redcordes
Wing-loading Vs Ride & Turbulence
Fri Mar 09, 2007 7:43 pm
Having a higher wing-loading has it's disadvantages (longer take-off roll, slower climb rate), but doesn't this provide a smoother ride and better ability to penetrate turbulence without over-stressing the airframe? I believe the B747-8 will have significantly higher wing-loading than the A380, so would a better ride and ability to handle turbulence favor the B747-8 in these measures of performance?
"The only source of knowledge is experience." A. Einstein "Science w/o religion is lame. Religion w/o science is blind."
411A
RE: Wing-loading Vs Ride & Turbulence
Sat Mar 10, 2007 1:04 am
Overstressing the airframe is really not a particular consideration with high wing loading (IE: less square feet of wing area for the same weight) as the structure is built to accomodate, however that higher wing loading will generally provide a slightly smoother ride in turbulence.
It however is very subjective, and what appears to work with some aircraft does not, with others.
It has more to do with wing-mounted engine placement, and the wing bending relief provided, among others.
Users browsing this forum: 727LOVER, 727tiger, DaCubbyBearBar and 2 guests
