most of the noise from a jet comes from the back. From my experience standing on the ramp as they taxi into the gate, a larger percentage of the noise comes from the front. I can (and have) stood directly in front, far enough back to be safe, and then walked to the side. As soon as you get away from where you can see the fan, it's a lot more quiet..
rendezvous
Sun Feb 18, 2007 10:32 am
Yeah I second what TimT is saying. My reference is to the 737-200 engines. They used to start up right in front of the terminal in Auckland, then taxiout from the parked position. It was really noisy (high pitch scream) until the turned around, it was a lot quieter from the side.
On takeoff it was a loud rour...by no means quiet, but awesome to watch.
Sun Feb 18, 2007 10:46 am
Quoting Rendezvous (Reply 14):
Thats the JT8Ds
Whats the Noise Restrictions out there for non Hushkitted Aircraft.
regds
MEL
boeingfixer
Sun Feb 18, 2007 11:37 am
Canada follows ICAO Annex 16 Volume I Chapter 3. This allows aircraft under 34,000kg MTOW to fly without Stage III compliance. All aircraft in Canada over 34,000 Kg's MTOW must meet the ICAO Stage III standard. There are instances where non-Stage III compliance is waived for aircraft over 34,000kg's. These are mainly for military aircraft such as the C/KC-135, C-137, B-52, B-1, etc... which can't meet the requirement due to operational limitations or humanitarian flights with aircraft such as the Il-76.
As far as hush kits are concerned I believe that the EU has banned Hush-Kitted aircraft. All aircraft in the EU must meet the ICAO Annex 16 Volume I Chapter 3 without the use of Hush-Kits. This has dealt a blow to the DC-8, DC-9, B707, B727, B732, etc.... which cannot comply without Hush-Kits and must pay a penalty to fly in the EU AFAIK.
John
Cheers, John YYC
sovietjet
Mon Feb 19, 2007 8:28 am
Oh come on. Airlines care about noise/thrust/fuel efficiency. From an enthusiast standpoint a JT-3C is much more exciting than a JT-3D. Not only would it be the only such 707 flying, but you get the joy of hearing a pure turbojet at work. I wonder if Travolta even had the option of getting such a 707 with JT-3Cs. If he did and decided to go turbofan then I am disappointed in him lol...not that my opinion of what he does matters  Smile.
747400sp
Mon Feb 19, 2007 9:14 am
Quoting Sovietjet (Reply 17):
I would love to hear a turbo jet 707 also, but with these new noise restriction, Jet Ella Clipper would be ban in many places in the world today if it had turbo jets. You can thank those people who live near an airport, but can not stand the noise for that. Those type people really get on my nerves!
boeingfixer
Mon Feb 19, 2007 9:15 am
It would be a nice dream but the USA also follows the ICAO Stage III regulation so that's why there are no civilian 707's with JT3C's in the USA.
John
Cheers, John YYC
Jetfixr757
Mon Feb 19, 2007 10:58 am
John's is hushkitted, but i do not think they are stage 4 compliant, and i think Europe is leaning that way already.
Jet
boeingfixer
Mon Feb 19, 2007 11:10 am
Quoting Jetfixr757 (Reply 20):
Jet
Stage IV compliance is going to spell the death of many classic airliners. In the EU, Stage IV means that your aircraft must meet this spec without modification. Meaning no hush kits.
I understand their point in that it keeps fleets newer and, due to this, increases reliability and reduces aging aircraft problems. I wish that North America would adopt the same philosophy... speaking from the aspect of a maintainer.
John
Cheers, John YYC
747400sp
Mon Feb 19, 2007 11:51 am
Quoting BoeingFixer (Reply 21):
John
I under stand you are a aircaft maintainer and I see your point.
Now as an aircraft spotter, I have to say to you ( and I mean this in a respectful way) Stage IV is a buch of juke. These noise law are going overboared, soon buses will be louder than an airliner.
