goinv
Turbulence And Helicopters
Fri Feb 23, 2007 7:21 pm
Do helicopters suffer from chop/turbulence as do aircraft ?
You hear many stories about how turbulence affects civilian flights but I honestly can't say I have ever heard a story of helicopters and turbulence.
Is this because far more people travel in commercial aircraft compared to helicopters so , by default, there are more people to witness such events ? Or is is because of the way that helicopters fly - by "pushing" the air down to stay aloft rather than "pushing" it vertically as in the case of an aeroplane ?
Be who you are, The world was made to measure for your smile. So Smile.
cancidas
RE: Turbulence And Helicopters
Fri Feb 23, 2007 10:32 pm
helo's don't fly as high as commercial a/c. in my expierience, i haven't experienced the major chop in ahelo as i have up in the flight levels. actually, most times i've only hit turbulence on a long cross-country flight when cruising in upper air.
"...cannot the kingdom of salvation take me home."
cptspeaking
Fri Feb 23, 2007 10:54 pm
Most of why you don't feel turbulence as much in a helicopter is because the wings are flexible. Unlike airplanes where you've got wings that are fixed and fairly rigid, the blades on a helicopter are designed to flap up and down, so more bumps are absorbed before they are felt in the cabin.
Your CptSpeaking
...and don't call me Shirley!!
KELPkid
Sat Feb 24, 2007 1:12 am
I think they can generate substantial amounts of wake turbulence...
I was once following a US Army CH-47 Chinook on the ILS at TIW (Tacoma Narrows, WA). The tower controller told us "Caution Wake Turbulence".
avt007
Sat Feb 24, 2007 1:39 am
The ride can be bumpy sometimes, but generally speaking the ride is smoother when compared to a private aircraft, a Cessna or light twin. The size and weight are fairly close, but helicopters seem to ride rough air better. I prefer a helicopter over GA aircraft.
FredT
Sat Feb 24, 2007 3:20 am
I'd suggest starting by looking at the relative magnitudes of the wing loading/disc loading.
When there is enough turbulence for you to hear about it in the media, it is almost always related to the heavy clear air turbulence which can be found up in jet stream territory, i e the higher flight levels. Helicopters don't venture there.
Quoting KELPkid (Reply 3):
About the same as any other aircraft. Substitute wing span for disc diameter.
Quoting Goinv (Thread starter):
You'll find that aircraft and helicopters stay in the air in the very same way - by pushing air down.
UH60FtRucker
Sat Feb 24, 2007 5:38 am
Yes, each helicopter produces a good amount turbulence.
Typically when flying in a stacked formation, you will encounter the wake turbulence behind the chalks in front of you.
Also, while on the ground, and a helicopter is hovering close by, or slowing hovers by you... you will encounter their disturbed air. And if you are hovering as well, then it becomes a little more difficult to hold a stable hover.
...well... so I hear. I am steady as a rock when hovering. I've never encountered issues.  Wink
-UH60
Your men have to follow your orders. They don't have to go to your funeral.
metroliner
Sat Feb 24, 2007 6:21 am
Quoting UH60FtRucker (Reply 6):
yeah... i got this once when putting an ASK-13 training glider down over a JetRanger that was on the taxiway having just started up... scared the pants off me! and it was only my third solo flight. i think my instructor was very curious as to why i had landed about 200m short of where he wanted me to be...
thank god it wasn't a UH-60, or i'd have been picking grass from between my teeth!  Smile
toni
Set the controls for the heart of the Sun
bhill
Sat Feb 24, 2007 12:56 pm
Helicopters ARE turbulence!!!  Wink ' cause mother Earth keeps trying to push them away..
As a previous Army medic, starting an IV in a Huey was a bitch!! Funny..I don't ever remeber having a smooth ride in a chopper...Either on a medivac flight or when I was with the artillery folks going air mobile with a 105 stapped under us...but the static generated...WOW!!!
Carpe Pices
L-188
Sat Feb 24, 2007 1:29 pm
Jeezus, that is an understatement by the controler.
WNCrew
Sat Feb 24, 2007 2:00 pm
I used to take a helicopter to/from work everyday several years ago (I was NOT an FA then)....and we had lots of chop, also weightlessness (a few seconds here and there) because of mountain waves.
zvocio79
Mon Mar 05, 2007 8:18 am
Helicopter also have one or more vibration absorver located around the nose and towards the center of gravity that reduces vibrations....they are like many pieces of heavy steal put together (150Lbs) that vibrate almost like a guitar string when been touch.
cancidas
Mon Mar 05, 2007 2:56 pm
was getting checked out in a jetranger a few years back, and sat on the grass abeam a run-up area at FRG. was in a good mood so i pulled up on the collective just a little, enough to get the warrior next to me with my former CFI a few bumpy minutes. he didn't totally hate me for that, until i got TO clearance before his student was done with his checklist.  duck
Users browsing this forum: Afstand and 1 guest
