Arniepie
New Problem For All 737 Rudders?
Sun Feb 18, 2007 4:51 am
http://www.airweb.faa.gov/Regulatory...7400086257275005A3828?OpenDocument
Is this the same as the old issue with the classic and 200 series or something different.
Also am I correct in understanding that it has to be solved pretty quickly?
[edit post]
EI321
RE: New Problem For All 737 Rudders?
Sun Feb 18, 2007 4:55 am
Wasnt there something about this in flight international last week?
OPNLguy
Sun Feb 18, 2007 4:57 am
Quoting ArniePie (Thread starter):
I think the word "superseding" would indicate that the new AD replaces the old AD (for the original rudder issue) and mandates some new items.
SUMMARY: The FAA is superseding an existing airworthiness directive (AD) that applies to all Boeing Model 737 airplanes. The existing AD currently requires installation of a new rudder control system and changes to the adjacent systems to accommodate that new rudder control system. For certain airplanes, this new AD adds, among other actions, repetitive tests of the force fight monitor of the main rudder power control unit (PCU), repetitive tests of the standby hydraulic actuation system, and corrective action; as applicable. For those airplanes, this new AD also adds, among other actions, replacement of both input control rods of the main rudder PCU and the input control rod of the standby rudder PCU with new input control rods, as applicable, which ends the repetitive tests. For certain other airplanes, this new AD adds installation of an enhanced rudder control system in accordance with new service information. This AD results from a report of a fractured rod end of an input control rod of the main rudder PCU and a subsequent report of a fractured rod end of the input control rod of the standby rudder PCU. We are issuing this AD to prevent failure of one of the two input control rods of the main rudder PCU, which, under certain conditions, could result in reduced controllability of the airplane; and to prevent failure of any combination of two input control rods of the main rudder PCU and/or standby rudder PCU, which could cause an uncommanded rudder hardover event and result in loss of control of the airplane.
ConcordeBoy
Sun Feb 18, 2007 6:54 am
What's interesting to note about this is that it also applies to the 737NGs, not just (primarily) the 73S/733 as before.
See also:
http://www.airliners.net/discussions/tech_ops/read.main/182492/
DAYflyer
Mon Feb 19, 2007 12:29 am
Quoting ConcordeBoy (Reply 3):
Why is that? As I understand it, the 737NGs have an all new rudder system.
One Nation Under God
jetfuel
Mon Feb 19, 2007 2:37 am
They have 30 days to do all this work
This AD applies to all Boeing Model 737-100, -200, -200C, - 300, -400, -500, -600, -700, -700C, -800 and -900 series airplanes, certificated in any category
I can forsee some major schedule issues here for many airlines
Where's the passion gone out of the airline industry? The smell of jetfuel and the romance of taking a flight....
express1
Mon Feb 19, 2007 3:22 am
that is worrying to know,considering we are catching a Ryanair B738 flight out of LUTON to ROME in the morning!!!!
 eek
dave
David.S cavanagh since 1961,if you can do better,then show me.
glideslope
Mon Feb 19, 2007 4:36 am
Looks like a bad batch of control rods discoverd during testing. I's not every 737. Only the ones with the "defective Control Rods" were installed in. Seems to me they have an good idea where they went.
It's a supplier Q&C issue. Not a design issue. The failure was discovered in a Boeing mandated test. What lead to that test is not in the article.
magyar
Mon Feb 19, 2007 6:32 am
Quoting Jetfuel (Reply 5):
Quoting Glideslope (Reply 7):
When did the last 737 classic roll out? They have this "defective rod" issue for some time.
ConcordeBoy
Mon Feb 19, 2007 7:18 am
Quoting DAYflyer (Reply 4):
it's right there in the directive... 681 of them were delivered with "fractures in the rods have been caused by a quality control issue that resulted in the units becoming 'over-baked and brittle'".
wingnut767
Mon Feb 19, 2007 10:26 am
For certain airplanes, that NPRM proposed to add, among other actions, repetitive tests of the force fight monitor of the main rudder power control unit (PCU), repetitive tests of the standby hydraulic actuation system, and corrective action; as applicable. For those airplanes, that NPRM also proposed to add, among other actions, replacement of both input control rods of the main rudder PCU and the input control rod of the standby rudder PCU with new input control rods, as applicable, which would end the repetitive tests.
We partially agree. We agree with Southwest Airlines that no further work is required by paragraph (g) for airplanes on which the input control rods have been replaced in accordance with paragraph (g)(4) of this AD. We also find that no further work is required by paragraph (h) for airplanes on which the input control rods have been installed in accordance with paragraph (h) of this AD.