Mon Feb 19, 2007 11:57 am
Quoting 747400sp (Reply 22):
Currently Out here there are No Noise Restrictions Although at Some Airports Abroad there are restrictions on Ground Runs & APU operation during nights.This can restrict Maintenance in their Rectification Action.
regds
MEL
boeingfixer
Mon Feb 19, 2007 2:10 pm
I can see your point as well. I like the noise of a classic jet or a century series fighter as much as the rest of you but when it comes to maintaining aircraft that are almost as old as I am, one must consider the future and if it takes aggressive noise reduction to do this, all the better. Aging aircraft inspections are a real pain in the back side and if there is a way to get newer aircraft into a fleet, I'm all for it. Just recently we retired a 727-100 that was accepted into service by United Airlines on the day before I was born and that was in 1966. It was a great aircraft but with more than 75,000 hrs and 45,000 cycles, it was a maintenance headache.
John
[Edited 2007-02-19 06:13:34]
Cheers, John YYC
sovietjet
Mon Feb 19, 2007 4:16 pm
Quoting BoeingFixer (Reply 19):
John
True I suppose, however I was under the impression that there aren't any operational JT-3C or JT-4A 707s left in the world. I also thought private planes don't have to meet stage 3. And if you dont meet noise regulations don't you just pay a fine? If I had that kind of money I wouldn't mind paying some fine to run my waterburner out of ORD and piss off all the complainers lol.
Mon Feb 19, 2007 4:50 pm
Quoting Sovietjet (Reply 25):
You wouldn't have that kind of money for long if you kept paying those fines. Smile
regds
MEL
Analog
Mon Feb 19, 2007 5:53 pm
It also shows disrespect for the environment, as forcing disposal/replacement of aircraft means that a new aircraft must be produced, something that consumes a HUGE amount of energy. This is especially true in comparison to flying an older aircraft around infrequently (think cargo of the non-self loading type or the actor's really cool toy).
This part of the Stage IV regs is taking the term "throwaway society" to a new level. You have to throw away aircraft; you are not allowed to fix them, even if you can make them work as well (quietly) as new ones.
boeingfixer
Tue Feb 20, 2007 1:16 am
Quoting Analog (Reply 27):
So, is it disrespectful to the environment for us to produce drastically more efficient aircraft to replace those that are blowing emissions(and fuel) out their exhausts like there's no tomorrow? Although it takes energy to produce new aircraft, it creates jobs which helps the economy and spurs on technology development. I would hazard a guess that over the lifetime of a new aircraft, the energy that was used to produce it is marginal compared to keeping an older type in service.
People tend to think that transport category aircraft aren't throw-away items and can last forever. Sure, they have a useful life span but the hours, cycles, maintenance/operating costs, etc... are their un-doing. As far as I'm concerned, the EU has it right with Stage IV noise reduction and fleet obsolescence.
John
[Edited 2007-02-19 17:21:15]
Cheers, John YYC
boeingfixer
Tue Feb 20, 2007 1:27 am
Yes they do.... at least for ICAO Anex 16 supporting nations. Airports that have high noise abatement requirements don't care who's operating an aircraft that just pegged their noise monitors. Stage III applies to all aircraft with certain exceptions within the ICAO framework.
John
Cheers, John YYC
zanl188
Tue Feb 20, 2007 1:28 am
Quoting BoeingFixer (Reply 28):
I'm sure you're correct. But it sure won't cause EU politicians to lose any sleep if the replacement aircraft is an Airbus will it?  Smile
Analog
Tue Feb 20, 2007 4:07 am
Yes, if an older aircraft is flown infrequently, like Mr. Travolta's. Given the amount of energy need to make Al (equiv. to 1000's of gallons of JetA per ton) and the amount of CO2 released during production (more than 1kg of CO2 per 1kg of Al produced), producing new aircraft has a non-trivial effect on the environment. Besides, airlines that fly frequently do replace inefficient aircraft; it's typically only cargo operators and others with low utilization levels that fly older, inefficient aircraft.
