JAM747
What Is The Effect Of Rain On Jet Engines?
Mon Feb 26, 2007 7:03 am
When a jet aircraft flies through rain does the ingestion of water with air affect the engine's performance such as fuel burn, thrust, wear etc? Can rain be too heavy that it causes a engine stall? How is it determimed if the rain fall is too dangerous to fly in? Do pilots take different precautions for engine settings during rain?
KELPkid
RE: What Is The Effect Of Rain On Jet Engines?
Mon Feb 26, 2007 10:49 am
Quoting JAM747 (Thread starter):
Water injestion is indeed tested during certification...as I recall, at least one engine manufacturer aims a fire hose at the engine to make sure it keeps going  Smile The testing varies by manufacturer, however they all test for it.
Well, I'm no jet driver, but maybe one of you guys could chime in here...I do believe that many makes of engine require the ignitors to be turned on when entering dark clouds/heavy precipitation...
Jamie757
Tue Feb 27, 2007 2:41 am
Quoting KELPkid (Reply 1):
Water injestion is indeed tested during certification...as I recall, at least one engine manufacturer aims a fire hose at the engine to make sure it keeps going The testing varies by manufacturer, however they all test for it.
Testing of the GE90-115B a few years back....
As I understand from previous posts on the matter, the engine must demonstrate no loss of rated thrust during the water ingestion test.
Rgds.
"I feel like a turkey who's just caught Bernard Matthews grinning at him!"
airfoilsguy
Tue Feb 27, 2007 3:11 am
Here is a rather miraculous instance where a 737 lost both engines but landed safely on a levee.
During descent from FL350 for an IFR arrival to New Orleans, the flight crew noted green and yellow returns on the weather radar with some isolated red cells, left and right of the intended flight path. Before entering clouds at FL300, the captain selected continuous engine ignition and activated engine anti-ice systems. The crew selected a route between the 2 cells, displayed as red on the weather radar. Heavy rain, hail and turbulence were encountered. At about FL165, both engines flamed out. The APU was started and aircraft electrical power was restored while descending through abou FL106. Attempts to wind-mill restart the engines were unsuccessful. Both engines lit-off by using starters, but neither would accelerate to idle; advancing the thrust levers increased the EGT beyond limits. The engines were shut down to avoid a catastrophic failure. An emergency landing was made on a 6060 feetx120 feet grass strip next to a levee without further damage to the aircraft.
Investigation revealed that the aircraft encountered a level 4 thunderstorm but engines flamed out, though they had met the FAA specs for water ingestion. The aircraft had minor hail damage; the #2 engine was damaged from overtemperature.
PROBABLE CAUSE: "A double engine flameout due to water ingestion which occurred as a result of an inflight encounter with an area of very heavy rain and hail. A contributing cause of the incident was the inadequate design of the engines and the FAA water ingestion certification standards which did not reflect the waterfall rates that can be expected in moderate or higher intensity thunderstorms."
Follow-up / safety actions:
After the incident, OMB 88-5 and AD 6-14-88 were issued to require minimum rpm of 45% and to restrict the use of autothrust in moderate/heavy precipitation; engine modification was provided for increased capacity of water ingestion.
Despite of this AD, a Continental Airlines B737-300 suffered a nr.1 engine flameout while descending through heavy precipitation with throttles at flight idle, July 26, 1988. The co-pilot warned the captain of the fact that idle descent was contrary to recently published procedures, but idle descent was continued.
http://aviation-safety.net/database/record.php?id=19880524-0&lang=en
It's not a near miss it's a near hit!!
phxplanes
Tue Feb 27, 2007 3:17 am
Wow thats an amazing video, I have always wondered about water in the engines, its amazing that there is no loss of performance.
FredT
Tue Feb 27, 2007 7:25 am
A little water can make the engines able to provide more thrust. Engines provide thrust by heating air in order to expand it. Ever seen a steam engine... ?  Wink
ZBBYLW
Wed Feb 28, 2007 9:34 am
I belive this happened to an A330 out of PVG or PEK about a year ago... both engines flamed out on take off.
Keep the shinny side up!
F14D4ever
Wed Feb 28, 2007 1:08 pm
Quoting Airfoilsguy (Reply 3):
Another more recent instance involved Garuda PK-GWA 733 flying AMI-JOG. It flew into the confluence of two huge storms, and experienced a dual flameout, despite the pilots having set ignitors to 'continuous'. This precipitated the redesign of the CFM56 front end, including moving the splitter rearward so the booster swallows less water, and changing the spinner to the current 'coniptical' shape, a hybrid conic / elliptical shape which more effectively flings hail and water further out radially past the aforementioned splitter.
"He is risen, as He said."
MD11Fanatic
Wed Feb 28, 2007 5:43 pm
Quoting ZBBYLW (Reply 6):
So what became of this flight?
Wed Feb 28, 2007 7:31 pm
Isn't the Def of Turbulence subject to the Interpretion of the Pilot flying.Some would consider shaking in their seat due Turbulent weather to be Turbulence.
regds
MEL
ZBBYLW
Fri Mar 02, 2007 1:05 pm
Quoting MD11Fanatic (Reply 8):
From what I recall, after loosing a little bit of altitude they were able to restart both engines. I am hoping someone who knows more about it can shed some light, or at least find a link to the thread on the incident. From what I recall, the flight was going to Europe.
FredT
Sat Mar 03, 2007 2:30 am
Quoting HAWK21M (Reply 9):
There's an agreed scale on what constitutes what degree of turbulence. Not that turbulence has much to do with engines ingesting water...
Sat Mar 03, 2007 5:51 pm
Quoting FredT (Reply 11):
True.but there is no way to interpret it apart from the Pilots view on the same.
regds
MEL
F-WWAI
Sun Mar 04, 2007 12:47 am
I was really tempted to answer that the engine would become wet... but I think you were after something else.
Lets resume in terms of
* effective water capture
The quantity of water entering the engine is a function of aircraft speed, (core) inlet size, droplet size and nuber of droplets per air volume in front of the engine.
high aircraft speed plus many big raindrops = high quantity of water.
* water/air ratio in the combustion chamber
You may imagine that, if the water/air ratio increases above a certain limit, then the energy developped by the combustion will entirely be used up for water vapourisation and heating, and the combustion will nomore be sustained. The flame extiguishes because there are nomore sufficient radicals in recirculation to light the injected fuel.
Since the water capture is fixed by the parameters above, the water /air rate is then governed by the (core) engine airflow. It is highest at IDLE and lowest at MAX power.
We would therefore not expect the engine to stall in any case of rainfall, but the risk of flameout is increased at idle. Engine control is normally tailored to take this into account and guarantee a minimum airflow, sufficient to avoid excessive water/air ratio. Modern engines have, in top of these protections, also an automatic relight feature to recover from a flameout.
hoping this obtains your satisfaction,
your
FW
pilotaydin
Sun Mar 04, 2007 6:30 pm
turbulence CAN cause compressor stall, due to erratic air flow patterns at engine inlet, rainfall doesnt cause this, rain and wet weather can cause flameout...so always put those start switches into FLT mode baby!
The only time there is too much fuel onboard, is when you're on fire!
soaringadi
Wed Mar 07, 2007 7:46 pm
Quoting ZBBYLW (Reply 10):
LoL.....  Smile
Seriously no offense...... but I couldnt resist..... that is just very funny !!!
If it ain't Boeing, I'm not going !
Users browsing this forum: Okcflyer and 2 guests