The modified rudder packages are still going into the 737NG. They have not all been done. This is an addition to the AD already being done. Also the standby rudder and control rod are not being modified at this time. This seems to change that with the recurring inspections and tests.
For the replacement of the input control rod of the standby rudder PCU: This AD specifies a compliance time of within 90 days after the effective date of this AD whereas Boeing Alert Service Bulletin 737-27A1279 specifies a compliance time of 24 months.
Regarding the reduced compliance times described previously, an unsafe condition exists that requires the immediate adoption of this AD; therefore, providing notice and opportunity for public comment before the AD is issued is impracticable, and good cause exists to make this AD effective in less than 30 days.
30 days to take effect and then 90 days to comply.
Yakum purkan min shmaya
ikramerica
Mon Feb 19, 2007 11:47 am
If you read closely, i don't believe this is true. The AD covers a subset of planes, and we really don't know which they are, how many, and whether some of these jets have already had this done as a precaution.
ConcordeBoy
Mon Feb 19, 2007 1:17 pm
Quoting Ikramerica (Reply 11):
how many,
...actually, that one it does specify.
adizzy
Mon Feb 19, 2007 1:21 pm
Sounds like Southwest is going to have alot of work to do over the next week. To bad they dont have a second type of craft in their fleet!
AsstChiefMark
Mon Feb 19, 2007 1:23 pm
Oh dear God! What's Northwest gonna do?
Mark  Silly
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
DfwRevolution
Mon Feb 19, 2007 1:29 pm
Quoting ADiZzy (Reply 13):
I don't think they have any regrets...  Yeah sure
sonic67
Mon Feb 19, 2007 1:39 pm
Quoting EI321 (Reply 1):
http://www.flightglobal.com/articles...es-resurface-despite-redesign.html
The article states the Boeing delivered 880 of which 681 were discovered to have been delivered with "suspect rods".
OPNLguy
Mon Feb 19, 2007 1:43 pm
SWA has 266 -700s in the fleet out of a total of 485 aircraft. *IF* all 266 were being grounded by the AD, I'd say you might possibly have a point. Since they're not, I'd say you don't...  Wink
Quoting DfwRevolution (Reply 15):
Roger that...  Wink
ikramerica
Mon Feb 19, 2007 1:59 pm
Quoting ConcordeBoy (Reply 12):
What I meant was we know how many were shipped that way, but we don't know how many have already been repaired per the AD. I highly doubt an airline like WN, for example, wasn't warned of the preliminary change in advance...
ConcordeBoy
Mon Feb 19, 2007 3:06 pm
Quoting OPNLguy (Reply 17):
...though this doesn't only apply to the -700 (not saying you're suggesting that either).
Adria
Mon Feb 19, 2007 7:09 pm
After 3 crashes they still didn't manage to fix the problem?
ConcordeBoy
Tue Feb 20, 2007 3:26 am
Quoting Adria (Reply 20):
...more than three; and despite patch after patch, the root problem still (and apparently, will always until the 737 is replaced by another model) remain(s).
sonic67
Tue Feb 20, 2007 4:16 am
Quoting ConcordeBoy (Reply 21):
This is a separate issue regarding possible cracked rods but some of the parts where part of the rudder control replacement.
The new rudder control system that includes new components such as an aft torque tube, hydraulic actuators, and associated control rods, and additional wiring throughout the airplane to support failure annunciation of the rudder control system in the flight deck. The system also incorporate two separate inputs, each with an override mechanism, to two separate servo valves on the main rudder power control unit (PCU); and an input to the standby PCU that also include an override mechanism.
IMG of new rudder control.
http://www.airliners.net/uf/view.fil...7524&filename=1171911422cfHvk2.jpg
ConcordeBoy
Tue Feb 20, 2007 7:09 am
Quoting Sonic67 (Reply 22):
Good stuff, but two questions immediately spring:
1) how many currently have this?
2) when will all be required to have this in service?
Adria
Fri Feb 23, 2007 5:53 am
So is the 737NG still safe to fly within those 30 days?
flashmeister
Fri Feb 23, 2007 9:03 am
Quoting Adria (Reply 24):
Yes, unless you work for a news outlet or are an associate of Scary Mary Schiavo.  Smile
I mean, seriously... thousands and thousands of these things flying around (plenty, by the way, with the old rudder design too) and yet they manage not to fall out of the sky at the drop of a hat. You're in far greater danger driving a brand new car off the lot than you are taking a hop on a 20-year-old 737... despite what NBC News might say.