If the goal is to replace inefficient aircraft, why don't they regulate that? Instead they say this is the standard for noise and you can't fix your old aircraft to comply. BS. If the rule were about noise, then make the rule about noise. Say this is the spec. and make aircraft operators meet it. If the goal is for force the purchase of new aircraft to promote safety, job creation, whatever, then why not set max age or # of cycles/flight hours?
It may be a good thing overall that airlines are required to purchase new aircraft; I don't deny that in sum total it would improve efficiency, but achieving this goal, and "job creation", through "noise regulations" is a regulatory cop-out.
How would you feel if the government instituted new emissions regulations for cars, but refused to let you fix your old car to bring it up to spec, if the only allowable way to meet the new rule was to buy a new car?
sovietjet
Tue Feb 20, 2007 4:29 am
Yes, I'm not in favor of noise regulations either, but you know the only reason they were made was because of the complainers living near airports. Also, I live next to a regional airport and some of the private jets like Gulfstreams or Learjets or whatever are pretty damn loud. There's one that takes off about once a week that is ear-splitting. I don't know what kind it is. That's why I thought private jets didn't need to comply.
Analog
Tue Feb 20, 2007 5:05 am
Quoting Sovietjet (Reply 32):
If you are replying to my post (31), you may have misunderstood me. I am NOT opposed to noise regulations.
What I am opposed to is noise regulations that have restrictions on how they can be met. The Stage IV regs basically say be quieter than X, but you are only allowed to achieve that by building a new aircraft (if I interpret the previous posts correctly). It does not matter if a 707 is made to be 100 times quieter than the requirements, it would not be legal, while a new aircraft that is barely quieter than the requirements is legal under the noise regulations. That is absurd.
boeingfixer
Tue Feb 20, 2007 10:09 am
Quoting Analog (Reply 33):
It's only the EU that imposes the rule of not allowing hush-kits to bring an aircraft up to standards. That includes the current Stage III and future Stage IV.
If JT wants to keep flying his 707, he can do so by upgrading the engines to the JT8D-200 series with hush kits and get a STC for the 707. Not cheap, but it will keep it flying in the rest of the non EU world.
John
Cheers, John YYC
boeingfixer
Tue Feb 20, 2007 10:27 am
Quoting Analog (Reply 31):
Hmmm...... we fly our fleet of 4 727-200's (FedEx Canada) an average of 126.5 hrs per week. That's over 1600 flying hrs per aircraft per year. Hardly low utilization for an older, inefficient aircraft. That's on the high side but your example of low utilization is flawed as there are many operators around the world lik us.
Guess I'd have to buy a hybrid or Smart Car.  Wink Like I've said earlier, it's only the EU that mandates compliance by original certification and not using hush-kits. You should take up your frustration with the EU.
Cheers, John YYC
Analog
Tue Feb 20, 2007 2:30 pm
Quoting BoeingFixer (Reply 35):
Note that I didn't say that ALL cargo operators have low utilization. I imagine that your example is at the high end of the utilization distribution of cargo aircraft.
I would, except I don't own an aircraft or airline (maybe through mutual fund?), and I don't live in the EU. That doesn't mean I can't b*tch about their stupid rules.
sovietjet
Tue Feb 20, 2007 3:15 pm
I was just saying it in general, but I do agree with you on the whole new aircraft/no hushkits deal. It is absurd. I think Stage IV in general is absurd, today's stage III aircraft are quiet enough I think. What more do you want. You can only make a jet engine so quiet before starting to lose efficiency to noise suppression.
SEPilot
Fri Mar 09, 2007 3:54 am
Unfortunately the vast majority of people know nothing and care nothing about aviation. They even buy houses near airports and then complain about the noise. I ran the local airport for two years, and the first year hosted an aerobatics competition. I got no complaints and many favorable comments, and I though, Great! So I hosted it again the next year and then the complaints started (it was for one weekend.) The man who took over from me has hosted it occasionally, but did not dare do it every year because of the complaints were getting so nasty.
Fri Mar 09, 2007 1:57 pm
Quoting SEPilot (Reply 38):
Its a surprise that Folks complain about APU noise too.
Till date out here no such noise restriction.
regds
MEL
Analog
Sat Mar 10, 2007 6:40 am
Quoting Sovietjet (Reply 37):
Is this true? Though it's practically impossible, one could, in theory, use active noise control to make an engine totally silent, right? Maybe even cancel out the sound of the air moving past the engine & aircraft.
My intuition tells me that such a scheme would go from practically impossible (as is never happen) to impossible when you're dealing with "sound" whose wavelength is on the same order of magnitude as the aircraft/engine size.
Maybe I'm totally talking out of my rear end.
kdm
Sun Mar 11, 2007 9:11 am
I loved the way ANZ used to do that (in Wellington as well of course) Did they stop doing it when they started using air bridges.
I also remember they always had someone standing in front of each engine when they started with a fire extinguisher just in case the engine burst into flames, all good but a bit disconcerting for the nervous flyer.
access-air
Tue Mar 13, 2007 5:05 am
Quoting BoeingFixer (Reply 16):
As far as I am concerned, the only reason they dont want to allow hushkits is because that gurantees that airlines will be forced in to buying new planes by not only Airbus but by Boeing and any other modern producer of jet aircraft.
There is nothing eciting about the prospect of looking the endless parade at airports of 737/A320/757/767/A330/787 types planes that are twin wing mounted engines..BORING!!!
Access-Air
Remember, Wherever you go, there you are!!!!
Tue Mar 13, 2007 12:49 pm
Quoting Kdm (Reply 41):
Very common for a 22.5kgs Ground Fire Extinguisher present during Engine Start.In fact out here its Mandatory.
regds
MEL
LH707330
Wed Jun 26, 2013 6:47 am
Does anybody know how much the inlet was extended on the hush-kitted engines? Did they basically just insert a donut ahead of the fan and then add the slightly wider duct extension aft?
Viscount724
Thu Jun 27, 2013 12:48 am
How do people find these 6-year-old threads to resurrect?
Max Q
Thu Jun 27, 2013 4:36 am
Quoting Viscount724 (Reply 45):
It is amazing, I saw 411A contributing and thought he had been resurrected !
LH707330
Thu Jun 27, 2013 7:34 am
By using the search function to avoid being flamed for "why didn't you use the blue button!?"
I think I found the answer though by looking at pictures: Travolta's plane and VH-XBA (the Qantas one that was restored in 2006/7) have an extended bypass duct aft and the same forward section, based on the following two pictures:
Hush kit on VH-XBA (note the wider section aft):
http://www.adastron.com/707/flyhome/images/nk-220.jpg
No hush kit on vintage Bcal 707:
http://upload.wikimedia.org/wikipedia/commons/thumb/c/c1/Boeing_707_engineviewedit.jpg/800px-Boeing_707_engineviewedit.jpg
Completely redone cowl on N88ZL (which everyone thinks is a JT8D even though it is a JT3D):
DL_Mech
Thu Jun 27, 2013 2:30 pm
I think JTs' 707 has the Comtran Super Q 707 hushkits (design later sold to Omega Air).
Seen here on their own -138B:
Photo © David A. Grant
Photo © Rolf Wallner
The Prototype:
Photo © Frank Schaefer
More Info:
http://www.aero.pub.ro/wp-content/up...E_S_AIRCRAFT_UPGRADES/jau_0852.htm
[Edited 2013-06-27 07:38:23]
This plane is built to withstand anything... except a bad pilot.
Users browsing this forum: 747classic, Faro, skyhawkmatthew and 20 guests
